Question about Toshiba Satellite PSAG0U-02D00M Notebook
A305-S6858 Laptop screen replacement
I have all the screws out the bottom of the case but there something holding the key board keeping me from removing the top so I can change out the screen my satellite a305-s6858 laptop. Can you help me get it apart?
Rudy
  • mac ch Jul 24, 2012
    very helpful directions. I wanted to replace my A305-S6858 screen and the directions alongwith the pics helped a lot, thanks.
  • 191 Answers
Please reference follow steps to disassemble LCD screen
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A305/remove-replace-LCD-screen-inverter-1.htm
be careful all small cable like KB top cover LCD cable and inverter cable.
hope help you fix it, please take a rating let me know huw much helped you thanks! keep in touch your question.
Posted on May 21, 2009
  • 1 more comment
  • Frank Zhang
    Frank Zhang May 22, 2009
    please take a rating if the solution helped you thanks! keep in touch your comment.
  • Frank Zhang
    Frank Zhang May 24, 2009
  • Frank Zhang
    Frank Zhang May 30, 2009
Remove the cover on an emachine e525
Umm, well there are things like the motherboard and plamrest that have screws in them that might be holding it. You just can't remove the bottom cover, You have to start by Removing the bottom screws like you did, but then you have to remove other things before you can get the bottom case off. Also the VGA Port might have screws on both sides of it that keeps the bottom case from coming off.
Below are some steps to follow.
Look inside the battery case, hard drive case, memory case and dvd drive slot for screw. Some screws on the bottom case in inside of some of the device cases might have the icon of a keyboard next to it. Those screws hold the keyboard in place.
Turn the laptop over, remove the strip that is just above the keyboard but be careful because a cable might be attached to it. Then remove the screws that hold the keyboard in place that are under where the strip was and gently lift the keyboard out because there is definitely a cable under it.
Next you can remove the screws from the lcd hinges at the corners and lift the lcd screen off, also note that you will have to pull the antennas cable and the lcd cable when you remove the lcd.
Next start removing any screws that hold the palmrest in place. Take note of any cables that are attached to the palmrest and remove them then lift the palmrest off.
Next start removing any screws you see that hold the motherboard to the bottom case, then lift the motherboard out an start replacing the fan.
A digital camera to take pictures will be most helpful to refresh you memory of where things were.
May 31, 2012 | Computers & Internet
Satellite webcam driver open fail
You should check the graphics card driver! ! Many cases they are related with the driver! ! ! N card to the NV official website to download the latest drivers! ! if A card,you do to the AMD download.
Apr 28, 2012 | Toshiba Satellite A305-S6858 (4400 mAh)
Toshiba A305-s6858 black screen
I have same problem with HP laptop, one of the things i did the first time was to take off the battery and press on/off button for twenty seconds, put the battery back and turn it on. That works for me and i hope to help you.
THX.
Apr 25, 2012 | Toshiba Satellite PSAG0U-02D00M Notebook
How to replace cq57-229wm screen
HI,
On amazon you can purchase display for affordable price
Amazon com cq57 229wm screen. Take a look, but be awero... read reviews first.
regards
Mark
Jan 31, 2012 | Compaq Presario, Compaq EVO, Compaq...
Good Morning. I wonder if anyone could help me solve my problem I have a Accer Aspire 5535 and its around 2yrs old on windows Vista. The screen stopped lighting up and then on Random days it would...
This could be one of two things, it is either the inverter (this generates high voltage to run the back light) or it could be the back light itself.
As you have suggested, it could just be a loose wire or cable.
Replacing the inverter is relatively straightforward as it is located at the bottom edge of the LCD screen behind the plastic case. The backlight is usually part of the LCD screen and you would usually be better replacing the screen entirely.
To get at either of these components to check cables/wires etc, you will need to disassemble the screen case of the laptop, this is fairly simple if you are comfortable with disassmbling laptops.
