Question about HP Officejet Pro L7590 All-in-One InkJet Printer
Says that I need ink even though I just replaced it
MY HP OFFICEJET PRO L7590 SAYS TO REPLACE THE INK, EVEN AFTER I HAVE INSTALLED A NEW CARTRIDGE. I HAVE REPLACED IT 3 TIMES IN A DAY!
Replace all the ink cartridges??????? If this is HP's idea of how to sell more ink my printer will be floating down the Ohio River very shortly.
Posted on Apr 24, 2011
    Scholar:
  • 191 Answers
to resolve the issue please replace all the ink cartridges and clean the print heads and reinsert the cartridges and align the printer. Click here for instructions to replace the ink cartridges.
Posted on May 22, 2009
Error message the following ink cartridge is not intended for use
I would replace the ink cartridge in question because each one has it's own circuit board and it appears you have a conflict in the printer.
Mar 06, 2012 | HP Officejet Pro L7590 All-in-One InkJet...
Bypass expired message cartridge. Cartridge is less than six months old & nearly full.
Every cartridge will have its own ID and Expiry date, please check the Cartridge expiry date, if its really expired then printer will reject it even-though the cartridge is full.
We cannot bypass cartridge errors for single cartridge in INK-JET printer, because they work in TIJ technology (Thermal Ink Jet) which needs all cartridges to be functional unlike Laser-jet printers.
Regards
Riztech
Jan 13, 2011 | HP Officejet Pro L7590 All-in-One InkJet...
I refilled HP 88 cartridge but printer (Officejet Pro L7590) still thinks cartridge is empty. How do I reset ink level?
Under the cartridge is a black like pump - on a new cartridge this is hard and rests firmly on an area inside your printer. As you print, the pump becomes softer - this is how the printer determines it is empty. Once refilled, the pump does not get back to the original state. Open the bottom of the cartridge and put a firm solid piece of folded paper in there - make sure it is steady and re-close cartridge. It will now read as full but may also show full - judge ink levels by the quality of print. Also make sure chip has not expired.
Nov 05, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
The chip on the cartridge needs to be reset. You can find replacement chips on the internet but they cost about half as much as a new cartridge. Also, if you filled the cartridge incorrectly you can get air in the ink lines of your printer which will make it unable to print that color. Overall, I would recommend getting refills from Cartridge World. They always reset the chip, take care of the mess of filling for you, cost less than new cartridges, and are 100% guaranteed to work.
Nov 05, 2009 | HP Compaq 6710b Notebook PCw/ OfficeJet...
For some reason my HP Officeject Pro K8600 is reading empty yellow ink cartridge even after I replace it. I have replaced the cartridge several times with a new cartridge but it still won't work. Why? ...
The mount that holds the spring for the yellow ink cartridge pump arm in the service station is probably broken. You will have to replace the ink-service station.
Sep 15, 2009 | HP OfficeJet Pro K8600 Printer
I installed a new black ink cartridge and printer printed a copy of pages just fine. Now it will not print black. We have had this printer for over a year and have never had this problem.
there is a specific place for injecting the ink in the cartridge through injection. but u have to purchase the ink from market specially for cartridge and inject it
Jul 07, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
HP L7590 black ink printing poorly even with new HP cartridge
I have had the same problem It is the print head not the cartridge If your printer is still under warranty have the printhead(s) replaced if not Open the unit where the print heads are and hold the OK button for 5 seconds. The Print head carriage will move to the left
Carefully remove the KY (Black & Yellow) Print head with a cotton swab and alcohol clean the contacts and replace the printhead. If this does not work remove the printhead and then with a spray bottle spray the nozzle area on the bottom (DO NOT TOUCH THE NOZZLES AS THEY WILL BE DESTROYED) HP techs have told me this will void any warranty so act accordingly I use a printhead cleaning solution available from most any online ink supplier
Replace the printhead after it has dried out (less than a minute). The printer will then go through an alignment cycle and should print I had to do this several times before the print head performed as it should
Apr 10, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
Blank Ink not pumping to print head
Turn off the device after removing the printhead After removing the printhead, turn off the device, wait about 20 seconds, and turn it on again without the printhead installed. After it has restarted, reinsert the printhead.
it will go through this long routine of perhaps 20 min or so. after its compleate it should print great.
Nov 22, 2008 | HP Officejet Pro L7590 All-in-One InkJet...
Printer claims black ink cartridge is empty, but it can't be.
Se if the tape, that comes with a new cartriage is of the cartriage if not try a new cartriage if the does not work your machine needs service
Jun 11, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
Inkjet refills
hi,
as you are using a refilled cartridge, it is causing this problem. the thickness of ink in a hp genuine cartridge and a refilled cartridge varies. and also the refilled cartridge may make your printer faulty. so it is good to try with a new hp genuine ink cartridges.
thanks and regards
agnel
Feb 14, 2008 | HP Officejet Pro L7680 All-In-One Printer
HP Officejet Pro L7590 All-in-One InkJet Printer Logo
844 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
