Question about Samsung Televison & Video
Samsung dlp PB01 turns off repeatedly
I've heard that taping the blue switch behing the access control panel will "trick" the TV into thinking the panel is closed and thus stay on. should the switch be facing upwards or down? and is there a specific tape i should use? I used duck tape but I'm scared the heat may melt it
SOURCE: sony ccd-fx310
My camera won't play back.  Occasionally, if I ffwd it will show the picture otherwise its a blank screen.  Any ideas?  I've tried cleaning the heads a few times now
Posted on Feb 02, 2008
  • 147 Answers
SOURCE: TV won't stay on. Green & Red light timer-lamp (Green) stand by/temp (red) flash.
Most likely needs a new lamp. Easily done yourself.
Posted on Apr 15, 2009
SOURCE: Samsung DLP 62 inch turns off by itself after being switched on
I had the same issue but instead of shorting out the sensor, I removed the bulb assembly, cleaned the interior of the assembly and TV the best that I could with a vaccum and small paint brush. Once cleaned, I reinstalled the bulb assembly and the TV has worked for the last eight months with no problem.
Posted on Jun 27, 2009
nicknovikov
  • 100 Answers
SOURCE: I have a Samsung 43in DLP TV. Stays on for 5
check power board for looseconnections.
Posted on Jul 09, 2009
SOURCE: Philips micro system MCM390/37, when turned ON, try to read CD then TAPE and gets back to ECO-MODE
mine have the same problem
Posted on Jul 30, 2009
My Samsung DLP Tv turns off after about 3 minutes. What needs to be replaced?
i think it could be trip switch in the back of tv it should be a little blue button you can try put a bit of tape over the button it might work and if its that you can order a new one i put tape on mine and its still working
Feb 21, 2016 | Samsung HLS5086WX/XAA
I hope u can help me w a samsung HLR4667 DLP. It shuts down, after a minute or two. The picture is perfect, when it is on, and I have taped down the blue access panel switch, which I read could be...
Hello Glen Harrison,
Welcome, and thank you for using FixYa!
To answer your question: This sounds like a weak capacitor on the power supply board.
You are right though, I would recommend a Black Friday special! By the time you put in a $90.00 part with labor, you might as well purchase a newer unit.
Have a great day!
Nov 25, 2011 | Samsung DLP HL-P5663W 56" TV
61 INCH SAMSUNG DLP TV DMD WENT OUT HAD IT REPLACED AND LESS THAN A YEAR SAME THING TURNS ON AND GOES RIGHT BACK OFF SAMSUNG SAY THERE PARTS HAVE NO WARRENTY ANY ONE KNOW HOW I COULD CHECK TO MAKE...
check the lamp and make sure it isnt bad. are there any odd noises when it trys to turn on? it could be a color wheel failure 2 dmd failures would be very odd.
Jan 06, 2011 | Samsung HLT6187SAX 61" DLP HDTV
Samsung DLP turns on and off - cycle repeats
make sure put the lamp door back before trying to turn it on because they have switches on them that allow the tv to turn on. If that is ok you probably have a bad ballast.
Call a local tv repair shop to further diagnose the problem.
Dec 10, 2009 | Samsung DLP HL-P5663W 56" TV
I have a Samsung DLP 56" It will turn off by itself. However it is not consistent all the time meaning it will stay on for hours some of the time and others it will turn off frequently.
IN the back of the tv, where you replace the bulb is a plate with 4 screws. Unscrew and take off plate. there is a little switch there that goes up and down. I can't remember if you have to tape it up or down but turn the tv on and play with that switch. I'm not a tv expert but when i had bulb replaced on my dlp this is what i had to do. So basically that liitle switch is a safety switch and it needs to be locked down or locked up. i used tape. Hope that helps.
Nov 27, 2009 | Samsung DLP HL-P5663W 56" TV
We have a Samsung DLP 69'' TV and as above, it keeps shutting off. We just replaced the lamp, which did not fix the problem. It will go on for a minute or two, then the TV shuts off and all three lights...
Previous answers are wrong unfortunately. And I'm sorry you've spent the kind of money you have to fix it. Its actually a very basic, tiny, annoying cause. So much so you'll be quite angry when you hear it: When you open the lamp door on the back of the TV, youll see a small toggle type switch that gets pushed in when the door gets re-installed and allows the TV to turn on. This is to make the power shut off in case someone tries to access the lamp with the set on. If memory serves, the toggle on my 50" samsung was blue I think. You can use duct tape or something but I actually used a very small zip tie to hold the toggle in place for a neater, less ghetto-fabulous fix. NEVER had it shut off by itself since.
Jun 20, 2009 | Samsung DLP HL-P5663W 56" TV
Turns off by itself
Above answers are wrong. Its actually a very basic, tiny, annoying cause. When you open the lamp door on the back of the TV, youll see a small toggle type switch that gets pushed in when the door gets re-installed and allows the TV to turn on. This is to make the power shut off in case someone tries to access the lamp with the set on. If memory serves, the toggle on my 50" samsung was blue I think. You can use duct tape or something but I actually used a very small zip tie to hold the toggle in place for a neater, less ghetto-fabulous fix. NEVER had it shut off by itself since.
Jun 14, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung 50" DLP TV turns itself off
I had the same problem which also included the picture having streaks of red in it sometimes too. I found that both problems were due to the TV getting too hot inside. I bought a $7 small 4" fan from Walmart and pointed it at the back "door" of the TV (where the bulb can be replaced). Both problems have disappeared which I think is due to not letting the interior get too hot.
Not sure if there is an internal fan to cool the parts inside, but if there is it is not working well enough.
Jun 11, 2009 | Samsung DLP HL-P5663W 56" TV
take off the lamp access door on the back and find the safety switch that the door pushes on. unplug the connector from the switch and put staple into the connector to short out the cable. Switch is probably bad. worked for me. same problem.
Apr 07, 2009 | Samsung 61" Slim-Depth DLP HDTV
Televison & Video Logo
15 people viewed this question
Henry  Thomas
Henry Thomas
