Question about Hyundai HHD3500 Generator
Finding the correct sparkplug for hhd3500 hyundai generator
Sparkplug for coleman generator, model
# should be on the old plug if not you should be able to match it physically at any hardware store or you can google the model number of the generator and find it.
Jul 26, 2016 | Coleman Electrical Supplies
Where can i get spare parts for a hyundai hy3000si generator [ie] voltage regulator
voltage output readings are governed by rpms of the motor
check that the engine rpms are correct by adjusting the governor setting
contact hyundai generator service center for parts
Jul 23, 2016 | Electrical Supplies
Hyundai 3500 generator carb adjustment
Go to the Hyundai website and ask for the user's manual.. They should have it as a download!
Dec 24, 2012 | Hyundai HHD3500 3500-Watt 4-Stoke Portable...
Changing plugs , is there any parts that have to be removed before you take plug sout?
Sometimes a plastic cover needs to be removed. Otherwise it's just unplugging the sparkplug caps and insert the sparkplug tool to loosen the sparkplug. Make sure nothing falls into the open sparkplug hole once it's out.
Jun 30, 2011 | Hyundai Accent Cars & Trucks
Yg2800i generator runs for about 5 minutes and then stalls
Put a new fuel filter on it and when it stalls take the fuel line off the carburetor to check if gas is getting to the carburetor. If it is remove the sparkplug put the wire on it and ground the nut of the plug on the engine block and pull the cord and check for spark between the sparkplug gap. If no spark you might have a faulty coil, when it gets hot it has no spark.
Mar 20, 2011 | Yamaha 2500 Watt Industrial Inverter...
Coleman sport 1850 powermate generator, no fire to sparkplug
is there an oilprotection on the gen. disconnect the cable and try again
Jan 18, 2010 | Coleman Sport 1850 Generator
My moped looses power and the exhaust gets very very hot.keeway hurricane
Is it a 2 stroke? if so, 1st make sure your gas/oil ratio is correct. 2nd make sure you have the correct sparkplug.... and 3rd... sorry to say.... you may be close to a piston and/or ring seizure. The loss of power and extra heat generation is probably coming from friction between a worn cylinder and the piston/ring.
Jan 03, 2010 | 2001 Suzuki DR-Z 250
Sparkplug replacement coleman 1850 generator
John if you pull the old plug out the plug number will be on the plug itself it will ahve the manufacture number and manufacture name. Otherwise take it to any parts store and they can match it. Nappa Auto parts will carry it for sure. Be sure to ask them what the gap is on it they will have in in the book but will be .0035 IN. I believe. Be sure to gap it as they are supposed to be gapped alread but some are not even close. Also Nappa will have the reference guide for the briggs and stratton engine but are a real common plug.
Oct 08, 2009 | Electrical Supplies
I Have a pro force 6000 that has no spark at the
First check and see if you have any cracks on the cable then replace the sparkplug with new one but make sure that the setting the correct one…before you do this you may try a test but you must be very careful…No kids around, clear place outdoors, etc .
After checking, the cables unscrew the sparkplug and put very small amount of gas in then put back the sparkplug “the same one” and see if you get a sound as backfire if yes that mean it is working good. That should take care of it…let me know and again be very careful and not too much gas
Sep 14, 2009 | Coleman Powermate Premium Plus 6250W...
Hyundai HHD3500 Generator Logo
170 people viewed this question
Top Hyundai Electrical Supplies Experts
john h
fred_therese
Are you a Hyundai Electrical Supply Expert? Answer questions, earn points and help others
