Question about Sunheat SH-1500 Electronic Infrared Zone Heater Golden Oak Casters, 13x19.5x17.5", 1000SqFt,1500W, 12.5A, 7-10 Min. Free Heat,140CFM,3 Ply Filter
How do you set the tempature
Temp is at 61 degrees want to set at 72
Recently purchased clock with tempature and humidity dials, humidistat not working It is outdoors in southwest Florida and it says the humidity is 50 %,no warranty or instructions
what makes you think that the humidity is not correct
it is a indicator that will not move much so don't expect it to move around like a temp gauge or barometer
May 15, 2017 | Humidifiers
How much water gal/hr is reasonable to expect from the furnace humidifier overflow in "0 degree" farenheit outside to heat a 1500 square foot normal midwestern house to 72 degrees inside having a norm
There is no flow rating because it would depend on too many factors. What you do need to check is the float valve. The water valve is opening and closing like it should be but the reservoir is filling too much.
Jan 23, 2015 | Humidifiers
Air inside house feels dry. Not sure if humidifier is workng. 1. regardless of outside temp (between 10 degrees and 40 degrees F) the humidity never goes above 28% even with the humidistat turned to the...
Sounds like you are not getting the proper voltage to the solenoid valve...
Check for 24v coming off of the transformer...that may be 24vac not vdc...
Then check to see if there is power coming from the humidistat...
unhook the wires to check for the power at the solenoid valve...
check across the two wires...
if there is power the valve is bad and that alone will cost about 90 bucks with shipping...
if there is no power trace back and see where the power stops at...
heatman101
Jan 20, 2011 | Aprilaire 400 Humidifier
Aprilaire manual humcontrol 4655 hum 560 .when control clicks works fine.move dial to outside temp never works changed 4655 twice i have 28\r\nvolts ac all the time
When humidistat is at ouside temperature that may be a lower humidity setting than is in your home. Doesn't sound like there is a problem. If it is too dry in home you can set it above ouside temp to turn on. The ouside temp setting is estimate that you will not get condensation on windows.
Jan 17, 2011 | Aprilaire 550 Humidifier
Ge Zoneline heatpump works fine in the summer but in the winter with 45 to 50 degree days the compresser hardly runs. By turning the thremostate you can get it to run for a short period. I have 6 of these...
These Ge Zonelines have and ambiant Temp control on the unit when the temp drops it drops out the compressor and goes to electric heat. This keeps the unit from getting iced up. They do go bad and sometimes they shut off to soon. I just replace them and everything goes back to normal. They are located on the outside part of the unit. Just slide out the unit and it is located I beleive on the right side of unit Rus.
Dec 17, 2009 | Humidifiers
Chronotherm Three thermostat vs Buderus Logamatic Computer.
The outdoor thermostat senses the the temp of the outside air, and adjust the boiler water temp according to what it knows is best. The reason that the boiler is running longer is the old boiler used to be constantly sending 180ish degree water to the baseboard, now that water may only be 140ish degrees. The idea behind this is to reduce off cycle heat loss, as the greater the temp difference between the air temp and water temp, the quicker you loss heat. The theory in boiler run time is this, the less times it starts and stops, and the long run times will give you the best efficiency. Hope this answers you questions.
Sep 28, 2009 | Honeywell Power Humidifier: Furnace...
My Aprilaire 560 is not producing humidity for our house. Outside temp is 20 degrees, inside humidity is 20% and won't go higher. I have replaced the water panel -- no change. There is water going into the...
Turn off the saddle valve going to the humidifier. Remove the water lines going into the solenoid valve. Clean the filter screen and the orifice in the water lines right next to the solenoid valve.
Jan 02, 2009 | Humidifiers
Aprilaire 760 w/ Auto-Trac quit
Have you changed the pad and cleaned it out ?
Feb 02, 2008 | Aprilaire 700 Humidifier
Honeywell Chronotherm III
Try this link:
http://yourhome.honeywell.com/yourhome/Applications/TechLit/TechLitSearchResults.aspx
It looks like there are a variety of model numbers for the Chronotherm III. Hopefully you can locate your model number.
Dec 17, 2007 | Honeywell Power Humidifier: Furnace...
Sunheat SH-1500 Electronic Infrared Zone Heater Golden Oak Casters, 13x19.5x17.5", 1000SqFt,1500W, 12.5A, 7-10 Min. Free Heat,140CFM,3 Ply Filter Logo
Top Sunheat Humidifiers Experts
Mack Baxter
Dennis
Are you a Sunheat Humidifier Expert? Answer questions, earn points and help others