A brief overview of the screen replacement process is below, instructions 1-4 show how to remove the case to access the inverter and cables:
1. Power off your laptop. Turn the laptop upside down so that you can see the bottom side of the laptop's case.
2. Depress the battery release latch and lift the battery and laptop ac adapter out of the laptop. Flip the computer back over and open up the LCD screen to a 90 degree angle.
3. Pull off each of the rubber buttons located along the edges of the Acer Aspire 5535 Screen. Remove each of the screws underneath the buttons with the Phillips-head screwdriver, remove keyboard.
4. Insert your fingers underneath the cover of the Acer Aspire 5535 Screen. Work your fingers around the edges of the cover to unlock it from the screen. Pull the cover off the screen and set it aside.
5. Locate the inverter board at the bottom edge of the Acer laptop screen . Disconnect the cables at the right and left end of the board that connect to the Acer Aspire 5535 Screen. Remove the screw holding the inverter board in place and then lift the board off the LCD screen.
6. Tilt the screen slightly towards you until you can see the strip of tape holding the video cable. Pull off the tape and then disconnect the video cable from the laptop case.
7. Remove the Acer Aspire 5535 LCD screen from the case. Set the new screen onto the case and reattach the video cable and tape strip. Position the replacement inverter board at the bottom of the screen and attach the screw.
8. Reconnect the inverter board's cables. Pop the plastic cover onto the Acer Aspire 5535 LCD screen and reconnect the screws. Set the rubber buttons over the screws. Reconnect the battery.
9. Turn on the laptop. Wait for the manufacturer's logo to appear on the screen to ensure the display was replaced properly.
Apr 13, 2011 | Computers & Internet
I have the Toshiba Satellite A305-S6857, and lately whenever i play music, or watch movies, or videos online the sound and video will skip or become delayed a couple seconds as if the computer is...
you do have something else running in the background and its using the internet, probably spyware or malware. run your anti-spyware program and check, if you don't have one, you need to try "malwarebytes" or "spybot" they are free programs
Mar 19, 2011 | Toshiba Satellite A305-S6857, A305-S6858,...
My Toshiba Satellite A305-S6858 keeps restarting when it is plugged in to charge. I have no problem running the laptop on battery Also, when plugged in and I boot in safe mode the problem does not occur....
On the computer manager, go to the device manager and disable the processors. It worked for me like a charm after several attempts to restore it to original settings and formatting the hard drive. It doesn't affect performance, it seems to be more a failure of the drivers than the hardware.
Mar 14, 2011 | Toshiba Satellite A305-S6857 Laptop
It works good on battery but when AC adaptor is plug in the laptop cuts out and restart by itself.
Problem description: The laptop shuts off when AC power adapter is plugged in. The laptop works fine on battery power but as soon as you connect it to AC adapter, the laptop turns off.
Possible cause: 1. Power adapter failure.
2. Motherboard failure.
Possible troubleshooting steps and repair solution: First of all, test the power adapter. Make sure the adapter outputs correct voltage. It's possible that the output voltage is not correct and the laptop shuts down to prevent the damage. Test your laptop with another known good power adapter.
Toshiba Satellite A305 AC Adapter
If the problem still exists, even after replacing the adapter, most likely it's the motherboard failure. Replace the motherboard.
Mar 11, 2011 | Toshiba Satellite A305-S6857, A305-S6858,...
Web camera on satellite a305-s6858 won't open
everytime i have seen that it is not software related. check if it is under warranty. typically it is the webcam cable that fails.
Nov 06, 2009 | Toshiba Satellite PSAG0U-02D00M Notebook
Drivers
Toshiba satellite A305-S6858 XP Drivers
all driver tested. all driver worked.
http://uploading.com/files/d6f2c6f5/toshiba305-S6858-XPdrive­rs.rar/
Jun 01, 2009 | Toshiba Satellite PSAG0U-02D00M Notebook
Toshiba Satellite PSAG0U-02D00M Notebook Logo
588 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
