Question about Olympus VR-320 14.0 MP 12.5x Super-Wide Zoom Digital Camera Red
The finished images have recently appeared bluish in tone.
    Top Expert:
  • Olympus Master
  • 6,702 Answers
Your camera has settings for White Balance. WB. Perhaps you accidentally switched to a mode and forgot to set it back to automatic. See page 32 of the manual, how to switch between different WB modes.
Posted on Jan 03, 2014
How do I fix vertical lines and no picture.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to both Plasma & LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Aug 20, 2015 | Vizio E320VP 32" LCD TV
Image projector is bluish
If you mean the image projected on the screen appears bluish - You might check the physical connection of the cable attached to your projector. Or the cable may have bent pins.
If you have access to another working Epson Projector, see if you get the same result using the same cable(s).
-GWOOD
Jul 16, 2014 | Epson Office Equipment & Supplies
How do you align the colors?
Press MENU button and ON-SCREEN MENU will appear. Press
POINT LEFT/RIGHT buttons to move a red frame pointer to
IMAGE ADJUST Menu icon.
Press POINT DOWN button to move a red frame pointer to the
item that you want to adjust. and then press SELECT button.
The level of each item is displayed. Adjust each level by
pressing POINT LEFT/RIGHT button(s).
Move a red frame pointer to
the item to be selected and
IMAGE ADJUST MENU
IMAGE LEVEL ADJUSTMENT
Press POINT LEFT button to decrease contrast, and POINT RIGHT
button to increase contrast. (From 0 to 63.)
Press POINT LEFT button to adjust image darker, and POINT
RIGHT button to adjust brighter. (From 0 to 63.)
Contrast
Brightness
Press either POINT LEFT button or POINT RIGHT button to obtain
better balance of contrast. (From 0 to 15.)
Gamma
To store manually preset image, move a red frame pointer to
Store icon and press SELECT button. Image Level Menu will
appear. Move a red frame pointer to the Image 1 to 4 where you
want to set and then press SELECT button.
Image Level Menu
Move a red frame pointer to any
of Image 1 to 4 where you want
button.
Store icon
Press SELECT button at this icon to
store the adjustment.
IMAGE ADJUST
Menu icon
Press POINT LEFT button to lighten red tone and POINT RIGHT
button to deeper tone. (From 0 to 63.)
White balance (Red)
Press POINT LEFT button to lighten green tone and POINT RIGHT
White balance (Green)
Press POINT LEFT button to lighten blue tone and POINT RIGHT
White
Jan 22, 2011 | Sanyo PLC XU35 Multimedia Projector
How do I remove the Touch tone/pulse option. This message has recently appeared without knowing how it go there. It was never there before. ''If you are calling from a touch tone phone please press 1 now,...
Sounds like your touchtone gate has been enabled in your voicemail. To disable the touch tone gate enter feature 983. if your system has 2 digit intercom #s your default password is 120000 if your system has 3 digit intercom #s your default password is 1020000. once you have entered the password you will see 3 selections you can make .use the three soft keys under the display and select AA (auto Attendant). next press 1, the display should say TT gate:std chng and ok. press the chng key til it says none and press ok press the rls key when finished.
Jan 11, 2010 | Nortel T7316E 2-Line Corded Phone
Bluish image appearing on screens
It sounds like the projection lamp is beginning to show its age. How many hours of use does the unit have on the bulb? The bulb are typically rated for about 800-1600 hours of use before they go bad. The bluish image on the screen image is a typical tell-tale sign that the bulb is going to need replacing.
Most of your better projection units will have an internal time counter of the bulb life from the time the unit is first used or when a bulb is replaced. Check to see if your unit has this feature, if so it will show you on the screen display what is the total number of hours on the bulb and the estimated remaining hours of life.
Be aware that the replacement bulbs are NOT cheap and usually will cost you several hundred dollars, I have seen bulbs for professional projection units used for large convention/presentations have bulbs costing as much as $500.00 USD.
One other last thing to check is to clean the lens of the unit both inside and outside. To clean the inside, you will need to remove the bulb (be sure to wear a rubber glove as the oils from your skin will cause the lamp to blow, (causes a hot spot)). Then using a cleaning wipe, just as one used for cleaning microscopes or glasses, wipe the lenses. The discoloration might also being caused by dirt and oils on the lenses.
I hope this shed some light on your church's projection problem.
Sep 19, 2009 | Panasonic Office Equipment & Supplies
No color
what type, make or model? if it's a dlp projector, replace the colorwheel. if it's an lcd, reset the settings to factory default. if no better, replace the optical engine.
Aug 19, 2009 | Office Equipment & Supplies
My HP LaserJet 2605dn is printing pictures with a bluish tone
Check the Colour management in printer driver on the computer - set this to Automatic.
On the printer or The HP ToolboxFX, check to see if Economode is turned on (under Print Quality) which reduces the print quality.
Dec 15, 2008 | HP Color LaserJet 2600n Printer
Bluish background
try blocking the sensor with you palm so that it would create a black background. if the blue streak would still appear on it, you need to call panasonic and have it replaced. sorry. =(
Sep 22, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
Olympus VR-320 14.0 MP 12.5x Super-Wide Zoom Digital Camera Red Logo
27 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
