Question about Proform iLog 750 Treadmill
When i turn on the treadmill only humming sound is heard
    New Friend:
I'm having the same problem. Any solution?
Posted on Aug 15, 2015
Treadmill (Nordictrack T9si) stopped suddenly... Power still being received by controller unit, but display doesn't stay lit so nothing functions
open up the control console and look for loose wires... if no loose wires are found, call CoreCentric Solutions and ask if they refurbish that control board... CoreCentric Solutions Reverse Logistics Core Collection and Recovery...
Jul 06, 2016 | Exercise & Fitness
Why is my nordictrack T6.3 making loud humming sound all of the sudden?
You don't oil belts as oil will eat away at the rubber. Start with running the machine and checking for lumps of wax build up at rollers (most common issue) if this is not it try oiling roller bearings. But call manufacturer first to see if your warranty is still good because as soon as you touch it it will void warranty.
Jul 18, 2014 | Nordic Track NordicTrack T6.3 Treadmill
What does error7 mean when I turn on treadmill
there are 2 options with this error:
1) The elevation motor: Run the software calibration for diagnose, troubleshooting, and fix it. a) lube the gear and shaft very well b) adjust the potentiometer c) test the motor if o.k or faulty d) see if relais for up and down is clean the contacts.
2) Display board: adjust the reed switch see the diagram attached.clean, tigh the wires connector.
sincerely. God bless you
May 02, 2012 | Endurance TF3i Folding Treadmill
What does error7 mean on TF3i
2 options:
1) Elevation motor can be faulty a) lube the gear and shaft b) adjust the potentiometer. However is better RUN the software calibration for diagnose, and troubleshooting.
2) Display board, adjust the reed switch, see the diagram attached, clean, and tight the wire connector very well.
Altec Lansing GT5051, I'm hearing a humming noise from the speakers as soon as I turn them on. The humming noise is heard even if speakers are not connected to source.If I try and play music with...
Sounds like a problem in the speakers' internal power supply, maybe a faulty capacitor. Speakers need to be looked at by a technician, or replaced with a new set.
Jun 05, 2011 | Altec Lansing GT5051 Computer Speakers
NordicTrack Z7xi treadmill console buttons not working
Hello there. It sounds as if you may have a button stuck on your console. Thus not allowing any other buttons to be pushed. (i.e. the 4 beeps). This is usually caused by the i-fit buttons (silver buttons on the front). If the machine is only 4 months old you should still be under warranty (1 year) I believe. This problem in most instances requires the console be replaced. You can contact nordictrack through iconservice.com or by using the number on the fron of your users manual.
Good Luck! Tim
Dec 15, 2009 | Nordic Track Exercise & Fitness
LOUD BUZZING/HUMMING SOUND- CAN HEAR OVER AUDIO
have someone check speaker ground to the TV chassis. Your speakers are picking up reverb from the Video Signal.
Aug 19, 2009 | Vizio L37 Television
Reebok RX100 won't work right
Sounds like you could possibly have a bad drive motor or something is wedged into the walk belt somewhere keeping it from turning. Check this out. One more question. How long does the walk belt turn for, seconds, before it stops. Is it like 3 to 5 seconds or less than that.
Jun 29, 2009 | Reebok Rt1000 Treadmill Walking Belt
Tv makes humming noise when on. how can I eliminate or reduce the nose?
Some of the larger TV's are DISH ready, meaning that they have the tuner inside for SAT TV. The SAT tuners often have an internal fan that makes a humming noise. If it sounds like something other than that, you might have a bad component in your sound circuit that allows 60 HZ hum through the speakers.
If it is a rear projection LCG TV it has a fan in it to cool the bulb. You will hear the fan if you listen closely. It usually cannot be heard over the volume.
The fluorescent bulb and electronics inside make humming sound naturally. Kinda like when you turn on a lamp, and some lamps make a low humming sound.
Apr 03, 2008 | Televison & Video
Proform iLog 750 Treadmill Logo
121 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
