Xerox document centre C450 error code 016 311
SOURCE: fuji xerox document centre C250
Press machine log in button, enter 11111 confirm, this will take you to sys admin mode, from here you can navigate into sys settings to configure network,copy and fax defaults, and also auditron admin if this is the password mentioned, if the 11111 password has been changed hold the zero button for a few seconds then press start while still holding zero enter 6789 to get into diagnostics, and you can navigate through to the above settings caution be careful what you change in this mode.
Posted on Sep 04, 2008
  • 2072 Answers
SOURCE: Error Code 09,038.46:1529
One of your ink sticks is stuck and not loading properly. It is not advancing down in the ink loader.
Look for a twisted block, cracked or just stuck not sliding down.
If you need to remove them take a screw, like a dry wall screw and twist it into the block then slide it out or down.
Posted on Jul 01, 2009
komguy
  • 2306 Answers
SOURCE: Where can i find Xerox Document Centre C400
you might try for help at www.partsdrop.com
Posted on Jul 16, 2009
pineworks
  • 4041 Answers
SOURCE: Xerox Work Centre C2424 System Error
Hi there
I found some thing maybe do for you it may not be rhe right code you have at this moment but it come in handy for you.
31,004.40:6909: it's a mechanical initialization jam error. Pull out the paper tray to make sure it doesn't have a jam. Try also to manually feed some heavy paper or card stock through the printer to make sure the sensor in the preheater isn't stuck.
39,002.40 : DRAM test failure.
39,012.40:56208: "Cycle the power" and if that does not work replace the document feeder.
39,012.41: Document Feeder Optical Failure. Replace the document feeder.
4,0XX.6x: Process Control Software Fault.
· Reset NVRAM and then retest.
· Ensure ground integrity for the system
· Replace the EEPROM chip.
· Reboot the system.
· From the System Setup menu, go to "Information", "Troubleshooting"
· Service Tools menu.
· With the cursor at the top of the Service Tools menu, press both the Up Arrow
· and Down Arrow buttons to display the Hidden Service menu.
· Reset NVRAM is in there.
Also may be handy is this.
4,0XX.6x Process Control Software Fault
Error 04,041.66
Solution 1:
a. Reset NVRAM and then retest.
b. Ensure ground integrity for the system.
c. Replace the EEPROM chip.
d. Reboot the system.
1. From the System Setup menu, go to Information --> Troubleshooting -->
Service Tools menu.
2. With the cursor at the top of the Service Tools menu, press both the Up Arrow and Down Arrow buttons to display the Hidden Service menu.
3. Reset NVRAM is in there
Solution 2:
1. Turn the system power ON.
2. Wait for the Xerox logo to begin moving across the display.
3. Before the logo is centered on the display, press and hold the Back and Info buttons on the control panel.
4. Hold both buttons until the display reads “Beginning Service Mode Initialization”. Release the buttons and the system reboots into service mode with the Service Diagnostics menu displayed. Hope it will help you in some way of finding the fault. Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 03, 2010
  • 2072 Answers
SOURCE: My Xerox Copy centre C123 shows error code 124-315
Thats a weird one. The machine is detecting the wrong speeds.
Try this.
  1. Enter Diagnostic Mode ( UI Diagnostic Mode).
  2. At the Control Panel, press and hold the 0 key for 5 seconds, then press the Start button while still pressing the 0 key.
  3. Press buttons 6, 7, 8, and 9 on keypad and press Confirm.
  4. Press the Log In/Out button (button with Key symbol) on the Control Panel.
  5. Select System Settings.
  6. Select Common Settings.
  7. Select Maintenance/Diagnostics.
Then look at these 3 locations and see if they match, If they do not set them to match the machine speed.
  • [700-600]
  • [700-601]
  • [700-602]
Posted on Feb 11, 2010
Testimonial: "Thankyou,and need more help. chose NVM read/write & enter value700-600, it shows 65000 current value what should i enter as new value?"
For document centre c250 fuji xerox: error code 062-380 or error code 062-386
Defective IIt/IPS board. Is very expensive. Call you local Xerox service number and ask them for part number 160K99811 and how much it would cost to get it fixed.
Aug 04, 2010 | Xerox CopyCentre C128 Black and White...
Xerox Document Centre 230st need new hard drive?
N7-4 and N711 indicate the network or as it is called the ESS hard drive has failed.
Feb 12, 2010 | Xerox Document Centre 265ST Printer
My Xerox Document Centre 265ST just stopped working and a message: Copier is not available Printer Fault please call for assistance I cannot access tools or anything else.
turn it off completely unplug it. open up all doors and trays....turn it on with everything open if you still get the error you are going to have to call in a tech if it starts up . start closing things till you get to when that errror comes up then repost and ill look up an answer for you. i work for xerox
Dec 14, 2009 | Xerox Document Centre 265ST Printer
I have a Xerox Copier Document Centre 350 it has a fuser error U4-1 How do I reset fuser as the copier will not work as it says call technician
I would truly call in for service. Copiers require a trained tech to replace the fuser. Trust me I work in the IT industry. Have a trained tech fix it.
Nov 23, 2009 | Xerox Document Centre 420 DC Laser Printer
Xerox Fax Centre F12 keeps giving me error code E3 when I am trying to receive a fax from one particular client. I can receive faxes from others without problem, and this client says he can send faxes to...
Looking through all the service documentation and engeneering tips, and also searching the Xerox.com database, I find no E3 code for a F12.
Do you have the ECM mode on your mechine set to "ON" ?
That is the error correction mode.
I really can't find an E3 message in service documentation.
I will download a user guide and see if I can find it there.
Apr 14, 2008 | Office Equipment & Supplies
298 people viewed this question
k24674
