Question about BUSlink (D-DW82-U2) DVD RW Dual Layer Burner
What dc voltage and wattage is required for a BUSlink D-DW82-U2
Looking to purchase a power supply for a BUSlink D-DW82-U2, need to know the proper voltage.
12 volt DC 2500 mA
Posted on Jan 14, 2015
How to find problem on vl470m will not power up
Unless you have an ESR meter and can check all the capacitors in the PSU for ESR, your voltage readings are not valid.
Apr 07, 2017 | Power Up Computers & Internet
Equilent for a zener diode (RD 30ESB2)
Zener diodes are invariably used as low power voltage regulators or as a voltage reference for voltage regulating circuitry.
Zener diodes are sold by wattage and reference voltage by numerous component suppliers and constructor stores and in theory the voltage is marked on them, though difficult to see and easily defaced.
Finding an equivalent for what appears to be a manufacturer's part number presents a rather difficult challenge. The official service sheet will probably provide the required voltage. Without that information you will either have to purchase the component from the manufacturer under the part number or experiment until the required value is discovered.
Mar 02, 2016 | Televison & Video
Input power for a Buslink dvrw812d-u2f
DC output 12V - 2A / 2.5A. Center tip positive.
Link to purchase a power supply:
http://www.buslinkbuy.com/product.php?prod_id=281
Mar 13, 2014 | BUSlink Computers & Internet
Wht kind of current comes out?
The computer's switch mode power supply produces DC (direct current) electricity.
Nov 05, 2012 | Computers & Internet
Lost or misplaced power supply for Beyond Micro Micro Model BMMDU2 External hard Drive. Need info on Wattage input. Please and Thanks if you're able to hrlp.
Well, looks like Beyond Mico web site has gone to the great Beyond.
From units I have been able to find online, it looks like the power supply is between 20 and 40 watts.
The hard drive unit itself should be able to supply you with the required DC input voltage (hopefully there is some kind of label on the enclosure).
You could try one of these or something similar. It comes with 6 interchangeable heads and has adjustable DC voltage. This is just one of many available.
http://www.amazon.com/Hosa-ACD477-100-240V-Voltage-Adaptor/dp/B000Z31G3M
I cannot guarentee any of these supplied heads will fit your particular drive (same with the dc voltage). But some local retailers often have these types of adapters and you might be able to determine what size you need by looking at one.
I have used DC units similar to these in the past when I have lost a power supply.
Hopefully with a minimum of effort you can get a working solution.
Dec 28, 2010 | Beyond Micro Mobile / 250GB / 7200 / 8MB /...
Dc-in... how many volts need to work the external floppy drive model fddi?
You usually need 5 volts and 12 volts, DC. OR if it is only a single input, then usually 12V DC
Jan 28, 2010 | BUSlink (FDD-1) External Floppy Drive
I'm going to Europe and wanted to know how to convert electricity so when I plug in my computer it won't fry the computer
This is a copy from the Radio Shack site. The quick answer is go to pretty much any electronic store or most travel stores and buy a Foreign Power Converter.
AC to AC Power Conversion (Foreign Voltage Converters) Purpose of Converter / Explanation of Operation AC-to-AC voltage converters, or travel converters, are designed to convert the voltage used in a foreign country to the voltage required for a particular AC device. These converters are either transformer-based or solid-state, and this affects what type of devices the converter can power. In addition to converting the power, you will often need to also use a plug adapter. Plug adapters are generally either built into the converter, or provided as separate parts. They are also sold separately, for use with multi-voltage devices that are designed to convert the power internally.
Selecting a Converter These are one of the more confusing of the power conversion devices. Because of the range of voltages, plug types and converter designs, many customers find that they need help determining exactly which converter they need. To aid in that process, we have put together a short worksheet to help you determine what type of converter is needed: We recommend that you print out thi sheet when taking a number of different devices to a different country.
First, you should determine the electrical requirements (voltage, frequency, and wattage) for the device(s) you will be taking with you. This information is generally on a label or embossed into the back or bottom of the device. Make a note of the voltage(s), frequency or frequencies, and the wattage indicated for each device.
  • The voltage may be given as either V, VAC or VDC. The standard voltage for US devices is 120 V. Devices that are designed to operate using different input voltages will be labeled, such as 110/120 V, or 120/240 V.
  • The frequency will be given in Hz. The standard frequency for US devices is 60 Hz. Devices that are designed to operate using different frequencies will be labeled, such as 50/60 Hz.
  • The wattage will be given in either watts (W) or volt-amps (VA). If the wattage is not listed on the device, you will need to contact the device's manufacturer for this information. If you have the maximum current consumption (in amps), you can calculate the wattage by multiplying the voltage (V) times the current consumption (A).
Next, you will need to know the electrical requirements for the country you are going to be visiting.
Next, you will need to compare your equipment requirements to the country's information to determine whether you need a Step-up or Step-down Voltage converter.
  • If your equipment accepts the voltage and frequency provided by the country you will be visiting, then only a Plug Adapter will be required.
  • If the voltage of the target country is higher than the voltage required by your device(s), you will need a Step-Up Voltage Converter.
  • If the voltage of the target country is lower than the voltage required by your device(s), you will need a Step-Down Voltage Converter.
Once you know what type of converter or adapter you need, consult our list of travel power conversion products to find one that meets your requirements.
Cautions
  • The AC outlet in many foreign bathrooms is for low-wattage devices only. To avoid damage to your converter and/or attached device, check with your host or hotel before powering a high-wattage device (such as a hair dryer) from this plug.
  • Do not use a voltage converter with electronic devices such as televisions, VCR's and computers unless the device indicates that it can handle both 50 Hz and 60 Hz.
  • Do not use heating appliances, such as hair dryers, irons and coffee-makers, on a transformer-based voltage converter.
  • Do not use non-heating electronic devices, such as calculators, electric razors and portable audio players, on solid-state voltage converter.
  • Do not use 110-120 VAC Surge protectors or Uninterruptible Power supplies on a 220-240 VAC system. Even with a step-down power converter, damage could occur as the two power systems are wired differently.
Sep 22, 2009 | Toshiba Satellite L305D-S5895 Notebook
Need to know the Power (Voltage) for buslink
Go to the Buslink WEB site, their support/contact page to requst info and or replacement power adapter.
www.buslink.com
Nov 26, 2008 | BUSlink Computers & Internet
BUSlink (D-DW82-U2) DVD RW Dual Layer Burner Logo
213 people viewed this question
Top BUSlink Computers & Internet Experts
David Payne
David Payne
Are you a BUSlink Computer and Internet Expert? Answer questions, earn points and help others
