Lennox gas furnace said warning code 35 and no heat
SOURCE: lennox 80 ugh furnace turns on, ignites gas and shuts off in 2-3
I can appreciate in the fact that you do not want to offer a solution to my problem without paying money however you would like me to tell you how I fixed my problem for free, if you would like to know how I fixed it, how about you subscribe to my premium plan and I will tell you.
signed,
Not impressed
Posted on Nov 24, 2008
SOURCE: Lennox Gas Frunace fires goes out, fires goes out, fires goes out
furnace was working fine until the electricity went out for 5 hours now furnace is just humming and then nothing...HELP...
Posted on Dec 29, 2008
machtcl1
  • 61 Answers
SOURCE: Furnace will not heat.
Most of the Lennox G-16s that I have repaired were having problems with the gray Penn-Johnson Piggyback igniton control module.
This is best repaired by replacing the spark module. Sometimes it may be neccesary to replace the gas valve also. Lennox updated to a ROBERTSHAW ignition system. Honeywell can also be used.
Also check that there is no water in the pressure switch or tube.
Hope this helps.
Matt
machtcl1@verizon.net
Posted on Jan 15, 2009
james3751
  • 614 Answers
SOURCE: How do I clean a flame sensor on a 1993 Lennox
You can sand the flame sensor but it sounds like another problem. Sounds like a limit switch or something in the control circuit, You need to have a service tech look at this. Ask for free estimate on repair. I have worked on hundreds of these units and they are sometimes tricky to work on. Lenox has come up with new controls for the whisper heat furnace to replace the old ones. If the flame sensor is bad the unit will try to light a few times and lock out and you ahve to kull power to the furnace to reset. If this is whats happening clean the sensor nd you should be ok If not you need help from a service tech.Rus
Posted on Nov 11, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: lennox diplomat furnace will not always ignite.
Maybe, look for bad wiring connections and retighten the ground wires from circuit board to cabinet. Take a can of air and clean the burner tubes being careful not to blow on the igniter. Are ther any error codes blinking when it does not light? Read on for some more tips.
On a call for heat, the 24 volt thermostat sends a signal to the control module. The control module will indicate a call for heat with a light on the control either blinking or remain solid depending upon model. The inducer (exhaust) blower will purge all gasses from the furnace and pressurize a pressure switch. Once the pressure switch tells the module to continue, the electronic ignition will energize and send 120 volts to the igniter. The igniter will glow and you will be able to see it if viewed thru the small inspection port. Once the igniter gets hot enough, it sends a signal to the module opening up the gas valve (24 volts). Either a pilot will come on or the burner tube will ignite then spread the flame to all burners. Lastly a safety sensor will be looking for a certain temperature within a few seconds and the furnace will continue to operate and the room air blower will turn on in a minute or two.
What could go wrong? The unit will not run if there is no signal from the thermostat (bad thermostat or broken wire), the control module does not sense a signal from the thermostat (bad control), the inducer does not energize (bad motor), the pressure switch does not close (blocked vent piping, bad switch, plugged condensate hose), the igniter does not energize (bad control, bad igniter), the gas valve does not open or there is no gas (bad gas valve, broken wire, no gas), the pilot does not light (dirty pilot), the burner does not light (bad burner, plugged orifice, not enough combustion air), the flame does not spread to each burner (bad flame spreader, dirty flame spreader, more bad burners), the flame safety sensor does not detect flame (dirty or bad flame spreader, bad flame sensor, broken wire, bad control), or the room air blower does not energize (bad fan motor, bad control).
Posted on Dec 29, 2009
5 u code is on how to fix it
Gas furnace fault or error codes for common furnaces - Gray ...
www.grayfurnaceman.com/-ifc-failure-codes.html
Here are error codes found on many York, Trane, Luxaire, Lennox, Carrier, ... If younotice 5 red colored flashes on your York Furnace, it signifies that your
Oct 03, 2015 | Cars & Trucks
Is 32c a normal temp for an exhaust on a force air high efficiency house furnace? This is the air temp that goes outside after heating the plenum. Is there a lot of heat going up the "chimney"??
Any furnace providing heat where it should and has little to no heat from its exhaust is doing a GREAT job ;-)
Our high efficiency gas furnace was installed with a PVC pipe as a 'chimney' which bothered me to no end until I found the surface temp of that plastic pipe only barely warm to the touch- that is a home run!
Jan 09, 2015 | Emerson Lennox Ducane Armstrong Furnace...
Lennox codes
I have a gas Lennox elite furnace & code light is not turning on
Jan 13, 2014 | Heating & Cooling
Furnace computer won't let furnace light
What is the model number? I have an SLP98 (installed on 11/29/2011).... and if I take the cover off the front of the furnace the panel that has the fancy "Lennox" badge on it) you will see two clear round windows about the size of a half dollar (one high on the furnace box and one lower on the blower box.) If you look downward into the window on the blower box you can see a red LED display that will sometimes flash error codes like E228 (one character at a time). If your model has something like this, let me know. I've done some DIY fixes recently out of necessity....and their easy.....and several technicians confessed they didn't know much, if anything, about the newer high effieciency Lennox gas furnaces.
Mar 01, 2013 | Lennox Heating & Cooling
I have a lennox 2 stage gas furnace and a lennox XP15 heat pump controlled through the Lennox 7000 touchscreen thermostat. I want to disable the heat pump due to excessive noise due to lower temperature...
At tstat press options. Press installer setup. Yes, you are qualified. System settings, non heat pump. Gas/ oil heat. Save changes. That should do it with no wiring changes.
Jun 18, 2017 | Heating & Cooling
Hope this helps.
Matt
Jan 13, 2009 | Honeywell Electronic Programmable...
Check your thermostat anticipator setting. If you dont know how to do this don't try on your own or you may damage your thermostat.
Dec 12, 2008 | Honeywell Electronic Programmable...
Heating & Cooling Logo
163 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
