Question about GE Spacemaker JVM1640SJ Microwave Oven
I have a jvm1430wd002 GE Microwave that is completely dead. The breaker and outlet are fine.
No light, no fan, no display. Is there an internal fuse of breaker?
MicrowaveSvc
  • 9086 Answers
SOURCE: Complete Shut-Down
I woulds first suspect a blown internal fuse or a thermal cutout on the magnetron in your case, but a microwave can be dead for many reasons.
If it goes dead for just a while during or after cooking then comes back on, the magnetron is probably overheating and causing the thermostat to open. When it cools, it closes the circuit and allows power on again.
If it's intermittent or random, it may be a bad connection, usually on the control board or fuse holder.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If the fuse is good, it may be an open thermostat or thermal cutout on or near the magnetron or on top of the cavity / body of the oven.
If you or a friend decide to look into it, we have critical safety information and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Please write back with more details if you need further help.
We appreciate your thoughtful rating of our answer.
Posted on Nov 25, 2007
MicrowaveSvc
  • 9086 Answers
SOURCE: GE JES1344SK01 countertop microwave, no power
A microwave can be dead for many reasons.
It may be the fuse, which is usually located behind the grille or on the floor of the oven behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking TCOs or thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If the cavity thermostat needs to be checked or replaced you'll need to pull the oven from the wall, in which case you can download GE owner's manuals and installation instructions here.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
There should be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
You can usually find helpful exploded view diagrams by entering your full model number here. Once you have the part numbers, though, I would suggest ordering parts here at a much lower cost.
Posted on Dec 17, 2008
housejess
  • 317 Answers
SOURCE: Wife left our GE spacemaker 2 running for 20
theres a fuse inside the unit
Posted on Nov 07, 2009
  • 34 Answers
SOURCE: GE Advantium 120 oven: Was boiling water and oven
You will need to remove the top grill vent first, then you can remove the screws coming in from the top of the grille vent then that will expose a screw holding down the control panel at the top. Remove the screw and remove the control panel. The fuse is located in a little 1" fuse holder just behind the front panel near the top.
Posted on Feb 05, 2010
Testimonial: "That's helpful to know. Found a similar feedback, "is usually a 15 amp Cerramic fuse (white color). Appliance parts places usually carry it.thanks"
SOURCE: GE Spacemaker microwave JVM140G just stopped
NO internal fuse. It is most likely, the magnetron, and or High power diode. As related In all likelihood the mangnetron has failed, or perhaps even the Power Supply. or a fault that is shutting the system down for safety reasons You need to have it serviced by a reputable service centre/man. Ensure you get a firm "Quote" before proceeding, and remember these days the cost of repair can equal or exceed the price of a new one.
Posted on May 10, 2010
Hi I have a Samsung SMH9187 micowave that is dead (no display, light, fan, mirowave).
Sounds like the main fuse blew. It's either near where the power cord enters the cabinet, or behind the control panel (if an over the range unit).
You may also have some type of failure in the high voltage circuit; based on your description of the symptoms.
Aug 16, 2014 | Samsung SMH9187ST Microwave Oven
No power, no display power to unit
Blown fuse inside of unit. Must find out why fuse blew, something shorted or bad connections.
Oct 21, 2017 | Jenn-Air JMV9169BAS Convection Microwave...
Unit went dead. No fan, display, light, oven. Is there an internal fuse or reset?
There is an internal fuse. Be careful high voltages present even if the microwave is unpluged.
Good luck
Jan 03, 2014 | GE Spacemaker JVM1640SJ Microwave Oven
My GE JVM1750DM blew an internal breaker or fuse when I attempted to remount a lamp lighting the stove top; it had fallen out of its mount. Where is the internal reset or breaker located, and how do
There are fuses inside the unit. No internal breaker. A lot of the time that damages the main circuit board too. Blowing the trace that supplies the power to the bulb off of the board. will probably need a new baord, or someone to repair that one.
Sep 24, 2017 | GE JVM1750DM Microwave Oven
I have a 20 year old GE JCM140H over the range microwave which has always worked just fine. Last week everything just "died" no lights, no fan, no display, no microwave. I thought that I had...
You'll have to remove the cabinet cover to access the fuse. It is in line with the power cord. 20 Amp, slow blow.
One of the screws on the back of the cover may be a security TORX (the kind with a pin in the center of the head). Usually, if you tap on it with a hammer, you can remove it with a pair ov Vise-Grip pliers.
Jan 05, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
My whirlpool mh3185xps went completely dead. No
sorry but yes its time to replace it,
oh,, by the way,,,
your very lucky to still be alive right now!!!
tinkering inside of a microwave could kill you,,,
inside of your microwave is a very big capacitor it works just like a police stun gun works,,,however it dont just stun you,,,it kills you! witch would realy spoil your day, be warned, many a fool has took a free flying losson from one of them but servived just!
Jan 09, 2010 | Whirlpool MH3185XPS Microwave Oven
Microwave dead even though power works
It sounds like the magnetron overheated and opened the thermal fuse on the magnetron.
This can be caused when the internal cooling fan is not running or by a magnetron that is failing.
When I say internal cooling fan, I do not mean the hood vent exhaust fan which you can turn on and off manually.
I'm instead talking about the internal fan which comes on automatically whenever you microwave.
It is vital that the cooling fan runs, or the magnetron will be destroyed.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can also find helpful exploded view diagrams and order parts by entering your full model number here.
The magnetron will have a 5 to 9 year warranty. Your manual will tell you that.
You can download GE owner's manuals and installation instructions here.
If needed, GE may send you a replacement magnetron. GE Customer Service is here.
Dec 04, 2008 | Microwave Ovens
Dead micro
It could be a bad in-line circit breaker fuse. Unplug the microwave and take the outside cover off. Look for the in-line circuit breaker fuse. Use a plastic fuse puller (not your hands or a metal tool as there is still voltage stored in the microwave even when it is unplugged). Look at the fuse and see if it is blown. (The metal wire running length of tube will be broken. If you have one, test with an Ohmmeter.
Jun 03, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave completely shut off, including the display
check the diode and the cap they like to go bad.good luck
Apr 06, 2007 | GE Advantium 120 Convection/Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
