Question about Samsung DV448AEE Electric Dryer
Samsung Overheating Push start, select setting and within a few seconds get OVERHEATING error. Lint trap was cleaned after every load, but I did a deep clean on the venting from the back of the machine to the outside of the house and there was a ton a **** in there. Ran it again - it ran for a minute then OVERHEAT error. went outside and some additional lint had blown all the way through, so I think the venting line is clear now. i am wondering if the air restriction could of caused the failure of a part - like the thermistor? and if so it is hard to replace?
    Habit-Forming:
    New Friend:
  • 25 Answers
Yes that could possible the problem
Posted on Jan 03, 2014
4 Suggested Answers
  • 1531 Answers
SOURCE: My dryer is blowing lint out through the vent
this is normal for lint to blown out the ducting because not all the lint will be collected on the lint filter when you remove the filter some lint may fall of down into the duct housing.there is nothing ot worry about
Posted on Sep 19, 2009
57 varieties
  • 1653 Answers
SOURCE: Samsung dryer DV448AEP/XAA - lint buildup
Yes this is rellatively normal as clothes are just not made the same way any more. You could turn down the drying temperature slightly and put in an anti static drying sheet but it won't make that much difference.
Posted on Oct 13, 2009
Testimonial: "I just had a repairman out because the dryer was no longer heating. The whole inside of the dryer was full of lint. It was awful. "
  • 3089 Answers
SOURCE: DV350AEP Samsung Dryer starts then stops after a few minutes
Sounds like you may need to take the whole dryer apart and check for lint build-up, or for a "worn-out "overheat thermostat switch" in the back or the bottom of the machine.
There are from 3 to 6 in most machines.
These parts, often the size of a quarter or half-dollar, usually have 2 wires hooked to them, and will shut off your dryer if it overheats (to prevent a fire).
These switches will require a testing instreument to check them.
Be blessed.
Posted on Mar 24, 2013
Dryer seems to be overheating within 3 minutes of turning on. No lint in trap or outside in the trap. What else could I check??
may want to check inside the housing, u may have had a lint build up somehow? Ur cycling thermostat or thermal cut off may be going haywire on you and u should check them with a multi-meter. for continuity. is it overheating and shutting off? If so u may have bad motor windings which will heat up rapidly then shut down the machine? but they usually will atleast let u run it about 20 minutes b4 shutting down
Dec 27, 2014 | Dryers
Wascomat dryer error codes
Check the following link: http://www.laundrynation.com/manuals/wp-content/uploads/2011/05/wascomat_dryer_selecta_control_programming_manual.pdf
On page 13 it identifies the E 08 error as overheating air (inlet or outlet). Chances are, it is the outlet that has gotten gunked up from lint or other material. Pull the vent tube off, vacuum out lint traps, clean the outlet tube, reset the machine. If the dryer is linked with other dryers on a multiple-link vent system, cleaning the vent lines may be necessary to avoid the problem.
Feb 06, 2014 | Dryers
Electric dryer runs shuts off then starts again on its own
This could be a bunch of different things. #1 detach dryer vent and clean out. Try running dryer with vent not attached for 10 seconds. (Warning, lint and sand will likely come blasting out the back. Reattach and try. #2 Likely is that you have lint buildup inside. Unplug dryer. Remove back cover. Clean air path from exhaust through lint trap. Look inside or remove heater as well. You are likely overheating the dryer and the sensor is shutting it down. #3. Unplug the heating element and then run dryer. Does it shut off still? No Then the sensor on the heating element is bad. Yes then the timer is bad.
Jan 13, 2014 | KitchenAid KEYS750LQ Electric Dryer
Solid red light
I would say the laptop is overheating. But wont be able to say without doing a few things. give the model number of the laptop so that we can get the error light info from the user guide. what happens is you leave the laptop for a while and turn is on again?
if it goes on then is is overheating and needs cleaning otherwise the could be other problems an the best would be so contact Samsung support to help trouble shoot .
Jan 03, 2014 | Samsung Computers & Internet
I have opened the back of my Hoover tumble dryer and taken out all the fluff...it is overheating all of the time and a friend suggested that the belt might be broken. I unplugged the machine and moved the...
It goes arount the motor pully and the lower side of the belt goes up and over the tension pully. Also on you overheating problem turn your dryer on with no heat and see if air is coming out of the outside vent. It should be a good volume. The next thing to check is the blower housing just follow the exhaust vent and the lint trap they will lead you to the blower wheel housing and duct to the lint trap. Remove the screws around the outside metal casing and seperate the casing exsposing the blower wheel you will find a lot of debris. Make sure the wheel is secure to the center spindle. Then make sure your hose leaving the dryer is not kinked when you push the dryer back and it is clean. Always unplug your dryer before starting on repairs and good luck..These are the most common problems
Aug 26, 2010 | Dryers
Overheating on ford bantam
there are three probable causes that may result to overheating one inadequate circulation of coolant within the cooling system. The radiator is clogged with dirt some stems are closed.try to flush the radiator using rad flushing fluid. Second improper bleeding of trap air within the cooling system. Third the water pump blades are worn out inadequate circulation of coolant.
Feb 02, 2010 | 1996 Ford Bronco
Whirlpool dryer stops drying on its own.
it sounds like its overheating. there may be lint in the vent hose or even stuck in the machine before getting to the lint trap.
Aug 17, 2009 | Whirlpool LER4634J Electric Dryer
Gets warm but not hot enough.
Occaisionally this is due to either dryer being set to a 'delicate' or 'low' setting. Most frequently it's due to an obstruction in airflow so the heating coil is cycling off to prevent overheating. The vent at the back of your dryer should be cleaned out (by sucking out the lint with a vacumn hose) at least once a year. The vent pipe out of your house as well. Make sure that the flap on the outside of your house is opening and allowing free air circulation when the dryer is on. And make sure you clean your lint trap every time you use the dryer.
May 03, 2009 | Dryers
Gas dryer - inadequate heat
Clean out your lint tray and hose. It sounds as if it is stopped up. The gas dryer automatically shuts off to prevent fires or overheating. The thermostat is probably O.K. since it will run for a few seconds each time.Let me know what you find out. Clean the lint trap first.
Jan 28, 2009 | Maytag Dryers
Samsung DV448AEE Electric Dryer Logo
412 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
