Question about Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin
Front handle broken
My front handle snapped off. Where can I get a new handle?
    Problem Solver:
  • 6 Answers
All you have to do is go to the web site and order a new one go to a true value or just look online for poulan parts
Posted on May 22, 2009
Hotpoint wf865 handle has snapped off
get a new part and replace it
this is only broken as you do not wait for the door to unlock
Apr 23, 2014 | Hotpoint Ultima WF865 Front Load Washer
Door handle broke
can you open from the inside, its the only way you going to get to sort this, failing that you may need to get a new door card and rip the one off the door at the top corner near to the lock latch and split the plastic and pull the door pin inside to open then take the door card off. sometimes you can do it with out braking the door card but would not say it will not brake. inside there is a plastic clip that the handle go's on then another bar to the lock. this is designed to snap if some one trys to open the door with force.failing that the handle part can snap where the bar fits to it. that you would need to change the handle.
Dec 06, 2013 | Land Rover Cars & Trucks
We broke the door handle on our Malber 1000 Can we order a new one and can we fix it ourselves?
Mike, in Washington D.C., again. Of course you can do it yourself. First call Joel (Malber in NY) at 800-600-8913 or 516-294-6660 . Tell him which model machine you need a door latch for (if you aren't sure, check label in rear). Once you've received your new latch assy (about $20): Open door, and notice white plastic "ring" around glass is actually 2 pieces (front and rear) snapped together - with a seam around periphery. Unsnap (separate) them by either getting your fingernails into the seam and pulling them apart - or prying them open with a spackle knife or thin screwdriver blade. Once it starts coming apart, just work the opening all the way around. Remove front "ring" and set aside. Using a 1.5mm Torx screwdriver, remove 2 small screws holding broken latch assy. Note the way the ends of the spring go under the 2 screws. That's the way it has to go back. Slip new latch assy into place, pressing vertical "hinge pin" and ends of spring into slots (near screw holes). Replace 2 screws. Test latch with door open - is it working? Try closing door. All good? Replace front "ring": Open door and, while pulling out on latch handle, slip the ring over the latch handle and get it into approximate position. Let go of latch (it snaps into "closed" position) and adjust ring so it doesn't bind the latch handle (meaning it's free to move). Now, beginning anywhere on outside edge, begin snapping rings together - and continue all the way around. Test that door latch still operates smoothly and that door latches shut properly. FYI: There is no adjustment for this latch assy - it just fits precisely where it's supposed to. Good luck and God Bless ...
Sep 26, 2010 | Malber WD1000 Front Load Washer/Dryer
Door handle broke off
bru the front internal cover snaps off. you need to stick a screw driver in the edges and pry it apart being very careful to not snap it or bend the outta metal frame undo the handles screws and replace as before but in reverse
good luck
Jul 12, 2010 | Hotpoint RVM1435 Microwave Oven
When i pull bonet release,feelsvery lose and will not open bonnet,how do I adjust,??
i believe the cable snapped. check to determine if the cable is attatched to the handle. if the cable has snapped there , use pliers to pull the cable. if its broken further up the line, you'll have to get under the front and try to release the latch. you may also be able to access the latch from the grill
Feb 24, 2010 | 2009 Audi A3
I have a C5 2.0HDI Tourer Exclusive and in the recent freezing weather I have inable to open both the front doors. The remote key in the lock both unlock all the doors but when the front door handles are...
I would say the mechanism is frozen, there is a chance that if you tried to open them the operating rods could snap the plastic and cease operating. Have you tried when warmed up? if still broken what area are you?
Jan 28, 2010 | 2002 Mercury Sable
Front driver door won't open from the inside only
The linkage is probably broken or snapped out of place from inside the door panel.
You'll feel that the handle is much easier to move than the other doors.
If you are confident and able, take the door apart removing the screws and snap pieces and look for the missing linkage. It's usually a snap piece that holds a rod in place on the back of the handle. They break all the time, or dry rot, or jarr out of place. They're easily available at your local auto parts place or even dealership for just a few bucks!
Jul 30, 2009 | Ford Fusion Cars & Trucks
Both door handles in the interior have broken off, it is amanual door lock. This is a 1999 Toyota Corolla
Get two new handles.
Unscrew the phillips screw located in the center of the handles. Slide the handle assembly backwards and out. Unclip the clip that holds on the metal lock-rod (needle nose pliers helps with that), and remove the lock rod. Fit the rod into the new handle's clip, and snap the clip into place on the new handle. Slide the front end into the door cavity, and then the back side. Reinsert the phillips screw. Very easy to do.
Thnaks for choosing FixYa for advice!
Mar 12, 2009 | 1999 Toyota Corolla
Microwave handle replacement
How to replace handle on GE Advantium SCA1001DSS.
Remove two screws on top at front in order to remove plastic front vent grill. Then the door lifts off pin hinges. Lay door flat on surface. Plastic trim snaps off with gentle prying (start at bottom middle and bottom hinge side). Then remove six screws holding notched metal section with door latch. This piece will also snap out (several visible clips holding it around edges). Then remove door handle screws, Replace handle and reverse process to put back together.
Jul 29, 2008 | Microwave Ovens
Broken front door
you need to buy a new 'handle'. to open the door for the time being, disconnect power and then use a coat hangar to pull the latch towards you, ie. outwards
Jan 29, 2008 | Washing Machines
Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin Logo
94 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
