Windows update 80070216 - Computers & Internet
How do I fix Windows 10 update 0x800705b4 error code?
This error commonly occurs within the operating system at the time of windows updates. If this error is not fixed, it will lead your system slow or even corrupt it.
This error may arise for the following reasons,
1. windows defender update
2.
Damaged system files.
3.
Third-party anti-virus and malware.
Solution for the windows 10 updates 0x800705b4 error code:
Right here are a few solutions for troubleshooting 0x800705b4 error code,
Method 1: Uncheck the "get updates for other Microsoft products when you updates windows" option:
• Open the "Windows Update" and click "Advance Options".
• Uncheck the "get updates for other Microsoft products when you updates Windows" Option if it's marked.
• Now the update process should complete successfully.
• You may run this process continuously until you get the "your device up to date" message.
• Once this message appears, again check/select "get updates for other Microsoft products when you updates Windows" Option.
Method 2: Temporarily disable the "Windows Defender"
• In case, the above solution doesn't work, you can disable the" Windows Defender" for temporarily.
• Type Defender in the search box and open the Windows Defender Desktop app.
• Click "Settings" and turn off the Real-Time Protection and Cloud-Based Protection options.
• Close the setting window and now the windows defender appears in red.
Note: After that do all the steps in solution 1 again, hope the update process will be successful this time. Once this issue is fixed, you can turn on both Real-Time Protection and Cloud-Based Protection.
Method 3: Run the Windows Update in "Clean Boot"
You should login computer as an administrator for performing "Clean Boot".
Method 4: Run the "Microsoft Update Troubleshooter" and Restart the Windows Update:
Still, if you having update issue, download the "Windows Update Troubleshooter" and Run.
After this, restart the "Windows Update Service".
Follow these steps for Windows Update Service restart,
• Open the Command Prompt(CMD)
• Type "net stop wuauserv" then press "enter"
• Wait for the confirmation message.
• Then type "net start wuauserv" then press "enter"
Hope the above solution will fix the update issue.
Jun 12, 2017 | Computers & Internet
How to fix windows update 80070216
Machine is infected with a rootkit or a virus.
Windows errors can occur for a number of reasons, including programs not installing or uninstalling properly, malware, system conflicts, Active X errors, and the most common, registry errors. PC registry errors occur over time due to the constant writing, editing and deleting of information from your computer's registry over time as programs are installed, modified and removed.
Many malware and spyware programs can also cause unwanted changes to your PC registry, which leads to the errors and reduced PC performance you are likely experiencing. In some cases, registry errors can be occurring without you noticing. They are still harmful and should be fixed regularly.
Download and run Kaspersky TDSSKiller, then download and run Combofix. These two tools will clean-up your machine. The links to download these applications are provided below.
Windows Update should work after that.
Combofix Download
Sep 09, 2014 | Microsoft Windows 7 Home Premium 64BIT...
Error code 80070216 windows 7
Reset your windows update component to see if that helps. https://support.microsoft.com/en-us/kb/971058
I’m happy to help further over the phone at https://www.6ya.com/expert/james_d4449ffdf318a2c3
May 10, 2014 | HP Pavilion Computers & Internet
Windows Update Error 80070216
http://answers.microsoft.com/en-us/windows/forum/all/microsoft-updates-not-installing-error-codes/8a046630-b9b8-4191-aac6-9075ac658d6c
Apr 18, 2014 | Microsoft Windows 7 Professional for PC
How to update windows xp
Go to Microsoft Update and follow the appropriate instructions.
Jun 11, 2011 | LG Computers & Internet
Windows defender will not update my defenitions are out of date
Hello
Is windows update turned on in control panel?Use automatic updates configuration.
Apr 28, 2011 | Computers & Internet
Security Update for Windows Media Player 10 for Windows XP (KB936782) Security Update for Windows XP (KB926247) Security Update for Windows XP (KB950749) Critical Update for Office XP on Windows XP...
Does windows always have this problem? I think it can be fixed through a <a href="http://www.pcaholic.com"> computer check up</a>. Might want to have a good look at the website <a href="http://www.pcaholic.com"> http://www.pcaholic.com</a>.
Jul 28, 2008 | Computers & Internet
Windows xp updates
Download from this link service pack 3
Mar 31, 2008 | Computers & Internet
Computers & Internet Logo
381 people viewed this question
David Payne
David Payne
