Question about Sharp XG-E3500 Multimedia Projector
Large dot in the middle of the projected display
On a Sharp XG e3500u DLP projector, the screen lights up just fine, except for a large black dot in the center of the blue screen if there is no video source. If I attach a source, the image is displayed with a now large transparent yellow dot. Menu items from the projector seem to display normally across the dot. The projector has been in storage for several months, I don't know how long it's been behaving this way.
    Problem Solver:
  • 5 Answers
You may mana replace the DLP chip
Posted on Nov 27, 2014
  • 2,237 Answers
There is a burned-in spot on the polerizer light filter for the blue lcd. it makes sure the light is blue coming through, that's why it is black on a blue screen, and yellow when the red and green are the only light showing through. it needs to be replaced. pat # PFiLW0213CEZZ.
Posted on Jul 17, 2009
Black and white dots on screen
Hi Emmanuel,
I think your projector lamp and LCD area is dusty.
please use pressurized air can and clean the area.also check the dust filter.
do it carefully.
regards,
nuwan
Jan 27, 2014 | NEC NP215 Portable Projector
There is a large green spot on the screen. Really noticeable when on a dark screen.
either the Green LCD Panel is shot, and/or the Green Polarizer Glass. unfortunately the only way to fix it is to replaced the whole Prism assembly.
May 26, 2011 | Sharp Notevision XG-C50X Multimedia...
I replaced the lamp in my Sharp XG-E3500U and there is lines in the picture now. How do I solve this problem?
mostly, this is caused by a default of the lcd screen inside, if so, you must replace it, if your model is using 3 lcd screen, open the cover, disconnnect one of them , run the projector, if you don't see lines, power off, reconnect it and disconnect the second, till you see the lines, so you can localise the default one. you also can try to check the lcd screen connector, disconnect, clean, reconnect
Mar 04, 2011 | Sharp XG-E3500 Multimedia Projector
Need to reset lamp displayon sharp xg-e3500u
To reset the timer go to the link below. It has the instructions.
http://unitedvisual.com/Pdf/SharpxgeCounter_Reset.pdf
Good Luck please rate 4 thumbs up and please leave a testimonial
Oct 18, 2010 | Sharp XG-E3500 Multimedia Projector
OUR 52" rear projection tv is now unwatchable because of white pixels everywhere on the screen. Started with a few now thousands
it sounds like a lot of dust in the light engine lens.usually pixel defects are purple or black...question is your set a lcd or a dlp format? and how large are the dots. if real tiny it will be dust. if large it will be insects... have a qualified serviceman take a look.. good luck...
Nov 13, 2009 | Samsung HL-S5086W 50" HDTV
Sharp Xg-50X projector won't turn on. Replacement light not on.
I pulled the projection bulb and did a continuity check on the filiment. It was open. I ordered a new bulb.
Thanks.
Feb 14, 2009 | Sharp Notevision XG-C50X Multimedia...
User manual
Solution for Sharp projector
with the function button on the laptop and the lcd button, F5 for toshiba, the screen will display both sides. if not then give the details of ur laptop.
Dec 11, 2008 | Sharp Notevision XG-C50X Multimedia...
Sharp Notevision XG-NV6XU
Looks like the wrong lamp was installed, or the cooling fan is not working. Careful - it may be permanently damaged, as the LCD inside can be hurt by high temperatures.
Sep 05, 2008 | Sharp Notevision XG-NV6XU Multimedia...
Sharp XG-E3500 Multimedia Projector Logo
606 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
