Question about Fossil Black Rubber Digital Dial JR8859 Watch for Men
How to set time on jr-8859
How to set time to 12 hr clock
Changing the speed of clock (loses 1 hr per day)
Not sure but it sounds like it is set on moon time. No idea how to change.
Sep 28, 2016 | The Watches
I want to know about the dials
Bad pic but as I recall, lower is 24 hr clock, left is day of week and top is month of the year. The buttons above and below the time setting stem move them. Need more? Gimme more info.
May 10, 2013 | Tommy Hilfiger Watch, Mens Black Leather...
I have an ultmost model 6695 talking alarm clock. It is supposed to "talk" on the hour and on the alarm. However, it has stopped. The mode has 3 options: time, 12/24 hr, and alarm. I...
Make sure the clock is in the normal clock-display mode, not in a "set" mode. Press the minute key (again, while not in a set-anything mode) and you will see the hourly announcement toggle on and off. The person who designed it that way needs a good kick right in the bracket.
Aug 18, 2011 | Watches
Hi, I can't set the time on my addidas ADP6013 watch, can you help. Thank you.
You need to press and hold both left hand buttons at the same time. This is the mode and the light. From this screen you have options to change to 12 hr or 24 hr clock, set day etc.. Hope this helps. I struggled for days before sussing it out. Hope this helps!!!
Feb 05, 2011 | Adidas Digi III Watch
HOW DO I CHANGE MY WATCH FROM 24 HOUR MODE TO 12 HOUR MODE?
click on mode or setting option.then you will see the default time.edit it..try to change it using select or any mode available.there you can see 24hr clock and 12 hr clock.select which one you want.if it is in 12 hr then the time will be displaying like eg:7:00am or 7:00pm it means that it is in twelve hours.if it is showing 7:00 or 19:00 it means it is in 24hr clock.
Jan 29, 2011 | Casio W71-1V Wrist Watch
Activate the 24 hr clock function
Press the mode button until you find the setting for 24 hour or 12 hour setting. (It is likely that the message will be abbreviated because of the limitations of the display, so some interpretation may be needed.).
You change the setting by pressing one of the other buttons on your watch - some experimenting may be needed.
Mar 10, 2010 | Watches
Tipsy clock programming lost leaflet. would like to down load leaflet. bought this inexpensive clock at BB&B.
Hi I was having a hard time with this too, but luckily I found my leaflet.
To set time:
Press Mode 1 time
Press Set 2 times/ press up or down for hour
Press Set again for minute
Continue Pressing Set (up to 6 times) until everything is set
Back to normal mode- Press Mode 4 times
To toggle between 12 hr and 24 hr, press Mode 1 time
To Set an Alarm:
Press Mode 2 times
Press Set 1 times for hour, continue pressing set like you did for the clock.
Back to normal mode Press Mode 3 times
To cancel Alarm Press Mode 2 times and Set 5 times
Jan 16, 2010 | Watches
Antique Forestville Mantle Clock
Middle Key hole for the time.
Left side is for Chime
Right side is for the strike.
r/
David
Aug 25, 2009 | Seiko Chiming Pendulum Tambour Mantel...
Change watch setting from 24 to 12 hr clock
armitron watch 40/6601 instructions
Jan 19, 2009 | Watches
Fossil Black Rubber Digital Dial JR8859 Watch for Men Logo
32 people viewed this question
Top Fossil Watches Experts
Ansel Alberto
Ansel Alberto
Jimmy Accardi
Are you a Fossil Watch Expert? Answer questions, earn points and help others
