Question about Westinghouse Refrigerators
Silhouette manual Removing door handles
2 Suggested Answers
cadman000
  • 607 Answers
SOURCE: Removing manual window handle at door panel
Uses a "c" clip to secure window handle. Requires a special clip removal tool, that can be purchased at the parts store. Hope this helps
Posted on May 23, 2009
My drivers side door outside handle will not open door, but inside handle works fine. What would be the problem?
Hi kisha , The handle broke inside the door where you can't see it .Common problem on cars . You can get one new for $19.00 on eBay or probably some auto parts stores too. Would have to take the inside door panel off to get at it. You could go to YouTube an watch a video on how to do it !
Feb 04, 2015 | 1992 Oldsmobile Silhouette
How do you remove passenger sliding door handle on oldsmobile silhouitte
The process of removing car door panels is essentially the same for each make of car. You may need to remove these panels when your fixing locks or power windows, replacing window cranks, installing speakers or replacing the side mirrors. Learning how to remove the panels yourself can save money on simple car repairs.
Related Searches:
Difficulty: Moderately EasyInstructionsThings You'll Need
  • Set of screwdrivers
  • L pick
  • Small flashlight
  • Ratchet and socket
    • 1
      Check out how the door panels are attached to the car. Most panels use screws and bolts but others have snap-in fittings. Gather all the tools you need for removing the door panels. If the panel is attached with screws and bolts, you need a screwdriver or ratchet and socket. Car door panels with snap-in fittings are easily removed with a flathead screwdriver.
    • 2
      Locate where the screws and bolts are before starting. These are usually found in the arm rest area, along the bottom or sometimes near the door lights.
    • 3
      Roll down the car door window. Begin removing all screws and bolts that hold the door panel onto the car. If your car has snap-in fittings, pry gently on the bottom corner of the door panel until the fittings pop out.
    • 4
      Remove the power window control panel if your car has power windows. The control panel should pry out easily, and then you unplug the wiring harness from the back and place it to the side.
    • 5
      Use an L pick and flashlight when locating a manual window crank. Look behind the window crank and slide the pick under the edge of the metal clip that holds the crank in place. Remove the clip and pull the crank off.
    • 6
      Remove the door handle by unscrewing the small screw located in the center. Gently pull the door handle out until you see the back of the handle and unclip the rod from the door handle. This should remove the handle unless the handle and door lock are attached, then you just unclip the rod from the lock and remove them both together.
    • 7
      Unscrew the cap off rear upper corner door panel locks. These don't have a rod attaching them to the handle and unscrew separately from the door handle.
    • 8
      Pop the door panel off after you've removed everything. Gently pry on the bottom edge of the door panel until it releases. Pull out and up to completely remove the door panel.
Jan 10, 2012 | 1998 Oldsmobile Silhouette
The door handle on the driver's side is broken...if you try to pull the handle the door does not open, you need to open it from the inside to get it open. How do we fix it?
1. You need to remove the door panel on the inside of the door first.
2. Make sure the window is all the way up.
3. Remove approximately 2 or 3 screws and the rod that is attached to the handle from within the inside of the door.
4. Replace with new handle attach screws and attach rod.
5. Put door panel back on and your done.
Oct 11, 2010 | 1990 Oldsmobile Silhouette
Replacing mirror on 1998 Oldsmobile Silhouette
you'll need to remove your door panel (screws are by the door handle, arm rest, under door and side of door) and remove the cover adjacent to your mirror to remove the bolts to remove the mirror.
Aug 12, 2009 | 1998 Oldsmobile Silhouette
Removing door panel
Manual window crank handle is held on with spring type " C " clamp . A special door handle clip removal tool is required. Inexpensive and easy to use. To reinstall handle , PLACE CLIP BACK INTO HANDLE GROOVE AND PUSH BACK ON. Hope this helps
Jun 14, 2009 | 2003 Pontiac Grand Am
05 caravan passenger power sliding door will lock but not open
READ YOUR MANUAL. THERE IS A SEQUENCE INVOLVING REMOVING A FUSE WHICH RESETS THE ELECTRIC DOOR OPENER. IT IS DESCRIBED IN THE MANUAL. EASY TO DO ONE YOU HAVE THE BOOK IN HAND.
Apr 15, 2009 | 1997 Oldsmobile Silhouette
2002 Old Silhouette Driver Power Sliding Door will not open
Look in your owners manual there is a procedure to reset the door controls. If that dosen't work maybe the motor is burnt out, it's in the left rear access panel.
Mar 25, 2009 | 2002 Oldsmobile Silhouette
My driver side mirror broke off on 1999 olds silhouette can't get door panel off found 2 bolts anything else or just force loose?
If you removed the 2 bolts near the handle (1 you reach by removing the lock & pwr windows control panel by prying it up, it will pop loose) there are plastic bolts/clips that press in through openings around the edge of the door panel. Just pry out slowly and they should pop out. Work your way around the door. It should slide off over the release handle which you may want to pull outward so it slides over it easier. I just did this 2 days ago to replace my passenger mirror.
Mar 08, 2009 | 1999 Oldsmobile Silhouette
Passenger power sliding doors won't open
most likely it is the child safetyy lock next time the door is open make sure the child safety is in the off setting
Aug 15, 2008 | 1997 Oldsmobile Silhouette
Refrigerators Logo
206 people viewed this question
Top Westinghouse Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Westinghouse Refrigerator Expert? Answer questions, earn points and help others
