Question about Tusk Yamaha Rhino 660 4x4 Auto 04-07 Oil Filters 3
Wiring diagram for
Need to tap key operated hot wire
What wire do I connect to the illumination wire on a car stereo for dodge stratus 2001 se ? ? There is no power going to stereo and won't turn on
Note the diagram and wire color, two fuses, the fuse that says hot all the time should be for radio memory and clock. The fuse that says hot with key on, should operates the radio. This is base radio wiring.
Jul 26, 2015 | Dodge Cars & Trucks
Went to get gas the other day and got back in it and it wont start turn key and it does nothing, we tried jumping it and nothing.. had to tow it home
It won't crank? Have you tried rapping the starter with a hammer-a light tap- to see if it will work? If that works, the starter is going out and needs replaced. Alternatively, take the starter off and have it tested for free at a parts store.
Apr 27, 2015 | 1994 Jeep Grand Cherokee
I am putting doors on my 1984 ford f150 from a 1985 ford firo which has power windows I need a diagram to wire power to the switches
You don't need a diagram, just power thru the doors at the hinge. Run 2(two) wires, one black and one red, thru an opening at the door hinge, even if you have to make the opening. Go to any fuse in the panel and find which is the hot side by pulling the fuse and test for the hot side. Stick a fuse tap on that side of the fuse and put the fuse back in. Get this fuse tap from any auto parts store. Get a pack of female spade connectors to connect the red wire of the wire size needed. Size 10 will do for this. Get some size 10 straight connectors also. Connect the red wire to the hot wire going to the window motor. Connect the black wire to the ground wire on the motor. now connect the other end of the black wire under the head of a bolt under dash. First in mind though, be sure the fuse you connect the red wire to is switch activated when on and off when switch is off. Power windows are great when you gottem. I plan on doing my Toyota with window power units from an Oldsmobile. It will happen. Breeze on Bro.
May 26, 2017 | Cars & Trucks
Honda crv wiring diagram
The tap? Do you mean the knob that turns hot to cold? If you are talking about this i had this problem on my 96 accord. You can pull the knob directly off. Do not twist it because it has interlocking teeth. See if the plastic teeth have been broken. That was my problem. Got a new knob for 7 bucks from body shop but you could just twist it with a wrench if you want(with the knob offf, of course)
May 10, 2014 | 2005 Honda CR-V 200i
Berlingo wiring diagram
Fixya has no wiring diagrams due to copyrighting. Sorry,.
Jul 23, 2012 | Citroen Berlingo Cars & Trucks
I need help with wire connections for power window switch on olds ciera front passenger door.what color wire connects it to master switch?
In the diagram, the brown wire is voltage for power windows. Goes hot when you turn on the key. Voltage comes from the power window circuit breaker. The black wires in the middle of diagram are ground. Use a testlite to check voltage on brown wire, key on. If the brown wire has voltage, to check the black wire for ground, use a testlite between brown wire and black wire. If lite comes on, you have voltage and ground.
Oct 15, 2011 | Cars & Trucks
My rd-s590 igot the wires hooked up but when i start my truck it say see ya. then whenigotto put a cd in it come on then shut it self down i need to kno if i got the wires hook up correctly but theres...
Hello! you realy need the wire diagram that cam with your unit,,,, I do know this> there will be a wire that gets connected to 12 possitive and is hot all the time,, next there is a wire that is cannected to the acc 12 Possitive that is switched on/off with the key,
when the key is "off" then the unit should go off,,,,,,,not be on...
with out seeing your wire diagram, I will say that the red wire (should ) be connected to the 12 possitive hot all the time,,,, and the Orange wire (should) be connected to the 12 possitive acc "key switch)
Please remember : never ground your speakers to the car ground/body!!!!! you could damage your unit
Hope this helps...
Sep 20, 2011 | Car Audio & Video
My wiring has been on fire and a lot of hot taps added to my 1984
good luck buddy. that sounds like a nightmare! best idea is to get a complete vehicle wiring diagram an try to read it to se where each wire goes. good luck
Dec 20, 2009 | 1984 Ford F 150
Installing radio in 85 mercedes-benz
there is no amplifier. you just need to find the memory wire that is hot all the time and the 2 wires that are hot with the key on. One is for radio operation and the other is for antenna operation. The speaker power is supplied through the fader switch in the center console and the switch is powered by the head unit. Just hook up your circuit 30 and your 2 circuit 15 with a ground and run you speaker wires to the head unit or if you are installing an amp from the wires from the fader switch. That switch can be popped out with a flat blade screw driver, Hopefully i have been helpful
May 28, 2009 | 1985 Mercedes-Benz 190
Tusk Yamaha Rhino 660 4x4 Auto 04-07 Oil Filters 3 Logo
21 people viewed this question
Top Tusk Science & Laboratory Experts
William McMath
ray gallant
Are you a Tusk Science and Laboratory Expert? Answer questions, earn points and help others
