Question about Sewing Machines
How do i thread a smartek mini sewing machine model rx01b
SOURCE: How to thread sewing machine Janome model 372
how to thread a janome model 372
Posted on Dec 27, 2009
SOURCE: bobbin singer stylist zig zag model 477
Check this web page
http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Singer_Sewing_Machine_Threading/singer_477_threading_diagram.htm
Posted on Jan 23, 2010
  • 1116 Answers
SOURCE: I have a Singer Touch N Sew Model 636. The
I had a Golden Touch 'N Sew many years ago and as the machine aged and parts became worn, step 4 of this bobbin winding diagram started to become a problem and I had to sometimes try several times before the "tabs" would release. If they did not release, the machine "thought" it was still winding the bobbin and would not sew.
http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Singer_Sewing_Machine_Threading/singer_2001_touch_tronic_threading_diagram.htm
Posted on Mar 06, 2010
SOURCE: I just bought a janome mini sewing machine. I
First, in order to get the bobbin thread up, you have to turn the wheel backward, not forward. If you try this, and it is not the problem, keep going.
Next you need to check the needle. There is a screw on the right side of the needle carriage right underneath the underside of the top...unscrew this and the needle should come right out. The flat side of the needle shank should go towards the back of the machine. If it isn't, switch it so that it is and try again.
If this doesn't solve your problem, what has happened is that the gears in the machine have gotten out of alignment. There is an easy fix:
Take off the plate that covers the bobbin chase...there are two screws one on each side. Remove these...you need a stub screwdriver, because regular ones will not fit under there.
Remove the bobbin carriage and the bobbin, making careful note of how they fit back in. Take a picture before disassembling it so you have a reference.
The part that carries the thread around the bobbin is still in the machine. Turn the wheel and you will see it rotate. What has happened is that the needle is not going down in the machine at the right point because someone kept sewing after it jammed and one gear kept going while the other one didn't and now it is out of alignment. These machines have plastic gears and the can slip past each other if you aren't careful not to stop immediately when they jam.
To fix it, you are going to have to do some trial and error. Grab the rotating part of the bobbin chase and hold it firmly. Rotate the wheel forward until you hear it click once. Then rotate the wheel backward again and see if it grabs the top thread. If it doesn't, repeat holding the bobbin chase and turning the wheel forward until it does.
Once you have the gears basically aligned, you will need to reassemble everything. Put the face plate back on and put at least one of the screws in all the way. The face plate holds the bobbin chase in correctly and if you don't fasten it it will not work correctly.
Now try sewing. If it starts to jam, stop immediately, cut the threads and look at the back. If it's a loopy mess, you are going to have to dissamble as before and again grasp the bobbin chase and turn the wheel forward one more click, then reassemble and try again. Eventually, you will find exactly the right alignment and the machine will sew perfectly.
I just had to make this fix on my own machine...I didn't want to take it in for repair because the bench fee alone would cost as much as the machine did!
There are some great video's on YouTube for help with threading the machine...look for StampTV and you should find them. Good luck!
Posted on Apr 21, 2010
  • 1116 Answers
SOURCE: How to thread mini mender
http://www.sewwhat.net/millie/Manuals/CEX300k.pdf
Posted on May 02, 2010
How do i adjust the bobbin tension on a mini rex sewing machine
Sorry, am unable to locate much information on your machine. However, something in the following may be helpful.
You may want to read through some of the reviews as there are some hints:
Amazon com Smartek Mini Sewing Machine Cordless Red
How to Use Mini Rex Sewing Machine eHow
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=4&ved=0ahUKEwjjjan6v43RAhVp04MKHdB2DCIQFggqMAM&url=http%3A%2F%2Fwww.tivax.com%2Fmedia%2Fdownloadable%2FUser%2520Manual--LSS-202.pdf&usg=AFQjCNGYbItSX6kGJyUY9pmNJnptm9RfWQ&cad=rja
Or contact them directly for information:
General Information
info@smartekusa.com
Dec 24, 2016 | Rex Sewing Machines
Want to download instruction manual
These machines are recent and inexpensive. I find no manuals.
Mar 30, 2015 | Smartek Smek Mini Rex Cordless Sewing...
How do I use smarteks mini cord-cordless machine with pedal and adapter. RX-05S
well the manual should tell you but if the picture shown is it looks really simple to figure out
Jan 30, 2015 | Rex Smartek RX-05
Hi the tention on the machine is incorrect... how can i fix this!!! where can i get a user manual
The tensioner seems to be the knob that the thread runs trough right on the front of the machine. try rotating it and feel the thread tension by pulling the thread with your hand to see which way loosens/tightens.
Jul 20, 2014 | Sewing Machines
John Lewis mini sewing machine
This was really helpful for me fixing my daughter a John Lewis (janome) mini sewing machine, and now can get the bobbin thread up again, however, when you sew, the thread is not staying in stitches, just coming off the material completely. I tried forcing the gears on one more time but then it didn't pick up the bobbin thread again so went back to the other gear position. Any ideas of what to try and get it stitching again? Thanks
Apr 02, 2013 | Janome Mini Compact
Upper thread not engaging bobbin thread...
Hiya Kandie. Usually when you can't pull the bobbin through, the wrong size needle is in, try a different size needle. Hope I was some help for you.
Feb 08, 2012 | Janome SEW MINI Mechanical Sewing Machine
I need manual for Smartek RX-07 Mini Rex Cordless Sewing Machine
How to thread a sewing handheld machine rx-o1r
Dec 12, 2011 | Sewing Machines
Sewing Machines Logo
15 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
