Question about Biostar GEFORCE 6100-M9 Motherboard
Motherboard: Biostar 6100-M9 with Opteron 165, cold start problem
The system works perfectly, including warm restarts. It also overclocks very nicely but this has nothing to do with the problem.
Problem: once powered off, it will not power on again with the normal soft switch button. Only when pulling the AC plug or switching off the PSU at the back of the machine for like ten seconds, then switching on again the machine can be started normally. That is, a power cycling routine is always required for a cold boot.
I've tried two different PSU's, same behavior.
I've also tried to reset the bios but the problem persists.
I tried another cpu in this MB, a single core Amd64. Then it worked normally.
So it seems like the problem has something to do with the particular dual core cpu I'm using. I use the latest bios released for this MB.
How can this be solved? I find it extremely strange that this cpu works perfectly in this rig in all other aspects but this very basic one... Of course it is possible to live with this awkward startup routine I guess but it would be very nice if it could be made to behave normally.
Many thanks in advance for all input!
  • 2 more comments
  • Håkan Sterner May 22, 2009
    It is a good quality 350 W Fortron PSU with lots of current on the 12V rails. Rather old though. The other PSU I tested was in a similar class. i.e not extremely powerful but good quality. Maybe it is too weak after all and that it shows in this peculiar way. Perhaps there is some kind of protection in the PSU that kicks in to prevent overload.
    When I think of it, I immediately fried a 430 W Antec PSU not too long a go after I installed a new graphics card in my son's rig, also dual core Opteron. It wouldn't even start the computer, the PSU only emitted a strange rising beep like it was about to explode... That computer worked perfectly after I installed a 600W Fortron Epsilon.
    I'll try this, thanks!
  • Håkan Sterner May 31, 2009
    I upgraded the power supply to an FSP Fortron Epsilon 600W. This is a very good power supply that I have used before in more power hungry machines.
    Unfortunately it didn't help. The annoying start-up behavior is exactly the same as before, the machine needs a power cycling with a delay of approx 10 seconds in order to start up again from "cold".
    It is such a pity that this machine that works so beautifully in all other aspects suffers from such an annoying defect. I even had the mainboard sent back to the dealer, it came back in the exact same state: they claimed it tested ok, nothing wrong with it according to them.
    As I said, it works normally with some cpu:s, it is just that the cpu I prefer for this machine - Opteron dual core - produce this stupid start-up troubles.
    Bottom line: problem is still unresolved, proven not to be PSU-related. Anyone have any other ideas?
  • Håkan Sterner Jun 01, 2009
    PS. The other FSP Epsilon 600 I have powers a similar system, only that it is a slightly overclocked dual core Opteron 185 (@ 3 GHz) and a moderate SLI graphics configuration. No problems whatsoever, rock steady voltages at all system loads just as it should be with a well suited high quality PSU.
    The system I have problems with is clocked much lower and has only a single graphics card that draws approx a quarter of the graphics in the gaming rig. It behaves exactly the same with the FSP Epsilon 600W as it did with a 350W FSP PSU. The PSU operates at only a fraction of its capacity as measured by a Watt meter, 220 W typical under load so it is nothing.
    Thanks for inspiring me to rule out the PSU as a potential problem as this was one of the possibilities that seemed possible given available information. It feels good to know I have a PSU now that doesn't have to operate close to its limit. Also much better efficiency figures in the new PSU that is 80+ certified, this may save some money on the electrical bill over time.
    President:
  • 414 Answers
What is the wattage of your power supply?
If is 600 watts or less you'll need a 650 watt or larger.
Mark
Posted on May 22, 2009
  • Mark Gough May 31, 2009
    If you'll read again for any dual core motherboard a minimum of 650 watt power supply is required.
    Mark
    Yes the problem is the power supply the only power supplies that are dual core certified are ones that are l650 watt or larger. Been doing this for over 28yrs.
Whre to plug in usb cable on moterboard
you can plug it on the back on those square holes
Nov 27, 2013 | Biostar GEFORCE 6100-M9 Motherboard
Geforce6100-m9 motherboard lan Drivers and Download
Try "DriverPack Solution" for the drivers. And to make answering your questions easier, you might want to actually ask a question.
Mar 06, 2012 | Biostar GEFORCE 6100-M9 Motherboard
My inbuilt audio not working
Go to tyhe bio star site and down load the drivers for sound.That should fix the problem.
Jun 28, 2011 | Biostar GEFORCE 6100-M9 Motherboard
Can i change my 32 bt mother bord into a 64 bit
32Bit/ 64Bit is the respective capacity of the motherboard hardware for data flow within the motherboard and its components and it can not be changed.
Hope this helps! Good Luck!
CreativeTECH
Jan 08, 2011 | Biostar GEFORCE 6100-M9 Motherboard
I need to reinstall windows cause its corruped i can't get into the bios to restart pc from cd cause i don't know the pas word please help
You will have to reset the BIOS to factory. To do this, you will have to open the case and expose the motherboard. The motherboard will have a set of pins that when touched together, it resets the bios and wipes the password. You will have to locate this set of jumpers and short them.
Look at a map of the board, and look for the reset jumpers here:
ftp://ftp.biostar-usa.com/manuals/GEFORCE%206100-M9/GeForce%206100-M9_BIOS.pdf
If you can not find the reset jumpers, you can just take out the battery on the motherboard. It is silver, round and the size of a quarter. A simple clip holds it in place. remove it and put it back in.
Then put it all back together, and reboot. press the del key or F1 key durring the begining of the boot cycle and you will be able to able to access the BIOS to change the boot sequence.
Apr 25, 2010 | Biostar GEFORCE 6100-M9 Motherboard
Comp building assist geforce 6100 m9 mainboard
check out the myspace computer and technology forum.
Dec 22, 2009 | Biostar GEFORCE 6100-M9 Motherboard
New ram makes my pc freeze
Many motherboards when booting from dual sockets wish for ram either of same manufactuer or same capacity per stick
Jan 14, 2009 | Biostar GEFORCE 6100-M9 Motherboard
Windows loads on every other boot.
Let's try running a memory test program. http://memtest.org/
Scroll down till you see the three screen shots. Just under them pick you're choice of bootable media to test you're memory.
Download - Pre-Compiled Bootable ISO (.zip)
or
Download - Pre-Compiled package for Floppy (DOS - Win)
Luck!
Mike
May 15, 2008 | Biostar GEFORCE 6100-M9 Motherboard
Biostar GEFORCE 6100-M9 Motherboard Logo
354 people viewed this question
Top Biostar Computers & Internet Experts
Jayburt
David
David
Matthew Spark
Matthew Spark
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
