Question about Fisher Paykel Fisher & Paykel Elba 3.7 cu ft Top-Load Washer - White
Elba washing machine wont drain or spin
Wont drain or spin
    Problem Solver:
  • 15 Answers
The pump filter is blocked ,so it wont empty,remove filter cap and clear out lint, coins etc.
Posted on Jul 11, 2014
Testimonial: "Turned out to be pump"
Elba washing machine wont advance to last spin cycle
may i advise you . TRY ANOTHER PROGRAMME CYCLE see if it does the same . pc controller faulty ie (computer board )
Feb 11, 2015 | Washing Machines
My f&p elba washing machine wont spin on rinse cycle or spin cycle?
sounds like a bad motor coupler? the connection from the tranny to the motor. its a simple but bit time consuming job to replace and only cost less than 15 bucks for one. also check for belt connections if its not a direct drive model?
Jul 25, 2014 | Fisher and Paykel Washing Machines
Wa50t54w1 elba
this can be a motor control fault, and sometimes a fault with the motor itself, test motor windings for equal resistance, and check motor physically for wear / damage. replace motor controller.
Oct 24, 2013 | Fisher and Paykel IWL12 Top Load Washer
Elba washer is not washing or spinning right...the only thing its doing is adding water
I couldn't tell if the water was draining. When you advance the cycle to spin the first thing it should do is drain the water. This will happen for a short time before it spins. If it is not draining then you need to check the drain pump for blockages( and pipes) the machine will not spin with water in it! If it is draining but not spinning then it is probably a faulty lid switch and needs replacing. There are a couple of other causes but they will usually create a fault code which you don't seem to have. Most likely blocked or faulty drain pump.
Jul 05, 2013 | Washing Machines
Elba washer wont drain
There is a a panel 10" by 5" on the front bottom right corner, carefully remove it, and with a torch look inside to see if the belt is still working and still in good condition. With the plug disconnected, remove the belt and try to turn the pump pulley by hand, if there is resistance you may have a jammed or a faulty pump. With machine going, looking through the inspection hole you may be able to see the belt trying to work.
Nov 27, 2011 | Fisher and Paykel Washing Machines
Washer wont drain. fills with water. goes through wash cycle but wont drain. once it gets to the spin cycle, it spins for a few seconds and then stops and rinse light comes back on.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 21, 2011 | GE Washing Machines
WASHING MACHINE WONT DRAIN OR SPIN
did you get a solution as i now have this problem
Jun 08, 2010 | Washing Machines
Maytag Neptune washing machine - wont drain & spin
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 21, 2010 | Maytag Neptune MAH5500B Front Load Washer
Washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
Jan 19, 2010 | Haier Washing Machines
Bosch wfd2473 washing machine wont drain or spin
I have a bosch wfd 2473 washing machine...wont drain,I have had this problem before and resolved it by removing drain/filter plug...normally a button or hair clip....but this time there are no objects blocking.I am guessing the drain pump is faulty and needs replacing...?????
Apr 05, 2009 | Bosch WFL 2063 Front Load Washer
Fisher Paykel Fisher & Paykel Elba 3.7 cu ft Top-Load Washer - White Logo
536 people viewed this question
Top Fisher Paykel Washing Machines Experts
Lawrence Oravetz
Paul P
marlin siecinski
Are you a Fisher Paykel Washing Machine Expert? Answer questions, earn points and help others
