Question about Innovage Jumbo Remote Control
Need codes for Westinghouse sk32h640g - Innovage Jumbo Remote Control
Where is the headphone jack
As far as I can tell, there is no headphone jack. But, there is a 3.5mm PC Audio jack used as a line-in for audio from a computer (or any other device that uses a headphone jack to output). It is located to the right of the PC/VGA port and below the HDMI ports. Here is a link to a picture of the rear of the TV:
http://asset2.cbsistatic.com/cnwk.1d/sc/33852346-2-440-DT1.jpg
Jul 13, 2014 | Westinghouse Electric SK32H640G 32"...
TV says " no signal"
Just Check the cable and make sure it is connected properly to the TV and from the source. Otherwise if the problem persist, then you might consider changing the cable or replacing with a new one.
Sep 08, 2013 | Westinghouse Electric SK32H640G 32"...
Need codes for westinghouse LD-3240
The code is under Samsung. I have the same tv.
Nov 26, 2011 | Westinghouse Televison & Video
I dont have any sound
Hello, without asking you loads of Q's about how you're connecting it to to your computer etc, don't forget you have to connect a cable from your computer's audio card output to your monitor's audio input connector in order to get the sound to come out of the monitor's speakers. Hope this helps! Regards
Nicam49
Aug 03, 2011 | Westinghouse Electric SK32H640G 32"...
The conyrol of my tv, westinghouse model sk:19H2105 IS BROKEN AND I NEED A CODE TO USE A UNIVERSAL CONTROL PLEASE HELP ME, THANK, YOU.
Hello
WHITE WESTINGHOUSE Codes: 097/ 100
Four digit codes for white westinghouse are : 0100 0130 0138 0136 0227 0279 0080
four digit codes for wetinghouse are: 0143 0114
OK
Jul 25, 2011 | Televison & Video
Screen went blank, all else works
post your problem clearly to solve. no display at all or it comes and fade of., check your monitor by unplugging VGA cable from your CPU and it displays nothing to diplay, colour codes any one of this
Mar 12, 2011 | Westinghouse Electric SK32H640G 32"...
The red light is on...so TV is getting power. Will not turn on via remote or manual push button. Usually light turns to blue.
The standby 5vdc is working but nothing else, it can be the bad caps in the power supply, bad logic in the main board, or shorted circuits in the inverter boards.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Dec 06, 2010 | Westinghouse Electric SK32H640G 32"...
Tv picture goes out after about 4 seconds
Westinghouse has had major issues with their Variable voltage power supplies (power inverter). Unless you have the technical skills to delve into individual component testing I would suggest finding a different brand to purchase. NOTE: Stay away from Toshiba; it has the same problem!
Sep 24, 2010 | Westinghouse Electric SK32H640G 32"...
Living soluttion codes for my westinghouse tv
The remote codes for a Jumbo Remote Control and a Westinghouse TV are 097, 100, 130, and 155.
Oct 10, 2009 | Innovage Jumbo Remote Control
Innovage Jumbo Remote Control Logo
19 people viewed this question
Top Innovage Televison & Video Experts
Computer Repairing
Computer Repairing
Electro Med Services...
Are you an Innovage Televison and Video Expert? Answer questions, earn points and help others
