Question about Mitsubishi WS-55809 55" Rear Projection Television
Mitsubishi ws-55809 code "22" - how to repair
Slinteriors
  • 8617 Answers
SOURCE: error code 22 on a Mitsubishi WS-55907 55'' HDTV
your set is the V17 series so a code 22 means short protect. Which means the TV has a short circuit condition and is shutting down to prevent further damage. You can get a manual for the V17 sereis at the following link for 15.99 and they will provide free unlimited support to help you with the diagnosis and locating parts. Your set is coverd in the V17 sereis service manual under the mitsubishi section. Here is the link in case youd like the service manual and free support.
http://servicemanuals.vstore.ca/
Posted on Mar 08, 2008
welcomejee
  • 10594 Answers
SOURCE: Mitsubishi tv model WS-55809
wdweber,
Its usualy convergence problem and needs to look dry solder joints in convergence board.
Posted on Jul 20, 2008
SOURCE: Mitsubishi ws 55809
Hi, after lookin in the service manual I have a question. I tested th see if the fuses were shorted, however... I'm not completely sure how these fuses work, since most fuses are shorted to begin with... Are they resistive type fuses of some type? Just looking for insight. Thanks
Posted on Jul 31, 2008
SD Tech
  • 14553 Answers
SOURCE: Mitsubishi WS-65857 has a trouble code 22 which I
2, then 2 blinks is short protection.
Usually this means in this set one of the two pico fuses that protect the convergence circuit is blown.
This model uses two of the STK-392-570 CONVERGENCE IC'S.
What you need to do first if you are able is remove the back cover and locate the fuses---I can tell you where they are on the board. Check both of them just like you would check any fuse. If either or both are blown----you have found your problem. The set will detect if either or both are bad that no voltage is reaching the Convergence circuit and it will shut off.
I can tell you the least expensive place to get the parts and I have step by step start to finish instructions for this repair if you are handy and know how to solder etc.
Considering the total parts cost would be under 25 dollars--if you can do this repair you can save a lot of money--most shops get 300-400 for this kind of repair----I know as I have done hundreds of these repairs----did a Mitsubishi a few days ago with the same two chips bad---about one hour for me in the customer's home.
I have photos of the fuses and location also--if you decide you want the instructions and photos we will find a way to get them to you. I am not permitted to give MY email address here--if you know what I mean.
If you have ANY QUESTIONS OR WANT the instructions etc---let me know--I am here to help and I do know a lot about this type of set.
First thing is for you to find out if either of the fuses is gone----if they are----you MUST change both chips and or fuses etc.
SD TECH
Posted on Oct 21, 2009
  • 8457 Answers
SOURCE: My Mitsubishi HD 1080 Model WS-55809 - the colors
Ur convergence it dead.U know how to solders?Buy a convergence kit.These websites have the kit.Tv repair World.com,Tv repair kits.
Posted on Dec 12, 2009
I have a projection television ws 55809 it turn off everytime i try to turn it on i did the test an 22 was the code what is it and how do i fix it
What you have is short protection--it means one of two pico fuses on the middle board is bad and it and the two STK-392-570 chips it uses for convergence are going to have to be replaced and the set adjusted with the Mitsubishi remote.
This can be a do it yourself repair for some people with basic skills and parts cost from a site I know will be under 30 dollars.
In addition I have my own start to finish, step by step instructions for this which are available if you provide a email address.
They tell you everything you will need and precisely how to do the repair. Once you have and read them you can decide if you can do the repair or not--shops usually get over 200 dollars parts and labor for this repair.
I attach a photo of the fuses (on middle board) and what the chips look like (also on middle board at the front)
12_18_2012_12_41_53_am.jpglike this but will have the 570 number on them.
Dec 17, 2012 | Mitsubishi WS-55809 55" Rear Projection...
Ws 55809 with a 2,1 error code. machine has been flickering green screen more frequenly. not you turn it on get white screen then it shuts off. is this nachine repairable? please help.
2,1 IS x-ray protection, problem is either in the High Voltage circuit or with one of the three picture tubes.
It should be repairable but most likely a shop job.
SD TECH
Oct 01, 2010 | Mitsubishi WS-55809 55" Rear Projection...
My Mitsubishi HD 1080 Model WS-55809 - the colors are distored. The picture is like double vision. For example the menu words all have yellow & red shadows.
Dec 12, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Are there any repair companies close to me zip code 46235. That could work on Mitsubishi WS-55809 55 in
I don't know, but here is Mitsubishi's Customer Service Phone number and I know they could tell you.
1800-332-2119
I hope this helps,
Skyassoc
Oct 24, 2009 | Mitsubishi WS-55809 55" Rear Projection...
I have a mitsubishi ws-55809 power comes on and then goes off
try to check it again as these are the only codes for your model.
3. Error Codes
The Error Code designations indicating a malfunction, or no malfunction, are listed below:
“12” ... indicates no error has occurred.
“21” ... X-Ray Protect circuit.
“22” ... Short Protect circuit.
“23” ... Horizontal Deflection failure.
“24” ... Vertical Deflection failure.
Mar 14, 2009 | Televison & Video
Mitsubishi WS-55809 2-2 code
look on the center board where the ics are and check F9A04 and F9A05 pico fuses, if they are blown you will need to replace those two 5 Amp picos and the convergence Ics
Nov 09, 2008 | Mitsubishi WS-55809 55" Rear Projection...
WS-55809 TV Won't Come On W/Fault Code 22
replace the fuses again and the IC8c01 and IC8C02 all together
Nov 03, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi ws 55809
22 is short protect usually its the convergence Ics in that model that can short out. check fuses F9A04 and F9A05 if they are open its most likely the convergence ICs that need repslacing. If you need further assistance, please reply to this same post.
Jul 29, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Green Gun does not come on
my tv comes on but it says your input is locked enter your 10 diget code press enter but i dont no it
Jul 16, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi WS-55809 55" Rear Projection Television Logo
41 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
