Tv reception problems
THe TV picture in the Den is just like a scrambled puzzle all over the screen. Colors as well. My mother & I have made numerous calls about this & we are still going through this. We want this fixed. We do not know if this is a reception problem or a line not connecting. We want help now.
  • 119 Answers
SOURCE: panasonic tv has white lines at top of screen
suspect it's 1 or a couple of bad capacitors in the vertical deflection circuit the caps are in the 400 series, c400,c401,c402, etc... check or replace c414,c418 & c417
Posted on Oct 31, 2006
SOURCE: convergence board
It wouldn't be the entire convergence board, you more than likely have a bad convergence STK-IC. Replacing the IC will take a good bit of knowledge and training as far as electronic repair is concerned, plus a complete convergence set up. In other words, unless your certified, you need to contact a tech. The convergence set up alone has driven men to drink.....
Posted on Jun 08, 2007
  • 87 Answers
SOURCE: Philips TV showing horizontal lines model 27pt6441/37
You likely have an elevtrlytic capacitor bad on the B+ line to the vertical ouput ic. If you continue to use the set like this it is likely the vertical ouput ic will fail.
Posted on Jun 26, 2007
MikeNJ1964
  • 398 Answers
SOURCE: TV
The vertical output IC has stopped working. The vertical output IC is the part that drives the coils in the yoke that spreads the picture up and down. This could be because it has cracked loose from the board (solder joints) or it simply burned out. Sometimes a bad pump-up cap will cause the vertical output IC to short out, and when the IC shorts out it often opens up a small value resistor next to the flyback. This is a relatively easy thing to repair. A qualified tech will be able to tell exactly why the vertical output has stopped working and repair it for you.
Posted on Aug 25, 2007
chrispurs1
  • 372 Answers
SOURCE: Color line across the center of a black screen
Hi. this is caused by dry solder joints on the frame o/p IC. Resolder all legs of frame chip. Should sort that out.
Posted on Sep 12, 2007
Black spots on screen and scrambled picture
Well this cloud be due to 2 reasons
  1. It could be that you are have low reception from your DTH operator or cable operator
  2. There could be fault in our TV
You better get it checked by a professional or contact Sanyo
NOTE: the first one applies only if all the TV's in your home are acting the same way
Oct 07, 2015 | Sanyo DP42848 LCD TV
Picture scrambled / multiple pictures
CONVERGENCE PROBLEM. FIND A HONEST TV TECH. MAYBE A $300 REPAIR
Nov 11, 2013 | Sony KP-61S70 61" Rear Projection...
My LCD tv screen becomes scrambled on half of the screen with input from a different source and has reddish colors.
Likely another board is bad--GET IT IN FOR REPAIR UNDER WARRANTY BEFORE NO WARRANTY SITUATION
Apr 01, 2012 | Televison & Video
Periodic color scrambling - out of focus. Seems as though the different colors separate and get out of focus.
Ur tv is having a convergence problems,it dead.Colors lines R,G,B mis alignments,have colors shadows pictures or 3D picture look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts must be replaced on the tv convergence board to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Jan 22, 2011 | Hitachi 50GX30B 50". Rear Projection...
Noisy sounds like a fan and the picture starts to flickers multiple colors and picture is scambled.
This tv have a colors wheel.The colors wheel is dead.The colors wheel is dying,going to be dead.The tv make loud humming,noisy sounds like a loud fans or motors noises.Also the tv colors flashes black&white or multiple colors pictures and scrambled.Colors wheel replacement is difficult,never done tv repair before.Hire a tv Tech. to replaced the tv colors wheel.
Nov 16, 2010 | Samsung HLN5065W 50" Rear Projection...
54inch Hitachi TV has double figures and colors red, yellow-not normal. Set approximately seven -eight years old. Lost remote control and direction book in moving. Is the set worth getting fixed? Generally...
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony2_bing.gif,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer2_bing.gif, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 11, 2010 | Hitachi 57F500 57" Rear Projection...
Picture colors scrambled
Ur convergence it dead,Know how to solders?Buy a convergence kit to repair.These websites have the kit.Tv repair World.com,Tv Repair Kits.
Dec 12, 2009 | Toshiba 57H82 57" Rear Projection...
Pictures goes to distorded wavy lines.
This could be attributed to tuning reception of your tv. If your using antenna only, it is most probable. If cable, check your line.
If this is a crt type, moving that tv with that size could somehow bend its circuit board. Loose connection is a probability. Could be some minor component is detached from solder. This can be attributed to tuner and vertical IC.
Just for an input.
Apr 20, 2009 | Sanyo DS27910 27" TV
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
Electro Med Services...
