Question about Sony Handycam CCD-TRV75 Camcorder
Error Code C:31:00 in a Sony CCD-TRV75 Handycam Camcorder
Tape will not play/record in either Power or VTR mode. After selecting "eject" tape, the tape will eject. However a new tape cannot be reloaded into the machine. The autoload feature closes part way (in towards the body of the camera), but the tape will not drop down into a usable position within the camera. Error code C:31:00 flashes rapidly in the upper right corner of the view finder along with an underlined up arrow in the display window on the left sid eof the machine.
  • Sony Master
  • 586 Answers
    This error shows that the problem is in mechanical section of the tape loading path. Please contact an expert for mechanical adjustment
 Thanks for using fixya.
Posted on May 22, 2009
Sony CCD-TVR-16 Handycam tape keeps ejecting and the problem code is c 21:00
You should remove the tape, check it is not full up, or replace it with new tape, I had this problem weeks ago, turned out the write-protect tab on tape had got pushed over to prevent recording.
May 21, 2010 | Sony Handycam CCD-TRV16 Camcorder
Tape will not run
The "will not run problem" was solved by replacing the CR-2025 Lithium battery. The eject symbol continues to appear sometimes and I can remove it and continue operating the camera by turning the power supply "Off then On" again. Camera is now running a recorded cassette but quality of picture is low.
Jan 14, 2010 | Sony Handycam CCD-TRV68 Camcorder
Sony Handycam CCD-TRV21 won't play tapes.
no that u must remove ur camera and try to clean all strip that connect with board and mechanisum and all connectors legs solder then it will work .any doubt call u.a.e no 00971503853766
Jul 04, 2009 | Sony Handycam CCD-TRV21 Camcorder
Sony ccd trv218e, recording & playing back does'nt work
I had that problem also and I found that using smaller tapes helped. I was using the 120 minute tapes, I think they may be too heavy.
Feb 13, 2009 | Sony Handycam CCD-TRV21 Camcorder
Sony Handycam CCD-TRV37 Error code C:32:20
1. I removed the battery. 2. With the power switch On position and holding the tape ejected I inserted the battery back on & it ejected the stuck tape.
Jul 24, 2008 | Sony Handycam CCD-TRV37 Camcorder
Error Code C:32:11 Tape does not eject
try removing the button cell battery, main battery, and any other power source from the camera and let it sit for one hour. THen using only the AC adaptor, see if the camera works, if it doesn't then you may have to take it to a repair shop, cause the cassette door has malfunctioned.
Mar 23, 2008 | Sony Handycam CCD-TRV37 Camcorder
Error code C:32:20
My best solution, is to pull all power sources form the camera for 24 hours. If this does not work, then take the small screws surrounding the Tape housing, in order to try and get the tape out. Best of luck dude ;)
Feb 05, 2008 | Sony Handycam CCD-TRV37 Camcorder
Sony Handycam Model CCD-V801 does NOt Play
Hai, Check with previous recorded tape, If it is not playing. Clean video head with head cleaning cassatte. Before that please check is it going to VTR mode & also is it takes play indication. Then check with pre-recorded cassatte. thank you best of luck udupi
Mar 13, 2007 | Sony Handycam CCD-TRV81 Camcorder
Tape ejects every 60 to 90 seconds regardless of the mode the camera is in
The flip up cover over the cassette housing has the "eject" button built into it. Sony has had problems with the flexible harness that connects this door to the camera body. The harness rubs against the metal frame of the camera and causes various malfunctions such as the constant eject symptom you are having. Sony service in Laredo, TX can repair this for you, it is no big deal. Good luck, this is a nice camera! Joe Weibel customelectronics.org
Feb 11, 2007 | Sony Handycam CCD-TRV87 Camcorder
Video Cameras Logo
640 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
