Question about Boating
Fuel mixture - Boating
    New Friend:
Hi there i have a 2005 .5.7 jeep cherokee the exhaust feums is verry ritch it burn yuor eyes can it be adjisted leaner a bit thanks johan
Posted on Jan 24, 2014
What is the code 171 mean on my dodge ram 1500
P0171 Chrysler - Fuel System Lean
Possible causes
- Intake air leaks
- Faulty front heated oxygen sensor
- Ignition misfiring
- Faulty fuel injectors
- Exhaust gas leaks
- Incorrect fuel pressure
- Lack of fuel
- Faulty Mass Air Flow (MAF) sensor
- Incorrect Positive Crankcase Ventilation (PCV) hose connection
Tech notes
If the P0171 is combined with the P0174 code, it's very likely that the problem is caused by an intake leak. If there are no intake leaks, the next step is to replaced the air filter and clean the air flow meter. If the problem persist the front oxygen (O2) sensor may need to be replaced.
When is the code detected?
- Fuel injection system does not operate properly.
- The amount of mixture ratio compensation is too small. (The mixture ratio is too lean.)
Possible symptoms
- Engine Light ON (or Service Engine Soon Warning Light)
- Excessive Fuel Consumption
P0171 Chrysler Description
With the Air/Fuel Mixture Ratio Self-Learning Control, the actual mixture ratio can be brought closely to the theoretical mixture ratio based on the mixture ratio feedback signal from the heated oxygen sensors 1. The Engine Control Module (ECM) calculates the necessary compensation to correct the offset between the actual and the theoretical ratios.
In case the amount of the compensation value is extremely large (The actual mixture ratio is too lean.), the ECM judges the condition as the fuel injection system malfunction and light up the Malfunction Indicator Light (MIL) (2 trip detection logic).
P0171 Chrysler Fuel System 1 1 Lean
Sep 04, 2014 | Cars & Trucks
Fuel mixture for mcculloch mt 280 strimer
Fuel mixtures can be viewed at the included links.
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
User manuals McCulloch Service
I trust this information proves beneficial.
Jan 22, 2014 | McCulloch Lawn Care: Trimmer Plus...
Adjust air fuel mixture
Hi Wentzpatrick, on the right hand side of the carburator there is an idle adjusting screw with a spring behind it, turn screw clockwise to increase idle counter clockwise to decrease idle. There is also an air/fuel mixture screw inside a carb body lug that may or may not be plugged with an aluminum cap that's about 3/16" thick. This cap can be drilled out to acess the air/fuel mixture screw. Turning screw clockwise will lean out mixture and lower idle, turning screw counter clockwise will richen mixture and raise idle. You need to balance the two adjusting screws to obtain an idle of 950-1000 RPM then back out air/fuel mixture screw 1/4 turn, snap throttle to confirm responce, you may continue to back out air/fuel mixture screw untill desired throttle responce is achieved, if you see black smoke coming out of exhaust you have gone to far and need to turn screw back in 1/8 turn at a time. Good luck.
Jul 15, 2013 | Harley Davidson XLH Sportster 883...
Mixture screw adjustment on a ford maverick 1990 how to reset it ?
turn allen 3/32 allen mixture screw for each barrel counterclock wise for leaner fuel mixture if turn mixture screw clockwise richen fuel mixture.
Jul 13, 2013 | Cars & Trucks
O2 sensor
O2 sensor monitors the air fuel ratio consistently. It makes sure that the engine receives optimum fuel mixture all the time. If the mixture will be rich, i.e. more fuel and less air, it will signal the ECU to reduce the fuel supply and if the mixture will be lean, the fuel supply will be increased.
May 08, 2013 | 2003 Cadillac Deville
Fuel mixture
Use the provided link for fuel/gas mixture.
Contact us
User manuals
McCulloch Service
McCULLOCH PARTS ACCESSORIES
I trust this information has proven beneficial.
Apr 21, 2013 | McCulloch Mcc1635a 16-inch 35cc 2-cycle...
My machine overload,what do i do.the cilinder gets oil and the sparkplug is wet
Marthadelafu:
Remove the spark plug and clean it with rubbing alcohol and let it dry or blow dry it. Look at the carburetor. You will see two small screws next to each other. Those are the fuel/air mixture screws. one controls fuel, the other controls air. First check the air filter to see if it is clogged with dirt and debris... if it is, wash it in a soap and hot water solution and let it dry. After it dries out, reinstall it. Then turn the air/fuel mixture screws in GENTLY all the way. Turn them out one and a quarter turns. Check your fuel/oil mixture to see if you have the correct ratio of oil to fuel (most machines run on a 40/1 ratio... 40 parts gas to 1 part oil in other words, 40 ounces of gas to 1 ounce of oil. If your fuel/air mixture screws are one and a quarter turns out, the fuel/oil mixture is correct and the air filter is clean, the motor should start. You will need to adjust the fuel/air mixture screws a little to get the saw running to your satisfaction.
Jan 18, 2013 | Poulan Garden
I have a 1987 gmc jimmy with a 5.7 litre fuel injection and it seems to be lack air or has to much i dnt know . and i want to know how to adjust my fuel air mixture
Unfortunately, most fuel injection engines don't have an adjustable fuel/air mixture by the technician.
The fuel/air mixture is controlled by a computer.
Jul 03, 2010 | 1987 GMC Jimmy
Fuel oil mixture
use a 32:1 mixture which is approx 4oz 2cycle oil to 1 gal of gas. you can also add an ounce or two of of a fuel sys cleaner to your fuel mixture for a good cleaning of the carb to remove any gum or varnish build up which could cause poor engine performance. hope this helps you
Aug 08, 2009 | Homelite Garden
Fuel/oil mixture
3.2 oz oil in one US gallon yields 40:1 mixture.
2.6 oz oil in one US gallon yields 50:1 mixture.
Jan 15, 2009 | Humminbird 140c Fishin' Buddy
Boating Logo
98 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
