Question about Air Purifiers
Life expectancy Bone cancer of the spine is now working its way up the spine and is in the hip. She is extremely nauseous and unable to eat
What is the life expectancy of aboriginals in australia
Posted on May 25, 2014
Does it really purify,drain and restore your entire lymphatic system?
nothing does that
if it was possible then there would be no cancers in the lymphatic nodes and cancer would be obsolete as all that would have to done is to drain the nodes
just good but deceptive advertising
Oct 25, 2015 | Air Purifiers
Life expectancy
Needs very frequently give maintenance
Nov 06, 2013 | Air Purifiers
I have a Flair air puifier but no ozone smell. I replaced the high voltage transformer( it was a 3500 watt instead of a 5000 watt transformer) The red light now flickers but no ozone smell . It has ne
Your ozone generator may have gone bad. It's the small black rectangular looking apparatus located near the bottom of the unit. It usually has a zip tie holding it to the circuit board. You will have to take the Flair out of it's case to see it. Make sure it's unplugged and remove the bolt from the bottom of the unit. You can then slide the framework out of the casing. It's also possible that it's time to replace your Ceramic Ozone Plates. They have a life expectancy of 2 to 4 years. The Flair has two of them that slide into slots in the rear of the unit. You can see them when you remove the washable filter. All items can be purchased on Ebay. DM
Apr 28, 2012 | Ecoquest Flair Air Purifier
I had a honeywell hepa air purifier 50250 given to me as a gift with no owners manual! Is there somewhere I can get one? also, there is buttons on the top, one saying check filter and the other saying pre...
http://www.honeywellpurifiers.com/ssi/pdf/honeywell/50100-200-300-manual.pdf
The Intelli-Check™ Filter Monitors will indicate replacement of the pre-filter and the
HEPA filter. Depending upon your individual usage (environment and hours used),
you may need to check and replace the filters more or less frequently.
To check Expected Filter Life Usage
When the unit is turned on, quickly press the appropriate filter monitor button. The
pre-filter light will flash up to 3 times and the HEPA filter light will flash up to 4 times,
depending upon how much expected filter life has been used.
PREFILTER:
1 flash = from new, up to 1/3 expected life used up
2 flashes = between 1/3 and 2/3 expected life used up
3 flashes = between 2/3 and all of expected life used up
Remains on = time to check/replace pre-filter
HEPA FILTER:
1 flash = from new, up to 1/4 expected life used up
2 flashes = between 1/4 and 1/2 expected life used up
3 flashes = between 1/2 and 3/4 expected life used up
4 flashes = between 3/4 and all of expected life used up
Remains on = time to check/replace HEPA filter
To RESET Filter Monitor
When the filter monitor light remains on, it is time to check/replace the filter and reset
the filter monitor, if needed. With the unit powered on, press and hold the appropriate
filter monitor button down for approximately 5 seconds until the light turns off.
Page 6:
Mar 29, 2011 | Kaz Honeywell Hepa Air Cleaner (50250) Air...
My Honeywell Enviracaire Hepa Air Filter machine has a squeak when it runs. I am unable to find a place to oil it. Can you help?
is no place to oil it.They have closed type motors. You can just use a lubrificant typeWD40 to spray the mouving parts
Feb 21, 2011 | Honeywell Enviracaire 13520 Air Purifier
Blue light is blinking and purfier does not work model s1871 mak3800.com
Hi mak,here is your solution...
What is happening is this: the main electrical component is overheating and forcing the machine to turn off. When it cools, the machine turns back on. Yes, that is actually what is causing the blinking.
There is no solution for this as the main electrical component (a high voltage capacitor in this case) has failed due to stress. In my case, the machine worked for 2 months before failing. The only real solution is to have the unit serviced. However, as there is no service centers, we are all out of luck.
I believe this could be a class action law suit against sharper image for selling units built with components it knew would fail after a short period of time. They had hundreds of reports with this same failure and they knew the cause. Pressing the "boost" button too much causes extreme stress on the capacitor and shortens its life drastically. This capacitor is what provides the power to the ionizing wires.
Thanks for using FixYa.
Good Luck!!!
neo
Feb 28, 2009 | Sharper Image Ionic Breeze GP SI730 Air...
BULB AND BLUE BLINKING LIGHT S1871 AND S1861
Good Luck!!!
neo
Feb 25, 2009 | Sharper Image Ionic Breeze GP SI730 Air...
How do you clean the ozone plates? By using household products.
Hi lawrsports,
I generally use household ammonia and an old toothbrush, rinsing thouroughly in clean water, and drying them thoroughly. And I do mean _thoroughly_, as-in bone-dry, use a hair dryer if in-doubt.
Putting anything wet, or even damp into a high-voltage environment is contra-indicated.
If I can be of further assistance, let me know. If this solves the issue, please rate it accordingly.
Thanks in-advance for using Fixya.com,
Jon
Dec 07, 2008 | Ecoquest Flair Air Purifier
Blinking blue light
Good Luck!!!
neo
Aug 17, 2008 | Sharper Image Ionic Breeze GP SI730 Air...
Kenmore air cleaner
I just bought the same model and also have the smell. My previous one did not so I returned the first unit and the second units smells the same. I called Sears Customer Support and they told me that it is probably due to the factory smoke test they do on each unit. He said let it run for a few days and it should dissapate. I went a step further and am trying a new filter and if this works he said call the store and they will get me a new filter.
Mar 23, 2008 | Kenmore 85250 Air Purifier
Air Purifiers Logo
520 people viewed this question
Top Air Purifiers Experts
Are you an Air Purifier Expert? Answer questions, earn points and help others
