Question about RCA 27V514T 27" TV
RCA 27V514TYX26 I have a RCA 27V514TYX26 I can't pick up any channels on it every time I keep getting unusable signal Is it something I need to hook up to my TV
  • 126 Answers
So the set is not reconizing no signal have you tried to goto the menu on your set and enter the channel manually try this let me know what happens okay good luck
Posted on May 22, 2009
Rca model j27435 trying to use dvd player says unusable signal
Most DVD players and maybe the Wi are connected via rear audio and video input jacks so that may be your issue.
Jun 11, 2012 | RCA F27442 27" TV
I have my rca model f36665 hooked up strait from the wall to the tv and I can't get it to find the channels. do I have to have a cable box?
First if cable I presume you have entered the menu and selected cable.
Another possible reason is the tuner/s in this set are bad---hook a DVD or something to one of the rear inputs and see if set works.
If set works that way and tuner turns out to be bad you can with a box with av cable out connections on back just go into a rear input and bypass the tuner--leave set on that input and change channels with the box.
Let me know if you have questions and what you find---usually on this set if no signal---"unusable signal" will appear on screen if no signal.
Mar 20, 2012 | RCA F36665 36" TV
I cant find the av jacks to hook up my dvd player
This model doesn't have any A/V jacks. Many low-end RCA models didn't include any special features. They can only pick up signals over the antenna input. What you'll need to connect your DVD player is an RF converter, which takes the audio and video signals from the player and turns them into a channel 3 or 4 TV signal that the set can pick up.
RF converters aren't hard to find. Radio Shack, Sears and Wal-Mart all say they sell them, and you can certainly find them online. Hooking one up is just a matter of connecting the necessary cable to the player and TV, connecting the converter power and setting the output channel. Then put the TV on that channel and you're set. Unfortunately, this will give you lower picture and sound quality than you get from a TV that allows direct A/V inputs, but it's the only option.
Nov 21, 2010 | RCA F25422 25" TV
Unusable Signal Message
I can;t keep my DISH satillite to turn on. when I turn the tv on and hook up the cales i get unusable signal and blue screen
May 21, 2010 | RCA TruFlat 27F520T 27" TV
Unusable signal
video inputs do not have channels you must not have it on the right source. Turn your Wii on then change the input untill you find it.
Sep 08, 2009 | RCA F32648 32" TV
NO channels now, we had some before!!!!!
Here is how you should have it connected.
1- Antenna (rabbit ears or whatever)
2- Converter box
3- Television
When you turn on the TV and the converter box, go to channel 3 on the TV. You should see the converter box signal there. If you do not see it try channel 4. Bring up the convert box menu and go through the AUTO SEARCH, not manual search. Now your box will search all the frequencies and add any stations that are in your area. Make sure you change channels with the converter box, not the tv. An antenna on the roof will still provide somewhat better range, but even rabbit ears will likely pick up something. If you still get no channels you could be too far away, digital signals have a shorter range than analog signals. You can check your local TV stations website or call to see if they are broadcasting digital yet.
Apr 08, 2009 | RCA Analog (RCA) to Digital (VGA)...
Unusable signal notice appearing on screen. we
Are you in an area where the digital transition has occured? You may need a newer tuner www.dtv.gov to get one for free or almost free.
Mar 19, 2009 | RCA 32F531T 32" TV
Installation of wii
I had the same problem on a 32" rca crt. It worked fine, power was cut during electrical work and when it came back, "unusable signal." I went into the menu, then channel, then video input source. had to change it to the correct input "s-video in my case" Then it worked. GOOD LUCK!
Feb 14, 2009 | Nintendo Wii Console
Unusable Signal for PS2
If you want to use a PS2 with an RCA stereo monitor Colortrak plus television, folllow these steps:
1.Buy a universal remote compatible with RCA televisions if you don't have the original.
2.If your remote needs programming, program it with the manual provided.
3.Goto Menu
4.Goto Alarm
5.Goto Alarm Channel
6.Set Alarm Channel to 00
7.Exit Menu
8.Goto channel 00 on the television by using the remote.
9.You should be in AV mode, and able to play your PS2.
P.S. I don't know if you need to set Alarm Channel to 00, but that's how i did it.
May 13, 2008 | Televison & Video
Unusable signal
Usually need a second receiver. Cannot just split signal. With some cable providers you can split the cable before it hits the cable box for basic cable channels.
Suggest contacting Cable Company if does not work.
Thanks!
Mar 23, 2008 | RCA TruFlat 27F520T 27" TV
RCA 27V514T 27" TV Logo
217 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
