Question about Hisense TL1700 17 in. LCD Television
The smart menu keeps popping up on my hisense tv
Smart menu keeping popping up on screen
  • 113 Answers
SOURCE: picture size
You need to go into the menu and take it off of auto aspect. As long as this is on it will adjust whenever it feels like it.
Thanks
Josh
Posted on Sep 27, 2008
SOURCE: The sound keeps droping if the tv signal is not full strenth Hisense 19in
i have sound but black screen , no picture
Posted on Dec 20, 2011
gopakumarg43
  • 74473 Answers
SOURCE: our 40' hisense tv keeps blinking sometimes it goes for an hour or two without and sometimes it blinks continuously
Hello
You haven't given the exact model number to your Hisense TV here. Yet, i posts this solution, as this is a common problems to all TV, irrespective of Brrand and model.
Check its power supply regulator board, for any loose solder points. Resolder all the suspected solder terminals to this board, by applying a little more solder, without making any solder bridge short in between adjecent solder terminals. You have to take the board out from the TV to do this job.
Reset it and see whether it helps you. If not, power retgulator board must be replaced as card basis. OK.
Posted on Feb 15, 2012
SD Tech
  • 14553 Answers
SOURCE: red light on my hisense tv keep blinking and the tv wont come on
I see so many here with no sound/nopicture issues:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.
Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have to buyand try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.If set is opened at least look for puffed up and bad caps like in thisphoto.6_2_2012_2_03_27_pm.jpg6_2_2012_2_03_55_pm.jpg
If any or all of this information is beyond you then consider the set is in shutdown as something is wrong===likely in the power supply of the set which is where most of these problems happen.
Posted on Jun 02, 2012
  • 16 Answers
SOURCE: hisense tv menu options blocked
go into setup then function then enable startup menu switch set off (completely off with poer switch turn back on then select normal mode not demo or hotel at startup.
Posted on Apr 21, 2013
Samsung smart tv. Menu bar on power right corner occasionally pops up. It doesnt work so I cant get rid of it except to unplugged it. What makes it come on?vwill it huurt anything?
hi don't keep unplugging your tv it will do damage, look in the menu on the tv for osd setting, look for the lowest setting thanks
shaun
Jun 12, 2017 | Samsung Televison & Video
Security warning keeps popping up
Check for security settings in tv menu
Apr 13, 2014 | Sharp Televison & Video
Menu Keeps Popping Up
There is either a short in the menu button on the TV or it is sticking/dirty.
Jan 30, 2014 | Vizio 60" E601I-A3 Full HD LED-LCD TV
Crt monitor turned orange and the monitor menu keeps popping up
probably its old or try to check the color status in display property in desktop properties
Apr 21, 2010 | SAMTRON 55V 15" CRT Monitor
Menu Screen Keeps Coming up on the screen
The most commom causes are One. There ia a stuck button on the tv itself. The Menu button. The membrane switch or the TACT switch is bad and needs to be replaced. The Main bd can also be bad.
Jul 16, 2009 | Philips 42PF9630A 42 in. Plasma Television
Menu screen keeps popping on and off during usage
Check the menu button on your monitor. Chances are it is stuck in the depressed position. (Sometimes an edge of the button will get caught beneath the frame.)
Jun 01, 2009 | Dell E157FP Monitor
My LCD tv's menu screen keeps popping up and won't stop.
Since it is brand new then should be OK.
Please return it to store and get another TV.
Feb 24, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
LCD Main MEnu
hi,
It is possible that menu button on the monitor is stuck. I suggest to call your computer manufacturer where you purchased the monitor, check for the warranty and request for a replacement.
Keep me posted.
Thanks
Dec 03, 2008 | Dell E173FP 17" LCD Monitor
Hisense TL1700 17 in. LCD Television Logo
2,451 people viewed this question
Top Hisense Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Electro Med Services...
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
