Question about Kenmore Vacuums
Kenmore vacuum Model 346.2255180
Won't turn on
My Kenmore vacumn won`t turn on . worked fine one minute then stopped. The light works on the handle but no vacumn
You probably have a sensor that needs attention and is clogged up so unclog and see if that takes care of it
Jan 12, 2011 | Kenmore Vacuums
Is there an easy way to see if a drive belt may be broken? It's so difficult to push my Kenmore upright vacuum!
Well there is only turning the vacuum over and see if the brush is rotating.
If it is not moving then you need to replace the belt.
If you need to know how to remove the bottom plate to replace the belt, please post the model number, the numbers you posted above are not the kenmore model numbers, the model numbers will look like this
316135912,FPF311PHSB, FGF316WGSK
Feb 15, 2010 | Kenmore 35912 / 35913 Progressive Upright...
I have a model 116.35922 beltless drive vacuum. The agitator brush will not turn with the vacuum running and the handle down. The brush turns by hand and the reset button has not popped. Ther is nothing...
I just had the same problem. The roller will not turn if the unit is overheated. I discovered that my bag was too full. I changed the bag then the roller started turning again. I don't know if this is true cause and effect, but it couldn't hurt to try.
Aug 23, 2009 | Kenmore Vacuums
Kenmore Vacuum cleaner #175.3866180 bags and belt
I logged into the Kenmore website, entered the vacuum model no. and found that the bag has been superceeded by 20-50004, which appears to be available only from Kenmore. The belt required is #5270.
Aug 01, 2009 | Kenmore Bagless Upright VacuumVacuum
Kenmore upright model number 86039259990. The
don'thave to smell, the belt just snapped in half.unplug the vacuum and try to turn the brush roller by hand,if it turns real freely the belt is broke.it should be kind of hard to turn by hand if the belt was good
Mar 04, 2009 | Kenmore Progressive Bagless Upright with...
Vacuums Logo
22 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
