Question about Apple MacBook Air
Hi, can you please help me?I have an icon stuck on my mac book air desktop. I moved the file into a folder on the desktop but the icon has duplicated an stayed put. My mac won't restart or shut down.
I can't view anything else without this icon sitting on top of the document or desktop. It is just there all the time. I tried to shut down the computer but it won't do it. Any ideas?
thehumble1
  • 137 Answers
SOURCE: Powerbook G4 wont start up, shows a file folder with a ? mark....
The hard drive is probably on it's way out. You can get and run Disk Warrior and you could repair permissions and such but the hard drive is probably on it's way to the grave.
A couple things though. It isn't enough to just put the disk in, you need to hold down "c" while the computer starts for it to try to run off your disk. You can then try to repair permissions and fix the disk from the installation program that starts. When the Install OS X screen comes up (looks like a desktop but with the big dialog box in the middle) click on Utilities at the top and then on Disk Utility. HERE IS APPLE'S SITE for you to read about how to try to repair your disk. I've found that this sometimes works and may help it work enough for you to get your files off, but may not.
Another method would be to get another Mac, and hook the two together with a firewire to transfer your files, then reinstall OS X in your ailing computer. Go HERE to read about this technique.
Posted on Feb 26, 2009
robert654
SOURCE: mac book will not turn on.
http://www.ifixit.com/Guide try this location for a guide
re-set your pmu 1. disconnect battery and power supply 2. hold down start button for 5-6 seconds 3. re-connect battery and power supply try to start if nothing might be your dc-in board/ has failed good luck
Posted on Apr 01, 2009
JSEhandyman
  • 368 Answers
SOURCE: macbook wont start
hi bobbie,
The only reason to pull the battery is to reset the SMU (used to be called the PMU). Do this when it's unplugged and completely un-powered, hold down the Start button for at least 5-7 seconds (count slowly) and then re-energize (battery and AC usually).
Also try zapping the PRAM (restart, holding down Command/Apple, Alt/Option, "P" + "R" (all four at once) and repeat until you hear start-up chimes at least 3 times. These may not fix it, but won't hurt.
The flashing question mark indicates that it's not finding the OS on the hard drive. In my experience, this usually means a re-install of the OS. If it's still doing this after the first two step above, dig out your install DVDs and get started.
Starting with the alt (option) button should put you into the Boot Manager. The password should typically be the the password for your (hopefully Admin-enabled) user account. Did you set the Master Password in the System Preferences? If so, you're back to erasing/starting over. If you use powerful features like this, select passwords you can remember, or write them down and store them securely (NOT a Post-It™ taped to the bottom of the MacBook or penciled in on the bezel - yes, I've seen both).
If I can be of further assistance, or if you have questions about any of my response(s), please let me know before rating me.
If this solves the issue, please rate it accordingly. My goal is to earn a "FixYa" rating from everyone I help.
Thanks for using Fixya.com,
Jon
Posted on Apr 04, 2009
  • 53 Answers
SOURCE: macbook was manually shut down during an update
while starting, hit cmd v. this will put it into verbose mode and show the background processes and where it stops, there will be your problem. Also try inserting an OS disk and hitting c during startup chime and use the disk utility to fix the permissions.
Posted on Jun 04, 2009
damien729
  • 221 Answers
SOURCE: Blinking file folder with question mark and a DVD is stuck in it
Hello, The blinking file folder with the question mark can happen when the computer doesn't "see" your System. It can be caused by a faulty hard drive, or by a damaged operating system. You can try to reboot the mac, hold the mouse button during 20 seconds to eject the CD, then insert you installation DVD (leopard). Reboot the Mac again, and hold the "C" key. Select english, the go to the tools menu, and Disk Utility. Go to the SOS tab, select your drive and click "repair". If something red appears, it means that it has found something wrong on your hard drive. Best regards
Posted on Jun 10, 2009
How to free up space so that In can update software on MacBook Air
Start with photos and music files: if there are duplicates - make SURE they are exact duplicates (name/file size/R click-quicklook). You can get an external hard drive cheaply (http://www.amazon.com/s/ref=nb_sb_ss_c_0_19?url=search-alias%3Daps&field-keywords=external+hard+drive&sprefix=external+hard+drive%2Caps%2C166) and move important info. If you are unsure of your knowledge - ask friends!
May 01, 2016 | Computers & Internet
Tip
How to Find Epson Printer Drivers on Mac OS X
If you're using the Epson printer with the Mac OS X to print documents for your office, you may require accessing the Epson printer drivers; thus you can back them up for security purposes or copying them to another Mac Book. The printer drivers are usually saved in the sub-folder under the Library folder of the home directory of your Mac. The Library folder is protected and hidden from ordinary users in the new Mac OS X, so you will require pressing a keyboard command to check the printer driver files.
Note: - You can also get the Epson driver support services to seek help in finding the driver files on a Mac operating system.
Know How to Find the Epson Printer Drivers on Mac OS X
To locate the position where your Epson printer drivers are stored on your Mac OS X, you must follow these steps:
1.Click on the 'Finder' icon on your Mac's Dock. Otherwise, click anywhere on the desktop of your Mac Book to move to the Finder.
2.On your Mac's keyboard, press and hold the 'Option' key when you click the 'Go' button from the 'Finder' menu.
3.Click the 'Library' option to launch the Library folder. Next, double-click on the 'Printers' folder to get access the Epson printer drivers.
Note that the information listed here is applied to the Max OS X10.8 operating system, yet, it can be somewhat different with other versions or Mac Book. If you came across any the technological problems when you install or update the drivers or configuring your Epson printer, you can directly speak with the technicians and address your queries by calling on the Epson printer customer support number to solve out all questionnaires in no time.
