Question about Ovens
St george logon - Ovens
I'mfinding it hard to disconnect the wires
Best to get help.
It may require terminations
Sam
Melbourne Domestic Appliances
Text 0424395512
Apr 08, 2017 | Ovens
Hotplate won"t turn off st george cc-600 cooktop
I have a St George glass cooktop with temperature sensor light.It takes forever for the light to go out when I use the main element and that section often feels like it is still heatinglong after it has been turned off.Can there be power leakage through the switch for the main element
Aug 21, 2010 | Ovens
Hi the temp on our st george oven, model ueo-8 has become unreilable?
if digital the replace the oven control / if dial then the dial is at fault . mm
Jul 12, 2010 | Ovens
Turn off the timer on an old imperial st george
I have this exact same oven and this "feature" annoys me no end. To turn it off ... turn the clock dial to PAST the time that the timer dial shows. EG: If your timer dial is showing 6, turn the clock dial so that it rolls past 6 o'clock. This will pop out the timer dial and thus turn off the timer, allowing you to use the oven normally.
To stop accidentally pushing/turning that timer dial, I removed the knobs. Good luck.
Jan 23, 2010 | Ovens
I have a wall oven, a St George single oven. The
Depending on model-
Put the door at an opening of about 100mm. You should feel an indent for thecorect position.
You will probably need 2 people, 1 each side,
Slide the door upward at an angle same as hinge, It will slide off the hinge.
If the hinge is broken, and they usually break inside the wall of the oven, it will be very difficult to slide it off the broken hinge.
Hinges are available from EDIS SPARES 1800 125 039
Sep 12, 2009 | Ovens
St George DEO 7 oven temperature not going past 170
Merrillie,
we have this problem too on the top oven. I used to work at StGeorge and I'm an engineer, so if I find a fix, I'll let you know.
Simon
Sep 06, 2009 | Ovens
Ovens Logo
22 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
