Question about Samsung Computers & Internet
Solid red light
I have a Samsung notebook and it just turned off off itself and when I try starting it, it turns on for a second and then off again. The second light from right is red, what does that mean and why won't my laptop start again?
    Problem Solver:
  • 33 Answers
I would say the laptop is overheating. But wont be able to say without doing a few things. give the model number of the laptop so that we can get the error light info from the user guide. what happens is you leave the laptop for a while and turn is on again?
if it goes on then is is overheating and needs cleaning otherwise the could be other problems an the best would be so contact Samsung support to help trouble shoot .
Posted on Jan 03, 2014
SOURCE: Computer starts and stops within seconds but batt light is solid green and pluged in
This is cause by the suspend button lock in and not reuturn to
off position. 100% will fix problem.
Posted on May 20, 2008
  • 193 Answers
SOURCE: Compaq Presario F500 - won't
check the power supply, either the power cord or your power supply in the laptop.
and NATurally..happens aFTER the warranty expires, that sounds about right.
Posted on Apr 13, 2009
Aeropostale3
  • 3 Answers
SOURCE: Gateway MX8734 crashed and will turn on for 1 second then die
try a new battery. It might be a bad brand of battery.
Posted on May 28, 2009
  • 116 Answers
SOURCE: Hello, My HP Compaq 6720s is turned off and
When you say turning on and off all the time until I disconnect the charger, IS the charger running the machine and then after so long cutting out? you leave it and it works , if so its overheating
Machine will need fan and all ducts cleaning and most likely replace arctic silver on psu
IF on the other hand its not running more likely the charger is not powering the machine or charging battery in which case you will need new charger
hope this helps get back to me if you need more help
Posted on Jun 10, 2009
SOURCE: Compaq Presario F700 wont boot
I had the same black screen problem with my Compaq Presario f700.
I went to the HP website to troubleshoot and found that a hard reset fixes the blank screen issue.
To perform a Hard Reset, unplug the AC power adapter and remove the battery, and then press and hold down the Power button for about 6 seconds. This will drain any residual charge in the capacitors and reset the power management controls to their default condition.
This fixed my problem.
I hope it helps you.
Best regards!
Posted on Jan 24, 2010
I have a Samsung Plasma PN63A650 that has worked 4 8 years, until today. I turned it on, stays on for 14 seconds, then turns off for 8 seconds. Would not respond to remote commands either
Easy fix for new Samsung TV switching on and off power ...
? 4:41
https://www.youtube.com/watch?v=H0cG3lzjuw8
Sep 15, 2012 - Uploaded by alwaysafix
My tv turns on and off by itself the minute I plug in the cable. ....Samsung E6030 led tv hv blinkin red light issue ... capacitors are looking good ...
Help PLEASE! Samsung Plasma Turning On/Off Repeatedly.
michiganstate.247sports.com > Topics
247Sports.comMy Samsung Plasma HDTV (approx 3.5years old) has some issues as of late. When Iturn the tv on, invariably, it starts to turn off and back on repeatedly.
Samsung Smart TV turning off - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - I have a Samsung plasma 60 inch model number PN60E6500EFXZA TV. It began to turn itself off every 5 minutes, for the past few days. I was able to factory ... Samsung TV Keeps turning off and on.
Jun 11, 2015
Samsung TV Keeps Shutting Down
Jun 11, 2015
Samsung Plasma TV turns off by itself
Jun 22, 2011
My Samsung 50 in PN50B650 turns off by itself then on again ...
Apr 30, 2010
More results from www.cnet.com
Jan 13, 2016 | Samsung Televison & Video
Samsung ln46c530 lost picture, now won't turn on. Indicator light turns on solid red when on, flashes five times when shut off
The fault is with its main board itself. Troubleshooting to this board is not an easy work to a user can do. It will be best to contact any service technician. google.com/+GopakumarGopalan
Nov 24, 2013 | Samsung LN46C530 TV
My playstation has the light trun green yellow flashing red light
With your PS3 turned off, press and hold the Power button on the front of the PS3 for about 10 seconds (the system will beep as normal as it starts up but after 7-10 seconds it will beep again). The video settings should now be reverted. Doing this will also reset any theme settings. try this? seems to fix alot of issues.
Jan 22, 2010 | Sony PlayStation® 3 (80GB) Console
Right out of the box, my ML-2510 has a solid red error light
You should install the software prior to connecting the printer, to make sure the provided drivers are ibstalled and not the generic ones that come with Windows.
Jul 22, 2009 | Samsung ML-2510 Laser Printer
My playstation 3 stays in the "standby mode" and does not turn on
its a power failure inside the ps3!!! You have to call sony to replace the system it will cost u 150.00 dollars unless ur still under warrenty goodluck because i had to get 3 systems from sony before i got one that worked just right
Mar 24, 2009 | Sony Playstation 3 (PS3) Console
Samsung lcd tv ltm1755b won't turn on (power light stays red)
Problem: Samsung LTM1755B with only a blinking yellow LED when you try to turn it on.
Solution: I just had one of these come in. I opened it up, and found the U501 capacitor a little suspicious looking, in that it had a deformed top. It was a 470uF 16V electrolytic 105degC 10mm x 12mm. I replaced it with a very good quality 1000uF 16V electrolytic 105degC 10mm x 16mm Nichicon UHN1C102MPD. After that repair, when I tried to turn it on, the LED was yellow for a second, then green, then I got a picture, and it appeared to work great. I then asked the owner a week later how it was working, and they said it was working just like new!
Jul 31, 2008 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
KP-57WS500 TV FADES TO SOLID RED W/ LINES A FEW SECONDS AFTER I TURN IT ON
Red CRT is doing short circuit in the neck. You can try to open the front panel and to hit easy the neck with wood or something and to decrease the red screen a bit. If doesn't work then replace the CRT.
Jan 04, 2008 | Sony KP-57WS500 57" Rear Projection...
Computers & Internet Logo
136 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
