Question about Crafts & Hobbies
One end of board is thinner than the other end when plained board is done
    Genius:
  • 1,406 Answers
This is after running it over a jointer? That's not uncommon. Flip the board after every pass to help keep it from happening.
If this is after running it through a thickness planer, are you sure you're not just seeing snipe? If it's not snipe, then the planer's elevation adjustment is somehow slipping or working its way into another position as you plane.
It'd help if we knew which machine you're talking about.
If you're hand-planing, then you'll need to work a bit on technique... practice on cheap softwoods.
Posted on Jul 29, 2014
Philips tv jarred in drop
Tv's don't take rough treatment well,picture tubes and other displays break,circuit boards are easily cracked usually around heavy parts,that sounds like your type problem broken board,if the damage is not severe it may be possable a tech.can repair the broken copper traces but this is becoming more difficult with newer more densely packed circuit boards with thinner and thinner traces many are not repairable and even if a new circuit board is available from the mfgr.it will cost more then a new tv.Good luck
Feb 26, 2012 | Philips 27PT643R 27" TV
My ct6112 mobile got damaged with water, the service centre peoples said the main board should be replace, is it possible to recover the phone memory data with the new main board
yes
Remove your main board and repair it
Sink the board in thinner(a petrolium product) after you remove the camera (that if it has a camera)and mic and other parts
only sink the board >sink it in thinner for 3 days.
then get it out and dry it ..or you can leave it in the air for 5 min.
then re build it after you re plug in the camera and the other parts.
and clean the golden parts on the battery .you may will see GREEN dirt on them.clean it.
and put your battery then turn it on ...(This way works 85%)
May 17, 2011 | Cell Phones
WHEN PLAINING A BOARD IS COMING OUT WITH A UNEVEN PLAINING ON THE ENDS OF THE BOARDS ABOUT 3" TO 4" FROM THE EANDS.
this is normal with all planers, when you feed the board in the planer there are two feed roller one on each side of the knives so you get uneven pressure on the board at the start and at the end of the board .when planing boards for a project always add 10"inches or more extras then cut to lenght after planing to thickness required. never cut boards to length before planing .
Apr 11, 2011 | Dewalt DW735R Reconditioned Heavy Duty 13"...
How to clean mfc 8120
a minor cleaning can by done by removing the toner/drum unit and giving the machine a good blow out with a blower. Locate the paper pickup rollers and rub them down with a cloth and a lil white spirits or thinners (be carefull not to get the thinners on any plastic covers or pannels).
Dec 09, 2010 | Brother MFC-8120 Printer
Usb will not go into camera properly and can't
Are you using the USB cable that came with the camera or are you trying to use another USB cable. The camera end of the USB cable that comes with the camera is thinner than some after market cables. Check to make sure that the camera end is in completely.
You can shave the area around the plub so that the cable properly seats or get a better, thinner camera end cable.
Jun 21, 2009 | Canon Cameras
Adjust ladies citizen watch metal link band
If it is a metal link band, you can remove a few segments. Segments are connected by split pens. You should see a thinner end and a bigger end; or an arrow on the inside shows where the thinner end should be. Push the thinner end firmly with a pin or something until the big end pops out the opposite side.Use pliers to remove the pin.
Apr 12, 2009 | Citizen Eco-Drive BL006056H Wrist Watch
Take link ot of watchband
take it to a jeweler because if you do it your self your warranty is no longer valid
Jan 06, 2009 | Citizen Aqualand Duplex JP104009E Wrist...
Bar oiling problem
Just a thought: Is it cold where you are? At this saw mill where it is my job to keep chain saws running, learned years ago that you cannot use "bar oil" in winter. Need thinner oil, like motor oil. ....preferably a "non-detergent" motor oil, plain 30-weight is OK, HD30W will work, but the HD part causes the chain to stretch more so than standard bar oil. The bar oil literally is so thick in cold that it stripped the worm gear out of a Poulan Pro oil pump (plastic gear, anyways, wasn't much to begin with.) But thought you may want to try thinner oil, if it is cold where you are. Oh yea we also have 2-Husqvarna 359's with 20-inch bar, and use thinner oil in winter. Our Husqvarnas have an oil adjuster located on bottom, on clutch side. Straight slot screw adjustment.
Nov 18, 2008 | Husqvarna Chain Saw 20" Bar
Crafts & Hobbies Logo
395 people viewed this question
Top Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Debbie
Are you a Craft and Hobby Expert? Answer questions, earn points and help others
