Question about Nautilus Commercial Series T916 Treadmill
Nautilus incline - Nautilus Commercial Series T916 Treadmill
Tip
Ubuntu Nautilus in Action
1.Windows use Windows Explorer, its counterpart in Ubuntu
the Nautilus (file manager in Gnome environment).
2.Nautilus can offer us much more than that, it is enough
to wish to see Nautilus in real action.
3. Nautilus scripts are very powerful
they provide new ways to Handle files.
Right-clicking will become your new powerful weapon.
(1.A) Add a nautilus script:
System> Administration> Synaptic Package Manager
When you open it, you do Reload, Search and install:
nautilus-image-converter
nautilus-wallpaper
nautilus-script-manager
nautilus-script-collection-svn
Nautilus Subversion Management Scripts
nautilus-script-audio-convert
nautilus-share
nautilus-actions
nautilus-gksu
nautilus-open-terminal
rar
unrar
(1.B) After the installation:
Applications> Accessories> Terminal
When you open this copy it (when you ask for your password, type):
gconftool-2 --set --type=bool /apps/nautilus-open-terminal/desktop_opens_home_dir true
(1.C) Rise of Ubuntu and re-entry
System> Quit> Log Out
(1.D) Now you are quite prepared to see the Nautilus in Action
When you right-click, you get new opportunities in addiction,
whether you are on the desktop or in Nautilus, above pictures, etc..
Right-click easy to get:
-Set as wallpaper
change-size image
-open as root (administrator)
-Open Terminal here
-When you have over a file,
Right click> Create Archive. ZIP or. Rar ... the choice is yours ... etc.
on Jan 13, 2010 | Computers & Internet
Calibrate nautilus T914
The Steps for Newer Style Console Calibration:
  1. Locate the calibration area on the rear or underside of the console (a hole, near the console's center, that goes through to the electronics board. (This hole should not have a screw in it.)
  2. Insert a pencil (eraser end), into the hole and feel around for the cal button (will click when pressed).
  3. Press the button 2 times (with the pencil eraser). The first click should show CL11 in the console, the second click should show CL21.
  4. If the process was done correctly, and CL21 appears in the console, you are in "calibration mode." The next few steps consists of pressing buttons on the console and observing settings. This will not require any other tools.
  5. Press ENTER. CL22 should display in the TIME window and (??) in the SPEED window.
  6. Press ENTER. CL23 should display in the TIME window and (??) in the SPEED window.
  7. Press ENTER. CL24 should display in the TIME window and (??) in the SPEED window.
  8. Press ENTER. CL25 should display in the TIME window and (??) in the SPEED window.
  9. Press ENTER. CL26 should display in the TIME window. You should then see the letter "E."
  10. Press ENTER. You should see "SS" or "55" in the console.
  11. Push the STOP/START button. For safety, at this point, you should step off, or be off, the treadmill.
  12. Push the ENTER button. The walking belt should start to move, accelerate to maximum speed, then stop on its own.
  13. When the belt stops, the incline should self test by raising to its highest incline position, then lowering back down to its lowest position.
  14. Once the incline test is complete, push the POWER button 2 times. The unit should shut off and the console should go completely blank. If this happens, the treadmill is done calibrating and is ready for use.
If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the "F" appeared in). Troubleshooting the failure would be the next step. The Calibration seq
God bless you
May 22, 2013 | Nautilus T914 Commercial Series Treadmill
Nautilus NTR 800.6 Treadmill. I can go up on speed and incline but not back down?
please RUN the software calibration, for easy diagnose, troubleshooting, and fix it.
Test the speed sensor, for open or faulty, clean it, and tight the connector very well. see the diagram
Happy New Year. God bless you
Jan 01, 2013 | Exercise & Fitness
My 2 yr. old grandson falls asleep and his head falls forward everytime. Looks uncomfortable. His mother has a Britax carseat and his head does not do this with this carseat. We both drive new Mercedes...
I would say it is just the incline of the type of carseat or the type of side wing things on either side of the head. I have seen a small u shaped neck pillows in the stores that may be able to help they come in different animals and are soft and pillow like.
Aug 11, 2017 | Graco Nautilus 3-in 1 Car Seat
GE Nautilus dishwasher. Doesnt seem like motor is working
Dishwasher (Nautilus) not draining into sink but leaks onto floor.
Nov 10, 2009 | GE Nautilus 24" Built-in Dishwasher
Parts for nautilus fans
Broan is the company to look for when looking for parts for a nautilus fan. You can check out www.broan.com. If you can't find them Broan this company will help you find them. http://www.centralvacuumstores.com/fan_help.php
Oct 15, 2009 | Nautilus Dryers
My Trimline treadmill 1050.E2 is showing an 'E2' on its screen and not working any more.
Hello all,
I have the same issue - it Shows "E2" on the time Display...
I already checked the Speed sensor and inclination potentiometer and both are OK... Moreover, I found that EEPROM Memory (Microchip 93LC46) is broken (reads "00"). After replacing it, I Need a way to reset / recalibrate the treadmill. I found on some Forums that there shall be a key combination (Speed+ & Start / Stop or similar) but None works for me. Could you please (if available) post the User Manual page describing the calibration entry? Or, maybe, advice a way to calibrate the 1050? Even the EEPROM Content (I guess the it is an issue) will be really helpful. Thank you in advance,
Milos
Oct 06, 2009 | Nautilus Exercise & Fitness
GE Nautilus Dishwasher - NO water coming in at beginning
Normally,if water doesn't come in, cycle should not go on ! Add water by hand to tub and operate the dishwasher. Let us know with your results and we will see how could we assist you.
Aug 03, 2007 | GE 25 in. Nautilus GSC3400J Free-standing...
Nautilus Commercial Series T916 Treadmill Logo
13 people viewed this question
Top Nautilus Exercise & Fitness Experts
David Payne
David Payne
Electro Med Services...
Techmotionusa.com
Techmotionusa.com
Are you a Nautilus Exercise and Fitnes Expert? Answer questions, earn points and help others
