Question about Spin Master Flutterbye Flying Fairy Doll 25246421
Flutter bye won't spin
Can't get fairy to spin
I'd like to catch a fairy
first you have to buy a fairy net and some fairy dust, be very good and have a proper fairy house so they will be at home
Jun 06, 2017 | Computers & Internet
How to turn into a fairy
This is too easy...just hang around San Francisco or West Hollywood. You'll be a fairy in no time! Or visit a costume shop and ask to see the fairy costumes.
Jul 06, 2014 | Computers & Internet
My fairy just spins on the base and I have lost the instructions,please can you help
The defect with this toy is cheap design. What is happening is the weights at the waist are support to spin, and lift the top set wings. This causes it to take off. There is a little plastic piece inside shaped like an 8. One side of the 8 is attached to a small round ball attached to the weights (the round ball snaps into the top loop of the 8) and the other side of the 8 is attached to a plastic ball to the top wings. When off the weights hang down and so do the wings. When it starts the weights spin (lifting up) and they are suppose to lift the wings, since there attached to each other. Since the fairy has some violent crashes, the plastic 8 attachment dislodges off one of the other or both. I found on my daughters fairy both were snapped off and the small plastic 8 was laying in the waist. I reattached them and it worked fine for about 5 minutes and it came off again. Now we have lost the 8 piece and out of luck. To try and fix yourself. You can twist off the legs (just turn counter clockwise while pulling lightly). Once the legs are off lift the head off. A stem is attached with a washer, don't lose the washer. Look inside the waist and you will see the little plastic balls hanging off the side of the weights and wings. To fix just snap the 8 piece over the round balls. Probably won't last long because the plastic is already damaged some what and will come off easier each time it reattached. You will need a very small screwdriver to reach down to snap on or dental tools.
Jan 27, 2014 | Spin Master Flutterbye Flying Fairy Doll...
My flutterbye fairy doesnt fly
Jan 14, 2014 | Spin Master Flutterbye Flying Fairy Doll...
Flutterbye fairy is not flying, the wings are spinning but not strong enough to lift her, she is completely charged
Mine is doing the same thing ! Look to see the upper rotors are flying even with each other mine are not ... One seems to be spinning higher . I'm thinking that's my issue
Sep 22, 2013 | Cars & Trucks
1997 Nissan Maxima - won't start; engine doesn't turn over; I hear only a "click" sound; Checked the battery - It's good, took the starter up to Pep Boys and checked - it rocks, just...
This sounds SO-O-O-O familiar! There are all kinds of variables here.
First, why was the alternator replaced? Did anyone ever perform a charging sytem test on the vehicle before making this decision?
If the alternator was in fact bad, it is VERY COMMON for a shorted cell in a battery to be the CAUSE of the alternator going out. Has the battery been PROPERLY tested?
Then I have a serious problem with taking the starter off of the car to have it "checked". What is anybody going to do with the starter off of the vehicle? Put some battery power to it and see if it spins? Just because it spins on a "bench test" does NOT mean that it is good, or that it has enough power to actually turn an engine over.
You probably only have something really simple like a bad battery cable causing this whole thing!
Please review the following articles:
My Car Won't Turn Over
What Else Could Be Wrong?
Oct 30, 2011 | 1997 Nissan Maxima
Spin cycle
its sounds to me that the bearings are going, it would show more in the fast spin Close Ireland bye bye
Nov 21, 2007 | Frigidaire GLTF1670A Front Load Washer
Spin Master Flutterbye Flying Fairy Doll 25246421 Logo
51 people viewed this question
Top Spin Master Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Spin Master Toy Expert? Answer questions, earn points and help others