Epson Printer Tech Support Phone Number Epson Driver Support
on May 01, 2017 | Epson Office Equipment & Supplies
How to fix a slow Mac? My MacBook is getting slow recently, how to speed up it?
there are many reasons about why your Mac works slowly. you should firstly clean it up. here is article which talks about how to speed a Mac you may need: 11 Methods to Speed up Your Mac
Jun 25, 2015 | Apple MacBook Air
MacBook Help
To create a new folder on the desktop right-click on the mouse and select New Folder from the drop-down menu.
If you do not have a mouse connected, press the control key while clicking the desktop background, and select New Folder from the drop-down menu. The folder should appear near the area of the desktop you clicked with 'untitled folder' highlighted in light blue. You can now type a name for your new folder. Press return/enter when you are done naming your folder.
Apr 29, 2013 | Apple Macbook Air 11.6" Laptop Mc505ll/a...
Duplicate file searcher
The software that I have used and recommend compares every important factor that you will need to make the right decision when dealing with duplicates. It finds duplicate songs, emails, files, and more easily on your computer by using a 'Wizard' function for the most common duplicate files and folder finding tasks. It has great customer support, and is the most thorough out of all of the programs that I have tested.
Feb 27, 2013 | Computers & Internet
Empty desktop
I am taking it that you are running OS X 10.5-6.
Go to your hard drive then go into users open up your home folder (it will have a house icon on it) then go into library then preferences find the following files and move them to the trash
com.apple.finder.plist
com.apple.desktop.plist
Then restart your mac that should fix it.
Hope it helps.
Nov 22, 2011 | Apple iMac Z0CY Desktop
I tried moving my word application to my desktop and now when I go to open it a error comes up that says that there was a problem opening word and it tells me to reinstall the program. I put in my office...
That's actually a normal problem. You don't need to reinstall Office Mac 2008. What you need to do is to put the the Microsoft Word icon from your Desktop back to Applications Folder. To create a shortcut on your Desktop, go to Applications folder, Right Click(Ctrl+Click) on Microsoft Word then choose Make Alias. Just drag the Microsoft Word Alias to your Desktop. From Desktop you will have Word as a shorcut icon without any problem. If the issue will not be resolved then you need to uninstall then reinstall Office. Here's the steps:
] > Macintosh HD\Applications
* Remove Microsoft Office 2008
] > Macintosh HD\Users\<username>\Library\Application Support\Microsoft
* remove folder called Microsoft
] > Macintosh HD\Users\<username>\Library\Caches
* remove all Microsoft related files
* remove Microsoft Folder
] > Macintosh HD\Users\<username>\Library\Preferences
* remove all the (com.microsoft.[....].plist files)
* remove Microsoft folder
] > Macintosh HD\Library\Receipts\Remove all Office 2008.pkg files
] > Delete Microsoft Office shortcuts from Dock
] > Restart
] > Install Office 2008
> Manual Install Updates
I hope this Helps! :)
Nov 25, 2010 | Microsoft Office 2008 for Mac: Mac
Hi, My 1T WD Drive will not show my files. The "my book" yellow icon shows up on my desktop and once I click upon it, it shows that I have 25 folders in the contents label but the folder does not show any...
Maybe your files are'hidden' ??! Enable to view hidden files by:
  1. Right-click the "Start" button, then select "Control Panel".
  2. Go to "Appearance and Personalization", then select "File Explorer Options".
  3. Click the "View" tab.
  4. Scroll down a bit and change the "Hidden files and folders" setting to "Show hidden files, folders, and drives".
Feb 02, 2018 | Western Digital My Book Home Edition 500...
Why does my icon disappears on mac
make an alias of the appropriate program or work folder by single clicking on the application or folder going to the file menu and selecting "make alias" then you can drag the alias (shows up italics) to your desktop. Hope this helps
Nov 05, 2009 | Apple Mac OS X 10.4 Tiger for Mac
Need to remove duplicate files
Hello rvpooley
My name is Billy.
PC Junktion is dedicated to finding solutions to those pesky computer problems.
Since you know what kind of files your are searching for, In XP, Windows Search Companion makes it easy to find duplicate files with the file search utility.
There are also many fine and free programs for accomplishing this mechanical feat. Let's first look at the Window's utility.
Create a Folder on My Desktop by right clicking and select new folder. Name this folder "Mixed up files" or something you can remember. It will be on your desktop.
GOTO->START->(menu pops up)->Click Search(magnigfying glass icon)->All Files and Folders->
Stop and take this in.
Text files will end in .txt, word docs end in .doc or (2007) .docx
picture files will most likely be .jpg, .bmp, .gif, or .png.
NOW:
We are going to use a wildcard search. An asterisk(*) represents the filename ina wildcard search.
For example in the [All or part of the filename] Box, we can search for ALL files of that flavor.
Type these wildcards in the first box exactly or copy and paste.
*.txt; *.jpg; *.gif; *.bmp; *.png;
LOOK IN: Drop Down Box-> CLICK->My Computer
Click Search. Be patient, there may be more than you know of...
Wait for the utility to finish.
GOTO Edit in the Toolbar and choose Select All. Move to the folder you created in My documents.
You know have them in one folder (on your Desktop) and now I will find a utility to handle the job.
You may want to back up to a DVD or CD in case of a crash.
I will be back tomorrow.
Hope this helps for now.
Billy
PC Junktion
Apr 02, 2009 | Computers & Internet
Apple MacBook Air Logo
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
