Question about Vehicle Parts & Accessories
Gear changes not recognized on 2006 BMW x5
I have a 2006 BMW X5. When I put the car into any gear the gears are not recognized on the cluster/dashboard and the car would not move. After several attempts the car would not start.
    Prodigy:
    An expert who has answered 500 questions.
  • 545 Answers
The obc has recognised (it thinks) a security issue and needs BMW to recover and reprogramme the obc.
Posted on Jun 30, 2014
3 Suggested Answers
  • 10 Answers
SOURCE: I have problem with my Mercedes E350 Automatic 2005 model. It doesn't change gears when the car is cold so it feel like driving in first gear no matter how much I accelerate. When the car heats up I n
When was the last time you had the tranny fluid and filer changed? I hear that they recommend changing it at 60,000. This model has extensive electronic sensors and interface controls on the engine and trans axle (nothing is simple anymore... :( ). Just from what you described, i would think that perhaps there is a relay or sensor connected to the trans axle that is not functioning properly ( especially when cold ). Since you have to restart the engine when warm to get it to work, it makes me think a relay is being re-set when you re-start the car. The car should shift properly whether cold or warm. I hear that you will have problems shifting if the regular 60,000 mile changes are not performed on the trans-axle fluid. If it were me, I would try that if you have not already done so in the last 60,000 miles.
Posted on Apr 11, 2013
  • 787 Answers
SOURCE: 1951 plymouth bucks when starting out in first gear
Bucking is generally a sign of you releasing the clutch to soon and not giving it enough gas. So I have to ask you, How long have you owned (driven) this car that it's bucking when releasing the clutch pedal?
Posted on Nov 12, 2013
Car does not recognize gear shifts
WHen moving the gear selector, could you feel the vehicle engaging the gears?
The vehicle may not start as it thinks the selector is in gear not in park.
It sounds like a selector switch issue.
WIth accessories switched on, place car in reverse (without enging going) and see if reverse lights are on.
Jan 03, 2014 | Vehicle Parts & Accessories
Either the actuater is faulty or the gear box.some times the filter inside the gearbox needs to be replaced.Have a proffessional look at it.
My 2002 BMW x5 seems to be idling for no reason and the truck starts jerking when in drive position.
Ur BMW X5 series is having a transmission problems and it going to be worst if u don't take this car to a AMGO or the BMW dealership to take a look at it transnission gear box.Must have the car transmission fix.If u adnore this problems long enough the car transmission gears in the box will evenly buckle and grain to a ruin all of the gears parts teeths and than the car have to be in reverse and go to drive again every times tries to drive this car.Evenually all the gears teeths in the transmission box are all gone this car will go into iddle and will not go into drive gear at all.
Sep 18, 2012 | BMW X5 Series Cars & Trucks
Bmw x5 manual transmission grinding when changing the 3rd gear
Click on link or copy and paste in your browser: http://www.manualowl.com for diagram in the free PDF.
Apr 13, 2012 | 2007 BMW X5 3.0si SAV
I have fault code EGS (054) 36 Gear monitoring 4, BMW X5 E53 3,0 D 2002
2003 X5 bmw the trans. fail safe program comes on when driving, I was told that the trans needs to clean out and put new sensors. Is that true it gives the code 055
Apr 09, 2010 | 2004 BMW 5 Series
My 2004 bmw x5 jerks when first putting the vehicle in forward gear. Only happens when starting out. Afterwards it is mooth sailing.
hi , you may need to get the gear box oil level checked as this seams that it may be a little low , you could also tryrunning the engine for a minute or so , this would allow the oil to warm up and hopefully engage the first gear correctly , regards mark
Jul 29, 2009 | 2004 BMW 5 Series
Transmission problem bmw x5 automatic
dear friend-the fact that your vehcl does not pick up speed tells me that it is slipping,there is a pressure lost in the gear box,you have to remove and rebuild as the clutches will be burnt.
Apr 07, 2009 | 2002 BMW 5 Series
Bmw x5 slow gear change
this is normal to some extent to try and warm up the tranny to opp temperature as soon as possible. make sure the vehicle had the latest software installed in the transmission as this could also cause a delayed shift when cold.
Jan 22, 2009 | 2004 BMW Z4
Vehicle Parts & Accessories Logo
83 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
