Question about Jungle Video Game Consoles & Games
Clean sweep claw machine. Looking for manual. Lights come on but timer doesn't. I have 1 wire going to a fuse holder but no wire goes on? I'm sure this needs to make a loop
I replaced fuse and timer came on claw went done and when it went back up it got tangled. Never came on again?
SOURCE: bobbin tangle
can not thread bobbin...bobbin on top
Posted on Apr 27, 2008
Fixitman909
  • 430 Answers
SOURCE: Brake Lights and Hazard still dont work
TEST FRONT RIGHT BLINKER CIRCUIT AND REPLACE THE BULB,,WITH PROPER BULB...A DOUBLE CIRCUIT BULB IN A SINGLE SOCKET WILL DO THAT ALSO A SINGLE SOCKET BULB IN A DOUBLE SOCKET HOLDER....CHECK LEFT SIDE BULB FOR ACURANCY
Posted on Aug 30, 2009
protek480
  • 1714 Answers
SOURCE: switch loop with mutiple fixtures
Here you go:
Posted on Sep 26, 2009
apart4u
  • 213 Answers
SOURCE: Hoover TCE660 tumble - no heat
Common faults -
1 The heating elements can fail (meaning open circuit)
2 There are cut-outs (T.O.C's) that might need resetting
3 The thermostats (stats) can trip out or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehave programs that can fail and circuitry although most should produce an errorcode showing you were the fault is.
5 Faultyconnections and burned wires may also be the fault.
Free tumble dryer repair videos
We have a Free full video library on appliance repair video’s
Posted on Jan 13, 2010
  • 8 Answers
SOURCE: We have a Clean Sweep Arcade size claw game,
99% of the time, if you've made sure the switch and wires complete the circuit, take the top cover off of the claw assembly, and look for a broken off wire. Check the connections, sometimes the wire can be broken from the connector (usually no connector, you have to solder it back on). Just make sure those wires are making connection, the clean sweep games specifically have this problem, and it is almost always one of these wires. You can even do a google search of "Clean Sweep Crane claw won't grab", and see where others have discovered this same issue and solution.
Posted on Apr 14, 2011
Where is fuse located
Leonard, first, unplug the microwave and then turn it around so that you are looking at the back of the unit. Take the screws out that hold the cover onto the unit, most will be accessible from the back, but some may be on the side as well. Once you have all of the screws out you can remove the cover and set it aside. Find where the power cord goes into the back of the unit and follow the black wire from the cord to where it stops. Usually it will go either to a circuit board where your fuse will be located or it will go directly to the fuse holder. The holder could be a block mounted to the unit or it occasionally goes to an in-line fuse holder. The fuse will be stamped with the amperage rating on one end of the fuse on the metal collar. You need to make sure that you replace it with the same amperage fuse. Hope this helps!
Feb 16, 2015 | Panasonic Nn-sd697s Microwave Oven Single...
I'm constructing a pair of custom light tubes aircraft aluminum housings with 6' acrylic pipes shooting up to the ceiling I'm using a mixture of bulbs from M13 70 watt halogens to 75 watt black spot lights...
The breaker (or fuse) in your house wiring will handle the dimmer switch if it goes "haywire", but will NOT protect your project if your project goes "haywire".
Yes, put a properly rated fuse or breaker AFTER the dimmer and BEFORE your project. Keep it close to the total maximum load your project will draw, and you will likely be as protected as you're going to get.
(Yes, the fuse or breaker goes on the "Hot" wire only, the juice to the load [the lights] goes through the it)
Sounds like a fun and nifty looking project, Jesse!
Nov 01, 2014 | Electrical Supplies
Dash lights blow fuse
you have something shorting out you would need to find out which one. dash lights can be connecter by fuse to other parts. I.e door lights ignition timer light timer control etc you would need to find what one of these is causing the problem
Feb 07, 2014 | 1994 Oldsmobile Eighty Eight
Timer doesn`t work,doesn`t rotate.
