Question about Garden
What should the gap be for the magneto on a Honda hru194
2 Suggested Answers
  • 4 Answers
SOURCE: Ryobi chainsaw magneto gap
The gap needs to be as narrow as possible without any actual rubbing of the rotor against the magneto. The spacing is not as critical as with spark plugs or points (remember them?) since unlike those gaps there is no spark jumping across this gap.
Generally, as long as the magnetic field is strong enough, the magneto will produce the necessary spark at the spark plug. The closer the magnets are to the coil, the stronger the magnetic field will be across the coil, and therefore the stronger and hotter the spark.
I have replaced magnetos and they are simple to install, and almost impossible to mess up if you do it this way. All you need is a piece of thin cardboard (not corrugated). I use a glossy business card without raised lettering (so it slides easily), or the like.
1) Rotate the flywheel so that the magnets are NOT positioned in front of the magneto, then loosen both screws of the magneto so it can move freely.
2) Insert the business card between the magneto and the flywheel such that the glossy side of the business card faces the rotor.
3) Then BEND the business card back over each side of the magneto (in other words away from the flywheel) so it stays fixed and can not move from side to side when you rotate the rotor.
4) Then while pinching the magneto and ends of the business card tight between your fingers, rotate the flywheel to position the magnets directly in line with the two sides of the magneto.
Note: The magnets will grab the magneto and try to move it. As long as the slippery side of the business card is facing the rotor and you haven't removed the screws, it should move fairly easily.
Since the magnets want to pull tight to the magneto, but the business card thickness is the same across the entire surface, this gives you an even spacing between both sides of the magneto and the rotor. Essentially, the magnets on the rotor do all the work for you. with regard to alignment. As long as the magnets (flat shiny polished square surfaces on the outer rim of the rotor) align directly with the two faces of the magneto, the alignment is automatic.
5) Once you have the magneto and rotor in perfect alignment, cinch down both screws in an alternating method, first just to where they start to grab, and then back and forth a few times until they are firmly tightened.
6) Now, unfold the flaps of the business card and let it move with the rotor instead. You should be able to rotate the rotor away from the magneto and the business card should slip out easily. It may stay where it was or it may slide out from the magneto - either way will work.
7) Once past the magnets, the business card should come out. You may have to move the rotor back and forth gently a few times to get it to come free. When you are done, the magneto should be in perfect alignment with the face of the rotor and the rotor should spin freely without any rubbing.
8) Confirm the above and then reassemble and go cut some trees.
Phil
Posted on Jun 01, 2010
Testimonial: "Thank-you very much, just as I suspected - had not come up with of an alternative to the feeler gauge so that was most helpful."
Generator PM0601100, Sparks are very weak, machine doesn't start
That generator has a 20HP Honda engine. If the magneto on the engine is bad then the spark level is low. To check this you need to take the cover off the engine on the side away from the generator. There should be a flywheel with a magnet built in and there is a coil that the magnet passes by. Check the gap between the coil and the magnet. IT should be very close to each other. Honda says the gap is between .008 and .016 inch depending on the model of the engine. If the gap is ok then you need to check the coil connections and resistance with a meter.
Sep 12, 2015 | Electrical Supplies
Erratic and weak spark
IF that is a small engine and has a magneto. You need to check the gap between the coil and the magnet on the flywheel. The easiest way to judge that gap is with a business card. If it fits between the two parts without effort, then it is too much gap.
Mar 31, 2015 | 5.5 HP GX160 Engine
Need magneto gap specifications between the flywheel and magneto.
I don't know the specs, but a business card inserted between the two always works for me.
Oct 12, 2014 | Garden
What is the correct gap between the magneto core and magnet?
The gap is .010. You can also use a card to gap the coil and after you tighten the coil and remove the card turn the flywheel by hand one revolution to make sure the magnet does not rub on the flywheel.
May 30, 2014 | Briggs Stratton H7159 & StrattonĀ® 5500,...
How do I get spark
Make sure the magneto is not grounded and make sure the air gap between the flywheel magnet and magneto is set to specs. If air gap is too wide, it will be difficult for the magneto to produce an efficient spark.
May 07, 2014 | Poulan PP5020AV 20 in. 50cc Gas Chainsaw
Not getting spark to plug on eagerbeaver 2014
Jeffuxum:
The magneto is probably where the problem is. You'll need to pull the cover off of the motor and check the gap between the magneto and the flywheel. If the bolts holding the magneto have vibrated loose, the gap between the magneto and the flywheel will be incorrect. While you have the motor cover off, check the wiring to make sure you don't have a short in your ignition wiring and clean the air filter. I don't remember what the gap is between the flywheel and magneto, but .010 In. sounds familiar. Both legs of the magneto should be the same distance from the flywheel and they must not touch the flywheel at any point. I have used a matchbook cover between the flywheel and magneto while I tightened the magneto retention screws and it worked.
Jan 18, 2013 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Pb-460 no spark
u could have a bad magneto, or u may need to check the gap on the magneto and the gap on your plug. pull plug and insert plug into wire and rest on top of head an pull starter to see if u get spark. if not, u need to check your magnetos gap.
Nov 04, 2012 | Echo Pb403 Pb413 Pb460 Pb4600 Carburetor...
Lawnboy gold series 10400, sn 4906038, failure to fire. Possible bad magneto. Looking for replacement part and magneto settings; i.e., gap between flywheel and the magneto. Any other tips appreciated.
You should be able to get a new magneto at any local lawnmower repair shop. The proper gap can be achieved using a standard business card. When you get the new mqagneto, turn the magnets on the flywheel to the opposite side away from the magneto, replace the magneto pulling it all the way back away from the flywheel and "snug" 1 or both of the mounting screws.
Now, turn the flywheel magnet to where it is centered under the magneto, insert the business card between the flywheel and magneto and loosen the screw you tightened earlier. Magneto will pull down tight to the magnet. Tighten both screws then rotate the flywheel to remove the business card
Sep 22, 2009 | Garden
Honda 501 no spark, how do i fix?
You need to check the contact, (right next to the magneto:) and then if that fails, check the magneto.
If it's old, or worn, it will not be producing the correct charge.
Then you will have to play with the timing adjustment.
Either on the spark plug, or the contact and magneto gap.
That should do it ;)
Remember to rate, thanks.
Jul 30, 2009 | Garden
My XR 1991 250r is just not kicking over,there is a very weak spark there,could the coil be faulty ?
no, the coil works or it don't work. Take a look at the magneto, check your gap on the spark plug, and check the magneto and see if it is rusted. Your spark plug wire might also be cracked.
Jun 30, 2009 | 1991 Honda XR 250 R
Garden Logo
26 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
