Question about Acer Aspire 3690-2196 Notebook
Losing memory i am running low on memory on my disk C but i dont know what is taking up the memory i cant find any folders with large memory
    Problem Solver:
  • 8 Answers
Download a trial of DiskState (type it into Google to find it).
It will map out all of the large amounts of data on your computer. If you find that the size doesn't match up to what you expected, there may be some hidden or secure folders that you can't access taking up all the space.
Posted on May 21, 2009
Thanks for the help in advance, i have two issues if u could plz help me with i have an acer aspire 5315 laptop with 80Gb memory. The thing is this memory is separated into two hard drives, C and D. 1)I...
Disk D is for storing recovery configurations. To see what happened to your memory, go to the root directory C: from your "My Computer" icon. Scroll to the folders in the root. Right click each folder and select "Properties." The drive will add up all the memory being used by that folder. Take notes on what you have and then drill down into the folders that seem to be using more space than they should be. Delete stuff you don't need. Let me know if you have more questions.
Dec 04, 2010 | Acer Aspire 5315 Notebook
Disk error
this is because you memory card is corrupt and not good any more.
I would advice that you get another memory card.
Take care.
Mar 12, 2010 | Nokia N73 Cellular Phone
Dont know how to look at my pics....put my memory card that I had some pics saved and I cant view them!! how do I view my pics from memory card?
well you need to place those pics in memory card images folder or photo folder...then you can see them on your phone
Nov 28, 2009 | Cell Phones
My computer constantly runs out of memory and does disk cleanup. i cant defrag. i dont know what to do
try adding additional memory(ram) look at the computer manual for exhact type of memory that will work with your system
Jan 29, 2009 | Acer Aspire 1640Z Notebook
Microsoft Word Suite
One solution is USB memory stick.
You can copy contents of a CD to USB drive, and then run the installation from there.
You will need memory stick large enough to support this data (512 MB or 1 GB, it depends).
Create a folder named Word on USB disk, then copy all the files and folders from a CD to this folder.
Insert USB disk in Aspire One and run setup.exe from this folder you created.
Jan 16, 2009 | Acer Aspire One PC Notebook
Cant put files on my memory
format both phone and memory card
Jan 10, 2009 | Nokia N73 Cellular Phone
My computer needs a clean out.
Perform the steps given below to increase you system performance.
Uninstall all unwanted software.
To uninstall software:
Click on Start -> Settings -> Control Panel -> Add/Remove Programs
Select the software (one at the time) from the list and click on Add/Remove button and follow the online screen instructions.
Erase unnecessary files in the windows temporary folder.
Double Click My Computer.
Double Click the drive where windows are installed. This is typically drive C.
Double Click the windows folder. This is typically C:\Windows.
Double Click the temp folder. This is typically C:\Windows\temp.
Press control A to select all files and folders.
Press the delete key.
If confirmation is asked to delete these files choose yes to all.
Defragment hard disk.
Close all applications.
Disable your screen saver.
Disable all the programs on the taskbar if possible.
Click Start.
Click Program.
Click Accessories.
Click System Tools.
Click Defrag.
Select the drive to defrag. You should defrag every hard disk on your system. This process can take quite some time.
Click Ok.
Enable your screen saver.
Remove Startup programs (if you know what you are doing)
Click Start
Select Run
Type msconfig in the text box
The "System Configuration Utility" window will open
A list of programs will be shown each having a checkbox to the left of the name.
Click on the checkbox to enable the program (so it runs when windows boots) and click a second time to Uncheck the box to disable the program (so it does not run when windows boots).
Set the size of the virtual memory (swap file) to a constant optimal size.
Right click My Computer
Click Properties
The System Properties window lists the amount of RAM in your PC
Click Performance
Click Virtual Memory
Click Let me specify my own virtual memory settings
Click the arrow next to the hard disk.
Here are some guidelines to choose the best location for your virtual memory file
a) Select the quickest hard disk.
b) If you have, two hard disks that are similar in performance select the hard disk that does not contain Windows system files (usually C:).
c) Make sure the drive has free space equal to at least twice the size of the recommended swap file size.
d) If the partition is on the same physical drive, select the partition in alphabetical order. For example, if you have one 20GB hard disk and you partition it into two 10GB partitions drive C & D) You should pick Drive C over Drive D if meets all the guidelines of a, b & c.
Set the Minimum/Maximum to: With large hard disks settings at least 128mb or 256mb swap file should be sufficient in almost every situation.
Note: The amount of RAM plus the size of the virtual memory file is the maximum amount of RAM you can use at once.
Click OK.
After setting the size of the virtual memory file windows will display the following message. You have chosen not to let windows manage virtual memory automatically.
Click Yes.
You must restart your computer before the new settings will take effect. Do you want to restart your computer now?
Click Yes
Next :-) please vote if this help you
Nov 29, 2008 | Computers & Internet
Gateway mx6930 laptop freezes up every 10 minutes - keyboard and mouse become inoperable
Click Start.
Click Program.
Click Accessories.
Click System Tools.
Click Defrag.
Click Ok.
Click Start
Select Run
Click Properties
Click Performance
Click OK.
Click Yes.
Click Yes
Unlock 1 GB micro sd memory card of Kingston Made
you will need to take the phone to a mobile service center....and have them reset the code
Aug 30, 2008 | Nokia 5300 Grey Cellular Phone
My desktop access is declined. i dont know why. i cant even create a folder or paste a folder in desktop. I am using windows xp service pack 2 genuine version.
Try running a check disk by clicking on Start-->Run then typing in chkdsk /f and clicking OK. Once it's completed, try creating a folder.
Jul 21, 2008 | Computers & Internet
Acer Aspire 3690-2196 Notebook Logo
93 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
