Question about Vacuums
Hoover manuals hbc033
It shut down it self
Hoover bagged wind tunnel 2 vacuum turns its self off after about 10 min. of normal vacuuming I can press the power button right away and the vacuum will turn back on and vacuum for sometime as long as 5...
There is a thermal sensor in the motor which shuts power off if it gets too hot but usually it won't turn back on until it cools down. It seems you might have a defective switch
Oct 06, 2013 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover Windtunnel repair manual
click this link below to see repair video for self propelled mechanism
http://www.youtube.com/watch?v=K722IsUxjYM&feature=related
Sep 03, 2012 | Hoover Vacuums
Self propulsion doesn't work on my upright. Vacuum works fine otherwise
You will need to look @ your owners manual to see where the self propell belt is located i am sure yours is broke and need to replace,- it will not be hard to replace-Lance
Oct 21, 2009 | Hoover Vacuums
Self Propel doesn't work on Hoover Wind Tunnel
Your self propel wire could be broken. Lean the vacuum back like you were using it. If you stand in front of the vacuum look down and to your left. When you move the selp propel button you should see a wire move. If not then it's broken.
Oct 06, 2009 | Hoover Self-Propelled WindTunnel Bagless...
Hoover Windtunnel shuts down after 15 minutes
Might be that its not exausting enough heat & stutting its self down..
Try cleaning all the filters & the hepa filter..
This will increase air flow & maybe fix the issue..
Hope this helps !!
rate me good ;o)
Jul 14, 2009 | Hoover U6630-900 WindTunnel Bagless...
Hoover WIndtunner 7600 no suction
According to the manual on your machine, you can either have a broken belt, or the switches to the self-propel switch, and brush switch are in the off position. I have included a link to your manual. Please look at pages 13-14 under troubleshooting.
http://www.hoover.com/pdfs/manuals/U6439900.pdf
I hope this helps.
Jan 18, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
HOOVER 6430-900
Hoover Fined for Failing to Report Vacuum Cleaner Fire Hazard
(function(){ var e9 =new expo9_ad(); e9.size ="160x600,120x600"; e9.showAd(); })(); _qoptions = { tags:"ADSDAQ.LAWPOLITICS,501500," }; _qacct="p-01-0VIaSjnOLg";setTimeout("quantserve()",3000);
January 16, 2007
Hoover
hoover.jpgHoover Fined for Failing to Report Vacuum Cleaner Fire Hazard
Whirlpool Spins Off Hoover
Hoover Recalls Self-Propelled Vacuum Cleaners
Consumer Complaints
Hoover Company Inc. has agreed to pay a $750,000 civil penalty to settle allegations that it failed to report to the U.S. Consumer Product Safety Commission (CPSC) the sale of vacuum cleaners with defective on-off switches that can overheat and cause the vacuum cleaner to catch fire.
In April 2005, Hoover conducted a recall of 636,000 Hoover Self-Propelled Upright Vacuum Cleaners because of defective on-off switches.
In June 2004, after CPSC received notice of several vacuum cleaner incidents, the Commission staff requested Hoover provide a full report of incident information. In July 2004, when Hoover submitted a full report, it had notice of 260 consumer incidents, of which 141 involved reports of fire. Additionally, there was one report of a minor burn injury.
Hoover first learned of a vacuum cleaner switch on one of these units overheating and melting in April 1999.
Federal law requires firms to report to CPSC immediately (within 24 hours) after obtaining information reasonably supporting the conclusion that a product contains a defect which could create a substantial risk of injury to the public, presents an unreasonable risk of serious injury or death, or violates a federal safety standard.
These Hoover Self-Propelled Upright Vacuum Cleaners are plastic, upright vacuums with the brand name �Hoover� and words "Self Propelled" printed on the front of the product.
Only those Hoover Self-Propelled Upright Vacuum Cleaners manufactured between May 1998 and November 1999 are included in the recall that is the subject of this penalty.
Jun 11, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
U5180-910 vacuum shuts off on own
I had same problem. Turned out to be the filter that sits above the waste cannister. Remove the waste cannister. There is a little orange lever that releases the filter. It was caked with dirt not allowing any air flow causing the motor to overheat.
This foam filter gets dirty pretty fast.
Nov 18, 2007 | Hoover U5180-900 Vacuum
Vacuums Logo
29 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
