Question about HP OfficeJet 6210 All-In-One InkJet Printer
Paper jam i was printing and the paper ripped and is now stuck
  • Andrew May 11, 2010
    Where is it **** at?
    Scholar:
  • 191 Answers
Please Click Here for instructions to clear paper jams and clean the rollers.
Posted on May 22, 2009
Printer will not print. says there is a paper jam but printer is completely empty
Check again. Sometimes you thing you got all the paper out but didn't. Did the paper rip when you removed it? If it did, check for small shred stuck in the jam sensor(s)
Aug 07, 2015 | Epson WorkForce WF-2540 All-in-One Inkjet...
HP j5780 printer sends "paper jam" message AFTER it prints one page. there is no apparent jam in all the places I have looked. I am in need of a repair manual (not an owners manual).
If you are getting a 'carriage jam' error as soon as you turn on your printer with no tasks in progress, then check for any piece of paper stuck in the carriage. Remove the paper carefully. If the paper tears, part of it might remain inside the paper path and damage the product.
Follow the steps for fix HP Printer Carriage Jam
Turn off the printer and open it to see where the paper is stuck.
Manually move the carriage toward the opposite side.
Check the paper path and remove any piece of paper or any other object that is stuck in the path.
Reconnect the power cord and turn on the printer.
http://www.fixya.com/support/t6088190-hp_7400_displays
May 12, 2010 | Office Equipment & Supplies
I am printing several pages and there is a jam. I
It will re-print it after you clear the jam. Just pull it out pulling slowly and evenly and it will come out.Also you can see directions on HP.com. Steven 818-888-0006
Mar 06, 2010 | HP LaserJet 3055 All-In-One Printer
Paper keeps ripping on the side on normal one sided printing. Duoble sided printing paper just rips up and jams.
sounds like some tron parper was stuck inside and has contributed to more paper tearing. First check for any paper jams, and check inside for and broken or damages items, causing paper to tear.
Nov 27, 2009 | HP Officejet Pro K8600dn - - colour -...
Paper jam. caused error print unable 30
"Machine Error 30" (or "Unable to Print") indicates either a simple problem such as a paper or part of a paper stuck inside the machine, which of course is solved by opening the machine as much as possible and remove the reason for the jam.
Even a ripped part of a paper will be able to cause the paper, so it's important to be careful when taking jammed paper out to not rip the paper (do this by carefully pulling the paper among the same way as it would go when printing, not the opposite direction).
However, if that doesn't work, the error is mechanical (but still most likely caused by the jam, either a sensor getting dirty and unable to do it's work, or actually getting broken), and there isn't much you can do. If the message comes back right after turning on the machine, you'll have to have service performed on the machine.
Jun 16, 2009 | Brother MFC 240C All-In-One InkJet Printer
Paper jammed
found the paper stuck inside and pulled it out with a pair of pointy nose pliers, very carfully so as not to rip the paper. I finally pulled straight out.
Mar 23, 2009 | HP Photosmart C6180 All-In-One InkJet...
Paper jam under print cartridges
Stick a 9x12 piece of cardboard down into the tray to force out unseen pieces of paper.
Jan 26, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Paper jam!!
Please perform the below steps.
1. Switch off the printer and disconnect the power supply. Allow any residual charge inside the all-in-one printer to dissipate before putting your hands or any metal tools inside the chassis.
2.
Pin down the exact location of the jam. The 3 hot spots for a jam are before a sheet completely leaves the paper tray, anywhere between the feed tray and print carriage or between the print carriage and output tray.
3.
Take off the front paper tray if the sheet jammed while still in the front area of the printer. If here, you should be able to see most of the paper.
4.
Pull the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a piece deeper inside the machine.
5.
Open the back panel to reach paper jammed between the feed-tray area and print carriage. Carefully remove the jammed paper.
put the cables back and switch on
Aug 25, 2008 | Brother HL-2070N Laser Printer
Paper stuck in brother printer
Which model printer.
Some printers have levers to disengage the traction to enable gently removing the jammed paper.
If you cannot remove it easily and it happens to rip try a trick I learned at a printing company: Re-construct the paper like a puzzle and dont stop looking for small pieces of ripped paper untill the puzzle is complete.
Good Luck.
May 02, 2008 | Office Equipment & Supplies
Printer keeps jamming
can you check to see if there is any paper piece's that might have ripped off a previous print stuck on the carrage bar, open the front flap and try to do a paper feed using the printer function buttions, thus elimiating windows printing... let on ;-)
Feb 18, 2008 | Office Equipment & Supplies
HP OfficeJet 6210 All-In-One InkJet Printer Logo
66 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
