Question about Schwinn 12" Roadster Tricycle
Can't blow up tires on12" roadster - Schwinn 12" Roadster Tricycle
Need rear tube for Schwinn roadster tricycle rear tire 10"
Search engines work better than postong and awating an answer.
search for >>> inner tube 10" bicycle
Jul 17, 2011 | Schwinn 12" Roadster Tricycle
What is the widest tire fitment for rear 2004 1200 roadster?
I really don't know how wide you can go but I never recommend going any wider than the stock tire without modifying the bike to accept a wider tire. The problems you will run into is rubbing the final drive belt and the tire rubbing under the fender when you hit a bump. I'd stay with the original size tire.
Good Luck
Steve
Jul 01, 2011 | 2004 Harley Davidson XL 1200 R Sporster...
Need two rear and one front tube for model S6760 schwinn tricycle roadster....
Any bicyle shop and many hardware stores could help you. Look at the sidewall of each tire and find the size embossed on it. It will be in the form of "diameter x width" Use THAT information in your quest. Perhaps look online/eBay.
Jan 26, 2011 | Schwinn 12" Roadster Tricycle
If I buy the new Iphone 4g, will I be able to pair it with my 2005 Z4 3.0i roadster?
Yes you will My IPhone 4G paired to my 2005 Z4 3.0i roadster and boy do I love my car damn she has a nice ***. But boy are the tires exspensive
Jan 17, 2011 | 2005 BMW Z4
Schwinn roadster trike back tire went flat and needs repair
buy a tire repair set from wal mart and repair the problem.
May 29, 2010 | Schwinn 12" Roadster Tricycle
I am restoring a Schwinn 12" Roadster tricycle
This is what I recommend:http://sheldonbrown.com/wheelbuild.html There is a lot of comprehensive info here and may be more than you will need but it is detailed and well written with illustrations. Please let me know if this helps.
Dec 04, 2009 | Schwinn 12" Roadster Tricycle
Front tire on 12" Schwinn roadster tricycle
if you take it to a tire shop they should be able to fix it. as it's not a huge tire... take the rim off... fill it with air and immerse it in water to find the leak
Feb 26, 2009 | Schwinn 12" Roadster Tricycle
Schwinn 12" Roadster Tricycle Logo
Top Schwinn Cycling Experts
Tony
michael
michael
jasiel murphy
Are you a Schwinn Cycling Expert? Answer questions, earn points and help others
