Question about Kwikset UltraMax Powerbolt 1000
Unlocks using any code or just the unlock button
I installed and program this lock about 3 months ago. i thought it was done correctly but when i accidentally hit the unlock button before typing the code it unlocked. I then typed in various incorrect codes and it unlocked to those as well. I have tried to reprogram several times but with the same outcome. What am I doing wrong/ any suggestions? Thanks
SOURCE: Lock works in reverse
You need to set the door direction jumper pins inside the unit. From LH to RH or vice versa depending upon your door.
Posted on Jun 01, 2009
  • 963 Answers
SOURCE: it unlocks only when you
Follow this link and go to Step 8 on page 7:
http://s7d5.scene7.com/is/content/BDHHI/kwikset-smartcode
I believe you have the functions reversed. This will walk you through how to fix it.
Posted on Mar 06, 2011
  • 963 Answers
SOURCE: My lock works backwards. Hit the lock and it
I'm assuming you are dealing with the Powerbolt, since you didn't mention the model of lock you have. This problem is probably because the "handedness" of the door is set opposite of your installation. That is, you may have what is called a "right-hand door" and the lock is set for a left-hand door, or vice versa. In other words, what side the door hinges are on and which way it therefore swings open.The Kwikset lock has an internal jumper which needs to be moved to another position to change the function.
Cut and paste this link into your browser, the scroll down to Step 11:
http://www.kwikset.com/Customer-Support/Product-FAQs/Faq/50160000000HifLAAS.aspx
Step 11 says:
11. Door handing: I have installed your Powerbolt, but when I push the Lock Button, it unlocks? What should I do?
First remove the cover on the inside of the Powerbolt unit. On the right hand side under the batteries, you will notice that is says "Door Direction Jumper". If the cap is mounted on Prongs 1 & 2, carefully remove it and move it over so that it mounts Prongs 2 & 3. A is right handed, B is left handed.
This link will illustrate how to remove the cover to change the jumper:
http://www.kwikset.com/Support/Faq/50160000000IB4hAAG.aspx
Posted on Apr 18, 2011
  • 963 Answers
SOURCE: Kwikset smartcode deadbolt. The
Let's review the programming steps, in case you are overlooking something. This information was found at this link:
Important before proceeding: 1. Verify that position #2 of the "Settings
Switch" is in the OFF position. (Refer to section 11.) 2. Work with the
door open (away from jamb) to avoid accidental lock out. 3. Make sure
the bolt of latch is in the extended (locked) position
8. Automatic - Bolt Direction Determination (Door Handing).
IMPORTANT: DO NOT SKIP THE FOLLOWING STEP.
LOCK WILL NOT BE ABLE TO OPERATE PROPERLY!
? In the steps below, the SmartCode mechanism automatically determines the "door handing" and sets the proper direction for motor to rotate.
a. Press and hold the "LOCK" button on the exterior keypad, while fully inserting the battery pack into the interior assembly (the tabs on the pack must face out)
b. When the unit begins to operate the bolt, release the "LOCK" button.
c. Do not disturb the unit for approximately 20 seconds until the interior Green LED flashes followed by a beep. During this time the system will drive the bolt several times, will determine "door handing", store data in memory and exit. It is very important that this process is allowed to finish properly.
Proceed with programming your Usercodes per the instructions.
Finally, here is the contact number for Customer Service At Kwikset. Call them if you still have the problem.
1-800-677-5625
Posted on Aug 04, 2011
  • 101 Answers
SOURCE: to unlock the bolt no code is needed... just by
You need to reset the lock, so it will be set to the correct handing (left or right hand door).
Open the door and extend the lock bolt. Remove the battery. Press the reset button three times and wait 20 seconds. Push and hold the lock button, while inserting the batteries. Hold the lock button until the bolt starts to move. Allow the lock to complete it's learning cycle.
Program a new code and test.
Posted on Aug 12, 2011
Lock botton unlocks the door and unlock botton locks it. When I put the code in it unlocks it and when I push the lock botton it unlocks it
I have installed your Powerbolt, but when I push the Lock Button, it unlocks? What should I do? First remove the cover on the inside of the Powerbolt unit. On the right hand side under the batteries, you will notice that is says "Door Direction Jumper". If the cap is mounted on Prongs 1 & 2, carefully remove it and move it over so that it mounts Prongs 2 & 3. A is right handed, B is left handed.
Good luck--and please provide feedback if this helps!