If this is an electromechanical timer and the dial will not rotate, you can be pretty sure the timer motor is no good
May 21, 2013 | UPM 120V/240V Heavy Duty Outdoor...
Recemtly my pool sweep motor burned out so i had it rebuilt. I had to un wire the sweep side of the dual intermatic timer and when i tried to re ook it does not turn on. i was sure i unwired the two...
Hi Tom - I located a source for you to download a copy of the manual for this timer, here. This timer has several variations - which can not be determined with 100% certainty by me from the info you provided in your question, but I believe your application is the large, bottom schematic called "Filter and Cleaner Timer Inter-connections".
If a 240 volt circuit, both the power source and motor load should consist of 2 hot wires and a single bare, green or green & yellow striped ground wire. The 240 power source wires connect to terminals 1 & 3 and the 240 volt sweeper motor would connect to terminals 2 & 4. It does not matter which of the supply wires connects to terminal 1 or 3 - nor does it matter which motor's wires connects to 2 or 4. It is not possibly to change the direction that the motor turns by swapping wires in the timer. The green (ground) wires must all be connected together.
I hope this was helpful & good luck!
Nov 28, 2011 | Intermatic T10404R - Two 220 time clocks...
I am replacing a programmable timer switch that controls exterior garage lights. This switch is in the same box as a ac switch that turns on the lights inside the garge. There are 3 rolmex wires inside the...
Project is not clear.
Are you replacing the timer with a switch?
I have complete files on timers, so if you are replacing the old timer with a new timer, then add a comment and say which timer you are installing.
http://waterheatertimer.org/ST01C-program.html
You have 3 cables. Assuming 120Volts.
Each cable has 1 black and 1 white and 1 ground.
White wires are twisted together and pushed to back of box.
Ground wires are twisted together and pushed to back of box.
Black wires are next:
(A) Cable A:
One of the three cables will have a black wire that connects to both the switch and to the timer.
So look for the black wire that connects to both switch and to timer.
This is the hot wire from breaker box. Connect this black wire to both switches including new switch.
(B) Cable B: One cable goes to garage lights. Black wire going to garage lights connects to on-off switch.
So the garage light switch has 2 black wires: 1 black wire from cable A, and 1 black wire from cable B going to light.
(C) Cable C: One cable goes to outdoor lights. Black wire going to outdoor lights connects to new on-off switch.
So the outdoor light switch has 2 black wires: 1 black wire from cable A, and 1 black wire from cable B going to light.
Jun 27, 2011 | Hardware & Accessories
Washer went dead. replaced thermal fuse and it worked for about a week and went dead again. Before going dead it seemed to take it a long time to do a load of dishes. The last load ran 1 1/2 hours and...
sounds like you have a bad control board on unit.and the reason the thermal fuse went out is one of the relays are getting stuck on unit. before long the fuse will go bad again when the resistance level gets to high again. i would replace the control board and you should be fine...good luck to you...
Jan 06, 2011 | KitchenAid 24 in. KUDP01DL Built-in...
Dryer just stopped working. Light still come on. Timer sounds like its works. Door clicks when closed. The clothes were almost dry. Do you thik this could be a thermal fuse?
Ours did the same thing, light was on, timer sounded like it was working, door switch clicked like it should, and had full power to and through cord to drier. Thanks to all the posts on here I was able to narrow it down to the thermal cutoff fuse. it is the narrow and long white plastic fuse with two blue wires, located on the lower portion of the blower motor duct. I pulled it and useing an ohm meter determined it was blown. I obtained another from a local parts store for $14.95 went back home and replaced it. wa,la. its working again and my wife is happy again. thanks to all on this site for posting this money saveing information. Especially right here at Christmas time....
Nov 17, 2010 | Whirlpool LEQ9858P Electric Dryer
Video Game Consoles & Games Logo
119 people viewed this question
Top Jungle Video Game Consoles & Games Experts
James Wishart
Are you a Jungle Video Game Console and Game Expert? Answer questions, earn points and help others
