Question about Car Audio & Video
Alpine sbr229a diagram
What is power trancsistre in amp
Need wiring diagram for alpine amp. mod.#3533
What does a black wire hook up to it's coming off the board jp8
Jan 11, 2015 | Alpine Car Audio & Video
I need to know how to wire 2 Kicker comp 10" subs
you can find your wiring diagram here
http://www.crutchfield.com/S-lCf6ewrWNQM/learn/learningcenter/car/subwoofers_wiring.html
Select from the list shown which describes your amp and subs (ie 2 channel amp with 2 4ohm subs)
Hope this helps and please rate, thanks
Mar 19, 2011 | Alpine MRP-M500 Car Audio Amplifier
How should I wire a 4 channel amp for alpine sps 600, 609
they are only 4 ohm speakers so just put the front speakers on channels 1&2 or a&b and the rear on 3&4 or c&d since you are using a 4 channel amp thats what they are designed for
Jul 09, 2010 | Alpine SPS-600C Car Component System
Where to get the wiring diagram for the alpine ktp-445 power pak amp. want to cut the plug off so I can wire to a different reciever/player
the wiring diagram is the same as your stereo , check for your actual stereo manual use the same pins layout.
Jan 16, 2010 | Car Audio & Video
Need wiring diagram ktp445 to be installed on a NON alpine unit
please, I need wiring diagram for a alpine ktp445.... to be installed on a NON alpine unit.
thx
dave
Dec 06, 2009 | Alpine KTP-445 Car Amp
Installing an alpine stereo in a 1999 Dodge 1500, I have power to the stereo but nothing from the speakers There is supposed to be an amp somewhere in line but I'm having no success at finding anything and...
if you have an infinity system you more than likely have an amp somewhere, if it isnt located on the passenger side either on side of or beneath the glove box it may be mounted in the rear... behind one of the side rear panels, or beneath the rear seat...
Jul 12, 2009 | Alpine Car Audio & Video
I need the wire diagram
Yellow: Constant +12VDC (memory)
Red: key-switched +12VDC (accessory)
Black: Ground
Blue/white: amp remote or power antenna output
Speaker wires: The solid-color wire of each pair is positive; the black-striped wire is negative.
Left front: white
Right front: gray
Left rear: green
Right rear: violet
Hope this helps!
May 08, 2009 | Alpine DHA-S680 6-Disc CD/DVD Changer
ALPINE MRV F400 AMPLIFIER
your best would be to contact alpine for that info on there website...that is a old amp .
Jun 23, 2008 | Car Audio & Video
Subwoofer
what OHM is the voice and what OHM can you amp Handel?
This are the facter that you need to know but the esey to do it is + to + and to the + on the amp and the - to - and to the - on the amp and this should give you a Two OHM ratting and will giv you Two time the Power out of your amp?
If you need more help E-Mail me at Gennisthgreat2000@yahoo.com
Oct 24, 2007 | Alpine SWR-1542D Car Subwoofer
Car Audio & Video Logo
50 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