Oct 09, 2011 | Weiser Lock Powerbolt 1000 Lock
Tip
How to Program Acura Remote Transmitter
Acura Remote Alarm / Central locking
Model: CL Year: 2001-2003
Model: TL Year: 1998-2006
Model: MDX Year: 2001-2006
Model: RDX Year: 2007-2009
Model: RL Year: 1996-2004
Model: RSX Year: 2002-2007
Model: TSX Year:2004-2008
System Operation
  • Pressing remote transmitter LOCK button once activates alarm and central locking.
  • Pressing remote transmitter UNLOCK button once deactivates alarm (if fitted) and unlocks driver's door only.
  • Pressing remote transmitter UNLOCK button once also activates driving position memory. Driver's seat and mirrors move into memory position specified on remote transmitter when driver's door opened.
  • Pressing remote transmitter UNLOCK button twice within 5 seconds unlocks all doors.
  • Pressing remote transmitter trunk release button for 2 seconds activates trunk release.
  • Pressing remote transmitter PANIC button for more than 1 second activates panic alarm.
  • Pressing any of the remote transmitter buttons deactivates panic alarm.
  • If vehicle unlocked and doors not opened within 30 seconds, locks are reactivated.
Synchronization.
when
  • Remote transmitter battery replaced.
How
  • Press remote transmitter LOCK button or UNLOCK button 5-6 times.
  • System should now lock and unlock vehicle to indicate synchronization procedure complete.
  • Check operation of remote transmitter
Programming
How
  • Obtain all remote transmitters.
  • Switch ignition ON.
Proceed as follows:
NOTE:Point remote transmitter at central locking signal control module (located behind glove box).
  • Within 4 seconds: Press LOCK button or UNLOCK button of first remote transmitter.
  • Within 4 seconds: Switch ignition OFF.
  • Within 4 seconds: Switch ignition ON.
Repeat procedure above twice.
  • System should now lock and unlock vehicle to indicate programming mode activated.
Within 10 seconds:
  • Press LOCK button or UNLOCK button of first remote transmitter, allowing doors to lock and unlock once.
  • Press LOCK button or UNLOCK button of each remaining remote transmitter to be programmed, allowing doors to lock and unlock once as each remote transmitter is programmed.
  • Switch ignition OFF.
  • Remove key
  • Check operation of all programmed remote transmitters.
Immobilizer
System Operation
  • System arms 5 seconds after switching ignition OFF. Immobilizer warning lamp flashes during this time
  • Immobilizer warning lamp illuminates for 2-3 seconds.
  • If immobilizer warning lamp illuminates for 2-3 seconds then flashes rapidly:
  • Key code not recognized.
  • Remove key and try again.
Programming
When
  • System malfunction.
  • Key added or replaced.
How
Immobilizer can only be programmed using diagnostic equipment.
Model: MDX Year: 2007-2009
Model: TL Year: 2007-2008
System Operation
  • Pressing key LOCK button once locks the vehicle.
  • Pressing key LOCK button twice within 5 seconds activates the alarm.
  • Pressing key UNLOCK button once unlocks the driver's door only and deactivates alarm.
  • Pressing key UNLOCK button within 5 seconds unlocks all doors and tailgate.
  • Pressing key UNLOCK button within 5 seconds and holding will open windows and sunroof
NOTE: Models with "Technology Package": Alarm central locking functions can be altered using digital multifunction display in instrument panel.
  • Pressing key PANIC button for more than 2 second activates panic alarm.
  • Pressing any of the key buttons or turning ignition ON deactivates panic alarm.
  • System will automatically lock all doors when vehicle is driven above 15 mph (if function selected).
  • If vehicle is unlocked and doors or tailgate not opened within 30, 60, or 90 seconds (depending on programming), locks and alarm system are automatically reactivated.
  • Pressing tailgate release button once will open, close or reverse direction of tailgate.
Programming
When
  • Key remote transmitter added or replaced.
How
  • Obtain all keys fitted with remote transmitters.
  • Ensure doors, trunk / tailgate and hood are closed and unlocked.
NOTE: A maximum of 5 remote transmitters can be programmed.
Proceed as follows:
Repeat procedure above twice. Locks should cycle when button in pushed.
  • Within 4 seconds of each other press LOCK button or UNLOCK button of each remaining remote transmitter to be programmed, allowing doors to lock and unlock once as each remote transmitter is programmed.
