Question about Philips 42PF7220A 42 in. Plasma Television
Screen flips to set-up screen immediately after powering up..
My Philips TV went into the set-up mode all by itself the other night. Even when trying to exit using the remote it immediately flips back to the set-up mode. Any ideas?
  • 106 Answers
Go to the philips website. Download the current software onto a thumd drive and upgrade your tv. The problemn will go away. Once on the philips website, you will have to input your model number and it will explain how to upgrade your tv
Posted on May 21, 2009
Colour settings
Good day!!!!
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter..
if no bulged capacitors that problem usually cause of faulty T-con board..
Jun 05, 2012 | LG 37LC7D 37 in. LCD HDTV
I have a Philips 47
The boards are different in sets even with the same basic model number- you would also need to check all voltages to board from power supply--PHILIPS HAD DIFFERENT BOARDS IN SETS WITH SAME MODEL NUMBER----POSSIBLE voltage needs to be adjusted or settings in service mode need to be adjusted.
Mar 10, 2012 | Philips Televison & Video
I have a Philips 42" LED flat screen about 5 years old, all of a sudden when you turn it on I get the settings menu, when I try to click out it will bring up the picture and then within seconds it...
Tv have a shorted IC that control the manual control board side of the tv itself or the manual control board itself it is dead.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish manual control board.Replace the manual tv control board first to test it out.If u still have the same result the IC that control the board itself is dead,now must take to the shop for repair.
Jun 09, 2011 | Philips Televison & Video
Stuck on menu screen
Try connecting the TV directly to a different wall outlet and check. Try resetting the TV to the factory settings. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service.
Jul 26, 2010 | Philips 42PF9431D/37 TV
MY in dash dvd player with flip open screen doesn't open
in dash flip tv dosent come allthe way out
Oct 29, 2009 | Car Audio & Video
Sony KV-27fs100 screen will not do anything, power is on
You may have had the sleep mode set itself. Try unplugging the set for 8 hours and let it reset itself to see if problem persists.
Aug 26, 2009 | Sony FD Trinitron WEGA KV-27FS100 27" TV
My Philips standard tv picture went out
You may have a corrupt eeprom! Eventually the red light will come on with no audio or video!
Jun 17, 2009 | Philips 27MS4504 TV
Open Questions:
See all Philips 42PF7220A 42 in. Plasma Television Questions
Philips 42PF7220A 42 in. Plasma Television Logo
183 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
