After the unit(etrex legend) locates the satilites, and i go to navigate, after a couple of seconds the screen goes blank, except of a single narrow vertical line. then i can't even shut the unit off. i have to remove a battery to shut it down. thanx jim
Accordingto Garmin, this problem can be fixed by disabling the WAAS feature in teh set up menu. There is an incompatibility between the old Garmin software and latest WAAS upgrades. Later software from Garmin is supposed to fix this problem.
This is a powering off issue. Put in fresh batteries once you acquire satellites and get coordinates turn the unit off immediately. The problem should be now fixed. When the batteries get low the unit does not turn off correctly and "black lines" until it is turned off manually with the power button.
Try changing the batteries, mine does that but only when my batteries are low
This is EXACTLY the same problem I'm having!! Except mine takes between 2 and 15 minutes for the blank screen with the horizontal line to appear and freeze up. Any help would be greatly appreciated.