  • Remove key.
  • Wait 10 seconds.
Immobilizer
System Operation
  • System arms when vehicle is locked using the remote transmitter.
  • If key code is not recognized:
  • Engine starts, then shuts off.
  • Immobilizer warning lamp flashes once, then blinks until ignition is switched OFF.
  • With ignition switched OFF, immobilizer warning lamp will flash 10 times to indicate the system has reset.
Programming
When
How
Model: RL Year: 2005-2009
Programming
When
  • Remote Transmitter added or Replaced.
  • System Malfunction.
How
Remote Transmitters can only be programmed using diagnostic equipment.
Automotive and Commercial Locksmith Acura Remote Transmitter Programming...
on Mar 26, 2015 | Televison & Video
Got a preowned 2004 318i executive series E46 facelifted two months ago, comes with 2 sets of ignition key with remote on fob. Suddenly, 1 key that can operate the keyless entry will not start the engine....
How
Unlock vehicle. Enter vehicle. Close driver's door. Switch ignition ON and OFF. Remove ignition key. Press and hold unlock button Fig. 2 [2]. Press lock button Fig. 2 [1] briefly 3 times within 10 seconds keeping unlock button [2] depressed. Release unlock button Fig. 2 [2]. Central locking system locks and unlocks rapidly to indicate correct programming. Repeat above procedure if central locking system does not work.
NOTE: A maximum of 4 keys can be programmed. Carry out programming procedure for each key within 30 seconds.
Aug 30, 2010 | 2006 BMW 3 Series
2002 bmw 530i key does not (remotely) unlock doors or trunk but they work fine manually.
Unlock vehicle. Enter vehicle. Close driver's door. Switch ignition ON and OFF. Remove ignition key. Press and hold unlock button. Press lock button briefly 3 times within 10 seconds keeping unlock button depressed. Release unlock button. Some models: LED flashes slowly for 10 seconds. Some models: Central locking system locks and unlocks rapidly to indicate correct programming. Repeat above procedure if central locking system does not work and LED does not flash or LED flashes continuously.
Mar 09, 2010 | 2002 BMW 5 Series
Central locking on mk 5 golf works fine with key in lock and from inside car using switch but only unlocks drivers side using key fob. any answers?
Synchronization
When
Key buttons operated repeatedly while vehicle out of range and system becomes inoperative.
How
Polo: Press key unlock button for approximately 1 second. Golf/Bora: Press key lock or unlock button for approximately 1 second. Manually lock or unlock vehicle. System should now lock or unlock vehicle. If not, carry out programming procedure.
Programming
When
Key added or replaced. System malfunction.
How - Polo
Keys can only be programmed using diagnostic equipment.
How - Golf/Bora
98MY
How - Golf/Bora 99MY
Switch ignition ON. Insert key to be programmed into driver's door lock. Lock vehicle manually. Press lock or unlock button. Wait at least 1 second. Press lock or unlock button again. Vehicle horn sounds to indicate correct programming. Keys can also be programmed using diagnostic equipment.
Mar 07, 2010 | 2001 Volkswagen Golf
Central locking went on my lexus took it the garage they said the key wouldn't reprogramme is there anything that can be done
Programming
When
How
Driver's door open and key removed from ignition switch. Insert key into ignition switch, then remove it. Within 40 seconds: Press lock and unlock on the vehicle door lock control switch at 1 second intervals 5 times. Close and re-open driver's door. Within 40 seconds: Press lock and unlock on the vehicle door lock control switch at 1 second intervals 5 times. Insert key into ignition switch. Switch ignition ON and OFF once to program a new key code whilst retaining the original codes or twice to program a new key code whilst erasing the original codes. Remove key from ignition switch. System should now lock and unlock vehicle, once or twice depending which mode has been selected. Within 40 seconds: Simultaneously press and hold key lock and unlock buttons for a maximum of 1,5 seconds. Within 3 seconds: Press any key button for a minimum of 1 second. System should now lock and unlock vehicle once.
Manufacturer: Lexus Model: IS 2,0 200 Engine code: 1G-FE Output: 114 (153) 6200 Tuned for: R-Cat Year: 1999-05
© Autodata Limited 2009 25/02/2010 V8.207M-ukad113581
NOTE: If system locks and unlocks vehicle twice, programming procedure has not been completed. Repeat programming procedure.
Within 40 seconds: If required repeat button procedure to program remaining keys.
