Question about Sewing Machines
Juki serger - Sewing Machines
  • 1116 Answers
SOURCE: Need instructions for threading Juki MO 3314
Open the font of the serger and the instructions will be printed on the serger or on the door.
Raise the presser foot and set the tensions to zero when threading.
Turn the hand wheel so the upper looper (curved one) is at it's highest point and thread it first, and then the lower looper.
With some sergers you must thread in a certain sequence. This should be indicated in the instructions on the serger.
Set the tensions back to normal ( 4 - 6), lower the presser foot and run a length of stitching to see if the threads are knitted together as they should before you start serging your project.
Posted on Feb 19, 2010
SOURCE: I need a manual for my serger. It is a Juki
(pdf format)--manualsonline.com
sewusa.com
mastersewusa.com
sewingmachineplus.com
homeappliance.manualsonline.com
Posted on Jul 31, 2010
SOURCE: JUKI MO 134 SERGER
How to Thread Juki MO-134 Serger from watching lady at Lyles. Turn upper blade up. Push in first then turn up.It makes threading easier. Blue Thread upper looper first. Pull thread through tension knob. Don'tjust lay it there. (She thought that is what I must have done) Orange Thread lower looper next. Pull thread through tension knob as inthreading upper looper. Adjust lower looper so it is right nextto upper looper so that their points are almost together and directly belowsewing needles. Lower looper will be in front of upper looper (I believe). With tread from upper looper pulledback, slightly lift lower looper above upper looper and thread. I think this isright. Pull thread back with other thread. Tension is the key. Remember that. Yellow: Thread left needle first.Remember tension. Pull thread through curled wire on left side of needle arm. Green: Thread right needle. Rememberabout tension. Pull thread through curled wire on right side of needle arm. b> Note: Before sewing turn the wheel tomake sure the stitches are going together correctly.
Posted on Nov 18, 2010
kiti63
  • 3 Answers
SOURCE: looking for an online manual for my Juki serger MO-634DE
Herre is a link to the threading diagram: http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Juki_Sewing_machine_threading/Juki_MO_634_Threading_Diagram.htm
Posted on Jan 31, 2012
SOURCE: JUKI MO-812 Class DD6 Serger Instruction Manual
check with a juki dealer about a manual
or check with sewvacdoctor.com
Posted on Mar 05, 2012
Can I make rolled hem with a Juki MO 2366 N?
Most likely. Most overlockers can make a rolled hem. You will probably want to do a lot of practicing on scrap chiffon before trying it on the real thing. It involves using only one needle, both loopers, and making appropriate adjustments to the machine.
Serger 101 Threading the Juki MO 654de Machine for Roll Hemming by CKC...
How to Serge Rolled Hem
Serger Stitches 101 Cheat Sheet Never Ever Without It Your New Must Have...
Bernina has some very nice Serger Workbooks that could be helpful:
Bernina Mastery Workbooks
Nov 13, 2017 | Juki Sewing Machines
I need replace thread holder for Juki MO-644D serger
Good luck. I found a replacement part for one of mine on Ebay. Just search for Used Juki Serger for parts. Maybe you'll find a 644D for cheap enough that you can scavenge parts for a few more years.
Oct 25, 2012 | Juki MO-644D Mechanical Sewing Machine
Mar 03, 2012 | Sewing Machines
I want to adjust my serger yuki mo 2516n but i don't still have it's manual instructions
if you go to this page http://www.juki.co.jp/household_en/serger/index.html there are the current household sergers from Juki and a four page threading diagram for them showing the different stitch set ups.
If your serger is a domestic one too (the MO in front makes me think so) then you may find that the threading up is very similar on your model. Stitch length is usually a kob on the right marked from 0.5 to 4 and differential feed knob is usually there too, usually marked from -0.5 up to 1.5. Tension settings are usually around 5 but you adjust the looper tensions to suit the fabric and how wide you are trimming it with the blades.
You could contact Juki or their local distributor in your country and arrange to purchase manual for your model. http://www.juki.co.jp/household_en/dl/index.html this page gives a listing for countries.
it is also available on line to purchase as a black and white pdf file, http://www.sewusa.com/Sewing_Machine_Manuals/Juki_Manuals/Juki_Industrial_Sewing_Machine_Manuals/MO-2500_Instruction_Manual.htm for $8USD
Jun 20, 2011 | Sewing Machines
How to thread a juki serger sewing machine. i need a large diagram of how to do it. thank you
do you know what model Juki it is? Is it a serger or a sewing machine? Juki do industrial straight, serger and specialised machines such as coverstitch and blind hemmers as well as domestic sewing machines and sergers so there is a big range of machines.
There are manuals at this site for http://jukihome.com/products/mo644d.html various models of Juki Home sergers, but you will need to hunt through and find your model.
The manual is on the "features" tab for each model so just dig down a bit to locate the pdf file in there.
I hope this is what you were searching for.
Jun 03, 2011 | Juki Sewing Machines
sewusa.com
mastersewusa.com
Jul 20, 2010 | Juki Sewing Machines
Don't know how to thread the juki mo-735 serger
This video starts off a little ****, but expected if you have ever visited the Threadbanger site - http://www.metacafe.com/watch/1462325/how_to_use_a_serger_indie_pendent_designer_spotlight_thread_he/ Not your brand, but the same "serger basics". Lift the antenna to it's highest position. Set the tensions to zero. Have the presser foot up when threading. Raise the upper looper to it's highest position. Sergers are great little machines, but they can be nerve racking when it comes to threading. After years of threatening my old FunLock, I bought a Babylock Imagine with air-jet threading - what a relief!
Mar 12, 2010 | Juki MO-735 Mechanical Sewing Machine
Feb 19, 2010 | Juki MO-734DE Mechanical Sewing Machine
Looking for an online manual for my Juki serger MO-634DE
Oct 08, 2009 | Juki MO-644D Mechanical Sewing Machine
Sewing Machines Logo
13 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
