Denon instructions changing the fm tuning steps to 100KHz from 200KHz
Have Denon AVR-2313ci receiver. FM tuner quit working; will tune in 50 MHz steps, on every step "stereo" and "tuned" are lit but no sound comes out whether actual station or not.
There is no module per se. Tuning is accomplished by applying a voltage to the tuner chip and their associated circuits. It needs to be repaired by a Denon service center.
Oct 25, 2016 | Denon AVR2313 7.2 Channel A/V Receiver
FM frequecy increases/decreases too mugh pr. step
Hi, Your post/description "the frequency increases in steps of .2 Mhz or 200Khz" refers to the increment of frequency spacing between tuning steps and is largely dependent on the radio standards of the country/region the radio is intended to be used. Assuming no hardware fault to the radio, tuning steps may be adjusted by: 1. With the radio switched off, press the Step/Band button for about 2 seconds. This will display the current FM tuning step (200Khz as in your case); 2. With the radio switched off, press the Step/Band button for about 10 seconds. This will display FM and a blinking 50Khz with a single beep sound. By rotating the Tuning Control you can increase or decrease this value. 3. pressing the Step/Band button again will move you to the tuning increments of the AM band again adjustable via the Tuning Control. 4. pressing the Step/Band button again will save the setting and complete the process. Hope this be of some help. Good luck and kind regards.
Sep 13, 2007 | Makita BMR100 Radio
Change radio setup to scan frequency from evry 200khz to evry 50khz
  1. Radio ON, tune to the XM channel 0 and record the radio ID. The radio ID will be required for activation of the new receiver.
  2. Call XM radio to deactivate the faulty receiver and activate the new receiver.
    • US: 1-800-556-3600
    • Canada: 1-877-438-9677
  3. Park the vehicle outside in an area with an unobstructed view of the southern sky.
  4. Leave the vehicle outside with the ignition switch in the ACC position and the radio ON, tune to the XM channel 1 for 30 minutes to activate XM service.
  5. Once activated, the radio will receive the remaining XM channels.
  6. XM is trade mark
Sep 09, 2014 | 2010 Chevrolet Spark 1.2
Using Denon AVR 2803 as an FM receiver
• Insure that the speaker system is working.
try it on other receiver.
• Check to see if there are headphones connected.
• Check if tuned is lit
Aug 12, 2012 | Audio Players & Recorders
How do i change the AM radio to FM?
Hello
Press RADIO BAND.AUTO PRESET until the band you want appears in the display (direct power on). Each time you press this button, the indication changes as "FM" --> "AM". Hold down TUNE + or --, until the frequency digit begins to change in the display. The player automatically scans the radio frequencies and stops when it finds a clear station. If you can't tuned in a station, press the button repeatedly to change the frequency step by step. If FM broadcast is noisy, press "MODE" until "Mono" appears on the display and the radio will play in monatural without any noise. Only strong FM signals can be decoded to stereo. OK.
Oct 22, 2011 | Sony CFD-S300 Radio/Cassette/CD Boombox
How do I preset the tuner for radio stations. I've never had a problem doing this with any other stereo. But what I think should work isn't!
Not very specific. Do you have the manual?
The following is from a VSX-03TXH manual. It ain't pretty but it may help.
I'm posting it in multiple parts due to space contraints.
37
Chapter 6:
Using the tuner
Listening to the radio
The following steps show you how to tune in to FM and
AM radio broadcasts using the automatic (search) and
manual (step) tuning functions. If you already know the
frequency of the station you want, see Tuning directly to a
station below. Once you are tuned to a station you can
memorize the frequency for recall later-see Saving
station presets below for more on how to do this.
1 Press the FM/AM button to select the tuner.
2 Use the FM/AM button to change the band (FM or
AM), if necessary.
Each press switches the band between FM and AM.
3 Tune to a station.
There are three ways to do this:
Automatic tuning
To search for stations in the currently selected band,
press and hold TUNE ?©/?? for about a second. The
receiver will start searching for the next station,
stopping when it has found one. Repeat to search for
other stations.
Manual tuning
To change the frequency one step at a time, press
TUNE ?©/??.
High speed tuning
Press and hold TUNE ?©/?? for high speed tuning.
Release the button at the frequency you want.
Improving FM stereo sound
If the TUNED or STEREO indicators don't light when
tuning to an FM station because the signal is weak, press
the MPX button to switch the receiver into mono
reception mode. This should improve the sound quality
and allow you to enjoy the broadcast.
Using Neural THX
This feature uses Neural Surround™, THX® technology to
achieve optimal surround sound from FM radio.
• While listening to FM radio, press AUTO/DIRECT for
Neural THX listening.
Dec 23, 2010 | Pioneer VSX-07TX Receiver
Solam MP3 SL800E
Hello
How to use
1. Save your MP3 or WMA files into the car MP3 player directly from your computer.
2. Insert the 12 ~ 24V adaptor end of the car MP3 player into your vehicle's cigarette lighter
3. Choose you preferred frequency on your MP3 player, and then adjust your FM radio' s frequency same to the MP3's.
You should have received a user manual with your mp3 player, please read the manual, as with these chinese devices, we don't have the manuals to write down the instructions for you.
Jan 17, 2010 | Audio Players & Recorders
Frequency increases/decreases in steps of 0.2 kHz
Hi again, Seems you posted twice. A copy of my reply to your other post.... Assuming no hardware fault to the radio, tuning steps may be adjusted by: 1. With the radio switched off, press the Step/Band button for about 2 seconds. This will display the current FM tuning step (200Khz as in your case); 2. With the radio switched off, press the Step/Band button for about 10 seconds. This will display FM and a blinking 50Khz with a single beep sound. By rotating the Tuning Control you can increase or decrease this value. 3. pressing the Step/Band button again will move you to the tuning increments of the AM band again adjustable via the Tuning Control. 4. pressing the Step/Band button again will save the setting and complete the process. Hope this be of some help. Good luck and kind regards.
135 people viewed this question
 Grubhead
Grubhead
