Question about Compaq Computers & Internet
What keys will allow the use of an external monitor?
I have a Compac Presario V2135US with windows XP. What keys do I need to hold down to display things on an external monitor?
  • 112 Answers
Fn+f4 hotkeys will switch the image among displays
http://h10032.www1.hp.com/ctg/Manual/c00568473.pdf
Posted on May 21, 2009
My compac presario CQ57, got diet coke on it thanks to my 2 yr old. Nothing comes up on the screen. However it does power up and I can hear sound. Any fix for this?
Maybe you got lucky and only the lcd inverter got fried. Try the steps below.
Shine a flashlight on the dark screen to see if you barelysee the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can beany kind of monitor even the old big fat crt monitors as long as it has a vgacable to connect to your computer's vga port. If so that proves yourvideo card is ok. The video will show on most systems when you rebootwithout you having to do anything. Some systems will require you to hit the FN(Function key) + F1 thru F12. Hold down the FN key then hit the correctkey for displaying on the monitor (F1 thru F12). The correct key willnormally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works,then your screen is bad. If you see no icons by shinning the flash lightand nothing shows on the external monitor, then most likely your video card isbad.
May 30, 2012 | Compaq Computers & Internet
How do i connect compaq presario x1000 to external monitor
Hi Judy,
The Compaq Presario x1000 notebook offers connections for external displays at the rear below the screen hinge as show in the picture below:
Identifying the back from left to right: Ventilation slots, External VGA Port, S-Video Port, USB Port, USB Port, RJ-45 Network Jack, RJ-11 Telephone Jack, Parallel Printer Port, USB Port and 1394 (a.k.a. "Firewire") Port.
You can connect a VGA monitor to the VGA port (blue colored jack) very easily. Any analog VGA monitor should readily connect to it. Additionally, the x1000 can output its display to TV or other monitor that accepts "S-Video" signals. An "S-Video" cable will be needed to connect between the "S-Video" jacks on the notebook (next to the VGA Port) and one on the TV. It is important to note that not all TVs support both or either "S-Video" or VGA inputs. When ever the there is a choice of using S-Video or VGA on a TV or monitor, the VGA will provide the best looking picture, and should be used.
I hope this helps and good luck! Please rate my reply - thanks.
Oct 03, 2011 | Compaq Presario X1000 Notebook
Is it possible to bypass the built in screen monitor(compac 7770 DMT) and connect to another computer monitor. I bought my laptop at the local goodwill store and the monitor just looks like wet splatter....
1) connect your external monitor to the 7770DMT and switch it on
2) boot up the laptop
3) after it has successfully booted, you need to identify which function key toggles the external monitor on/off
4) you should be able to do this by holding down the Fn key and trying each of the F keys in turn, waiting a few seconds after pressing each one
5) begin by holding down "Fn" + "F3", "Fn" + "F4", "Fn" + "F5" etc.
Oct 18, 2010 | Compaq Armada 7770DMT Notebook
I would like to hook up my compaq presario v2000 to an external monitor/tv What cord would I need and where would I plug it in?
Connect the monitor cable to the D-type connector on the laptop. Once the monitor is connected to the laptop. Hold down the Fn key on the keybaord and tap on the F8 key to toggle the display on the external monitor
There are three stages of the Fn+ F8 key
1, Exterenal only
2. Laptop + External screen
3. Laptop only.
Thanks for using Fixya
Proton
Sep 06, 2010 | Compaq Presario M2000 Notebook
Lcd screen stuck in external screen mode
How to use the function (Fn) keys on the keyboard - ThinkPad T40, T40p, T41, T41p, T42, T42p, T43, T43p
Switching the display output location.
Switch between the computer display and an external monitor. If an external monitor is attached, the computer output is displayed in the following three patterns by turns:
  • External monitor (CRT display)
  • Computer display and external monitor (LCD + CRT display)
  • Computer display (LCD)
Notes:
  • For any operating system other than Windows 2000 or Windows XP, no additional procedure is needed. Just press Fn+F7.
  • This function is not supported if different desktop images are displayed on the computer display and the external monitor (the Extend desktop function).
  • This function does not work while a DVD movie or a video clip is playing.
To enable this function in Windows 2000 and Windows XP, the following procedure is needed:
  1. When you log on to Windows 2000 and Windows XP for the first time, press Fn + F7 and select a display-switching function in the Initial setup window. Since in Windows 2000 and Windows XP multiple users can log on to a single operating system by using different user IDs, each user needs to select the function in the initial setup window when logging on for the first time.
  2. If the Fn + F7 key combination have been assigned to a presentation scheme function, start Presentation Director, and change the settings.
Feb 28, 2010 | IBM ThinkPad T41 Notebook
MY PRESARIO V3000 WITH WINDOWS VISTA COULD NOT DETECT EXTERNAL MONITOR/PROJECTOR
Try pressing your fn key and f4.Also right click on desktop, click nvidia control panel, make sure all external monitor or projector is hooked up,click on multiple displays,you should see a drop down menue telling you to select wich display to use. Hope this helps.
Jan 24, 2009 | Compaq Presario Notebook
Black screen!
lets check a couple of things. I'm sure you know that a laptop can be hooked up to a external monitor or projector, There is a button usually F5 Or close to it that will turn your monitor off and send it to the external one. In some models of toshiba this will stay in effect even when you turn it off. You can toggle this setting by holding the FN key down and pressing the appropriate "f" key. try this first before you chuck it. There also may be a problem in the bios. Let me know how it turns out. Take care..Be mucho blessed... Mark
Jun 28, 2008 | Compaq Presario R3000 Notebook
Blank screen
I think your LCD is stuffed is it under warranty do you know BUT if the screen is cracked they wont replace it typical HP. To get your external monitor running hold down the function key and the blue monitor looking key similtaneously normally on compaq its the F4 key but look around your keyboard (looks like a monitor) and is blue letters.
Sep 18, 2007 | HP Compaq Presario V2000 Notebook
Computers & Internet Logo
108 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