NOTE: To exit programming mode: Close driver's door or insert ignition key. NOTE: A maximum of 4 keys can be programmed
Feb 25, 2010 | Lexus IS Cars & Trucks
I replaced battery in my audi 80 2.0 tdi but have lost the remote and alarm wont stop going off .
Depress lock or unlock button. Manually lock and unlock driver's door within 30 seconds. System should now lock or unlock vehicle. If not, carry out programming procedure.
Programming
When
Key added or replaced. System malfunction: Alarm LED in rear fog lamp switch illuminates for 30 seconds when vehicle is locked.
How
NOTE: A maximum of 4 keys can be programmed (one at a time).
As memory positions of existing keys are unlikely to be known: Obtain and reprogram all keys.
NOTE: Existing key memory positions will be overwritten.
Switch ignition ON. Use key not fitted with remote control. Manually lock vehicle using key. Using first key, press unlock button once (programs memory position 1). Alarm horn sounds once to indicate signal received. Wait 6 seconds. Press unlock button once to confirm programming. Vehicle unlocks. Programming mode deactivated. Switch ignition OFF. To program remaining keys into memory positions 2, 3 and 4. Carry out the complete procedure below for each key: Switch ignition ON. Use key not fitted with remote control. Manually lock vehicle using key. Press unlock button at 1 second intervals, as follows: Twice for memory position 2 (second key). Three times for memory position 3 (third key). Four times for memory position 4 (fourth key). Alarm horn sounds once every time unlock button is pressed, to indicate signal received. Wait 6 seconds. Press unlock button once to confirm programming. Vehicle unlocks. Programming mode deactivated. Switch ignition OFF.
NOTE: Ignition MUST be switched OFF between each key programming procedure
Jan 10, 2010 | 1992 Audi 80
How do i program a keychain and the smoke dector
to program any new sensors first you must access the installer menu by opening the front cover and using the red buttons typing in the installers code,(4321) is the default code. once that is done press the add button, then the sensor/remote button, then trip sensor(keyfob by pressing both the lock and unlock buttons together until the system beeps) or (removing the smoke detector from the base until it beeps). Once the sensor has been learned it will say keychain remote, press the sensor/remote button repeatedly until it says the correct location, then press done. then enter group code 01 for the keyfob and 26 for the smoke detector. then done.
Sep 25, 2009 | GE Security Simon 3 Wireless Home Security...
Need of programming instructions for keyless entry for 1996 LHS
System operation
System will automatically lock all doors when vehicle is driven in excess of 15 mph
Pressing UNLOCK (on remote) once deactivates system and unlocks driver door only
Pressing UNLOCK (on remote) twice w/in 5 seconds deactivates system and unlocks all doors
Alarm/central locking functions can be altered using remote transmitter
Programming
Access data link connector (DLC)- druvers sude fascia
Switch ignition on
Jump DLC terminal 1 and ground
Ensure doors lock and unlock, indicating programming mode active
Press any button of each remote to be programmed
Ensure doors lock and unlock after each remote operation - indicating programming complete
Remove jump lead to exit programmming code
A maximum of two remotes can be programmed
Jan 20, 2009 | 1997 Chrysler LHS
Programming keyless remote
2003-04 Mazda 6 REMOTE PROGRAMMING
Step 1: Open drivers door and leave open.
Step 2: Lock and unlock the driver’s door using the power door lock switch on the door.
Step 3: Insert key into the ignition.
Step 4: Turn key to on position and return to off position. (IMPORTANT - use ON position NOT ACC position). Do this 3 times within 10 seconds. Leave key in the ignition.
Step 5: Open and close the driver’s door 3 times. (Door should be left open after this step).
Step 6: ECU should respond by locking and unlocking the doors.
Step 7: Press any button on remote #1 twice. ECU responds by locking and unlocking the car doors.
Step 8: Press any button on remote #2 (etc.) twice. Each time the ECU will respond by locking & unlocking the doors.
Step 9: Remove the key from the ignition and the ECU will respond a final time with a series of door locks and unlocks. You're done!
Good Luck.
Jul 12, 2008 | 2003 Mazda Mazda6
Kwikset UltraMax Powerbolt 1000 Logo
Top Kwikset Locks & Locksmithing Experts
Jim Thurston
Mike
Steve Masymas
Level 1 Expert
Are you a Kwikset Lock and Locksmithing Expert? Answer questions, earn points and help others
